Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Old 05-17-2009, 11:26 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Water Temp Gauge Sender Install Options
OK, seems like a lot of people cut the main hose leading to the radiator and put one of these in:
I would prefer not to do this. However, I have done the TB Coolant Bypass Mod, meaning that I have the line to and the line from the TB plugged into each other with a double-male barb fitting. I would like to put the temp sender here. Is there such a thing as 3/8" double-male barb fitting with a port for a sender (usually 1/8"NPT) in the middle? Like this, but with a place to fit an 1/8NPT sender in the middle:
Old 08-03-2009, 09:40 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
bump for an update as I am thinking about doing similar thing...
Old 08-22-2009, 07:06 PM   #3
jitb
Member#: 220012
2008 Honda
Ruckus.
anybody else have input? i am also interested in this
jitb is offline   Reply With Quote
Old 08-22-2009, 07:14 PM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Curious why do you want to do it? The OEM sender registers accurate values if you read them through OBDII (Scangauge)
Old 08-23-2009, 03:35 PM   #5
jitb
Member#: 220012
2008 Honda
Ruckus.
A buddy of mine is giving me his old gauge set up and one of them is a water temp, and seeing how I track my car with NASA, I'd like to do this just to be safe
Old 08-24-2009, 08:30 PM   #6
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Get a 1/8 npt threaded T-piece with female connectors.
Then use 2 barbed 1/8nptx3/8 hose pillars.
Screw them in, and then hardsolder the 2 connections.
Dutch Scooby lover is offline   Reply With Quote
Lamco Boost Gauge with steering colume,prosport water temp with sender brand new jeremywrx15554 Interior/Dressup/Audio & Security 24 06-26-2009 04:52 PM
STRI Oil Temp Sender install options? MINO Electrical & Lighting 0 02-08-2009 02:28 PM
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 07:38 PM
oil pressure and water temp gauges, where to mount senders? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-15-2006 11:03 AM
Many options for water temp gauge sensor install... which one to choose? 02R6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-06-2005 10:59 AM
