Old 05-17-2009, 09:28 PM   #1
albaughs07
Member#: 192327
2000 2.5 rs 4 door
maroon
Default 2000 2.5 rs gas light
gas light does not work anymore...just wondering if anyone might have the same problem and knew how to solve it. There is no gas light fuse.
albaughs07 is offline   Reply With Quote
Old 05-17-2009, 10:28 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I assume you are talking about the 'low fuel level' warning light. If that is correct see if you have power getting to it. If the bulb is good you should have power on both leads of the bulb. The return side of the bulb should tie to the thermistor in the tank. You could test the bulb placing a test light probe to the return side of the lamp and the clip lead to ground. Both lamps should light up. If the bulb is ok then I would make sure the wire to the thermistor in the tank is ok at the connector to the sensor.
MY98 2.5 RS fog lights in a 2000 OBS? jeff_rage Electrical & Lighting 3 07-14-2011 08:05 PM
(Socal) - Stock 2000 2.5 RS tail lights. Diabolus 1993 - 2001 Impreza Specific Parts 4 06-22-2009 02:07 PM
2000 2.5 RS Tail lights usdm turbolover Exterior/Styling 3 06-17-2008 07:50 PM
FS Right Tail light OEM 2000 2.5 RS Imprezivblue MAIC Private Classifieds 0 06-19-2007 06:37 PM
2000 2.5 RS Corner Lights Bigdrw Interior & Exterior Modification 1 01-11-2005 03:05 PM
