Old 05-17-2009, 09:37 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default What are Correct Compression Numbers with Stock and Wild Cams?
So while hanging around with some of the local guys, my compression test numbers came up again. What came out of the discussion was that none of us had a really firm handle on what the numbers "should" be. Consulting the factory service manual, it says, on page ME(H4SO)-2, that the compression pressure should be 148 to 185 psi. However, on page ME(H4SO)-21, it goes into greater detail and says that the cylinders must be within 148-185PSI with less than 7PSI variance between cylinders. Now, a couple of things about that jumped out at us.
First, none of us have ever heard of compression test results coming in anywhere near 185psi. Have any of you? The Subaru manual doesn't specify how many times to let the engine crank over. I've heard that differing numbers of revolutions can make different results.
Second, 7PSI variation between cylinders is WAY, WAY more strict than the commonly accepted 10% variation. Is Subaru being overly cautious, or are most of us being overly relaxed?
So, what compression numbers are actually "right" in the real world for a car with stock cams and a car with wild (Delta 2000, Cobb Spicy, etc) cams?
Old 05-17-2009, 09:42 PM   #2
Qman
Member#: 964
'95 work in
progress
Now, a couple of things about that jumped out at us. First, none of us have ever heard of compression test results coming in anywhere near 185psi. Have any of you? Second, 7PSI variation between cylinders is WAY, WAY more strict than the commonly accepted 10% variation. Is Subaru being overly cautious, or are most of us being overly relaxed?
Service manual numbers are for perfect, brand new engines. A 7psi variance seems a bit loose for a "new" engine. The "industry" standard is 10% between highest and lowest cylinders for a used, working condition engine. Engine compression isn't that critical as long as it is over 100psi and within 10%. You really do not have to over think this. For a vehicle that is making slightly over stock compression does not require it. For full race engines yes, for 200hp engines, no.
Using cams is not like re-inventing the wheel. Subaru engines do not have adjustable timing gears like a Honda, Ford or GM product. There is no variance for cam timing. It goes in at a set position. It stays at that point until the belt stretches or breaks.
Qman is offline   Reply With Quote
Old 05-17-2009, 11:42 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
When I did a compression test on my 98 OBS a few years back with 135k mi on the clock the results came back 183 psi with no more than a 2 psi variance across all 4 cylinders.
Not sure what you can take from my experience but my only point is that 185 psi is not too far fetched. Even my professional mechanic friends found it hard to believe what my results were and one of them repeated the test himself with nearly the same results.
98 2.2l engine 9.7:1 CR
PhilSine is offline   Reply With Quote
Old 05-18-2009, 01:37 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
My current engine is about 10 months old, maybe 8K on it. It has Cobb mild cams. I check compression when the engine is warm and let it hit compression 5-6 times when cranking and get an average # over 3 runs. It's right around 180 psi with maybe 5 psi difference. My old short block(with same heads and cams) would get around 172-176 psi.
Old 05-18-2009, 01:41 PM   #5
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
proper way is to let it turn over 3 times.
Zac86 is offline   Reply With Quote
Old 05-18-2009, 02:54 PM   #6
Odyknuck
Member#: 192866
2006 Impreza
The compresson (using two seperate gauges) on my 2000 legacy motor w/ 100K miles is 210, 205, 210, 205. I pulled the heads on Saterday and there is very little carbon on Pistons so its not from Carbon build yup.
Odyknuck is offline   Reply With Quote
What are my rough numbers? dj.rowland Newbies & FAQs 6 07-30-2008 06:48 PM
Just wondering who is running the Perrin 35r kit and what are your Dyno numbers? 03clipsegts Factory 2.5L Turbo Powertrain 7 06-05-2007 09:44 AM
What are the HP numbers for the 2000-2001 Subaru Imprezas? Vbp6us Newbies & FAQs 15 01-24-2006 04:50 PM
what are the part numbers for bhorton Brakes, Steering & Suspension 1 04-22-2003 04:38 PM
What are good alignment numbers for stock WRX suspension? wrxxtc Newbies & FAQs 4 03-22-2002 07:00 PM
Message Board Statistics All times are GMT -4. The time now is 03:11 PM.
