Old 04-22-2002, 12:06 PM   #1
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Default O2 Sensor question
I need to replace both of my O2 sensors. They're both simple bosch 3 wire sensors. Should I be able to go and purchase a generic bosch 3 wire O2 sensor and have it work? Or is there something specific I shoul be looking for? I'm not all about spending ons of cash on the dealer parts just to get one that will plug right in.
Thanks!
Chuck is offline   Reply With Quote
Old 04-22-2002, 12:09 PM   #2
krave
Member#: 13908
2002 WRX Sedan
296 whp
I don't see why it wouldn't work right...you would want to splice in your harness to the o2 sensor.
krave is offline   Reply With Quote
Old 04-22-2002, 12:44 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you get the generic bosch sensor you should be able to get a plug that will mate to it and add that to your harness. I would rather have you do that then splice wires.
Tim Sanderson is offline   Reply With Quote
Old 04-22-2002, 12:50 PM   #4
SubaruStu
Member#: 8972
2003 WRX Wagon
Default Re: O2 Sensor question
Thanks!
When did Subaru change the front sensor? My MY00 front is a
5-wire one, with a six pin connector. There is also some "extra"
piece on the connector itself, that I can't identify - I'll take a
pic and post.
Stu
SubaruStu is offline   Reply With Quote
Old 04-22-2002, 01:05 PM   #5
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
I believe they changed 1/2 way through production in the '98 run. Mine was built in August '97, so I get all the old parts. Off to AutoZone to find the cheapest one. Thanks!
Old 04-22-2002, 01:21 PM   #6
SubaruStu
Member#: 8972
2003 WRX Wagon
Cool. There is another company NTK (by NGK) that makes them as well.
There must be a three-wire replacement for the Subaru.
S.
Old 04-22-2002, 03:48 PM   #7
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
I just went to Autozone.com and picked up both front and rear sensors, as well as the O2 sensor socket for the same price the dealer wanted to soak me for a single sensor. $162 out the door.
OEM parts prices get one of these... :monkey:
Thanks again!
Old 04-22-2002, 04:04 PM   #8
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
Hey Chuck...did you ever get your clutch issues resolved?
Sorry about the OT post.
beethoven is offline   Reply With Quote
Old 04-22-2002, 04:23 PM   #9
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Heh.. which clutch issues? After I blew up my 1st engine, I had the flywheel and clutch replaced with new stock junk. Everything has been pretty happy since. It still studders a bit when I don't rev the engine up a bit from a stop, but that's gone on so long that I've chalked it up to how the car works.
Old 04-23-2002, 03:06 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Default Re: Re: O2 Sensor question
pic and post.
Stu
MY98-99 has standard 3 wire bosch O2's...MY00-current use the wonderful 5 wire-wideband O2
jeremy
WRX o2 Sensor question... BuickturboV6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-09-2002 06:08 PM
TurboXS stage 2 exhaust O2 sensor question fastburro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-06-2002 11:59 AM
O2 sensor question NateDogg Normally Aspirated Powertrain 0 05-21-2001 08:00 PM
O2 Sensor question Spectre23 Normally Aspirated Powertrain 3 01-04-2001 10:16 AM
O2 sensor question Eric SS Technical Forum Archive 2 08-08-2000 09:19 AM
