Old 05-18-2009, 01:11 PM   #1
sublimeplaid
Member#: 106044
2011 Tacoma
Default My Volk center caps aren't fitting..?
So I took my wheels and center caps in to the tire place that balanced/mounted my tires on my 18x9 +35 SEIBON edition TE37's, I gave them the # 4 centercap on this list. They will not fit, it looks like a perfect fit, I have the rubber gaskets on there all lubricated, ready to pop in, but they just won't go in for some reason... Am I missing something?
Thanks.
j
sublimeplaid is offline   Reply With Quote
Old 05-19-2009, 07:49 AM   #2
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Hmm...they're a pretty tight fit on there. Did you try sliding one end in first then using a rubber mallet and towel to tap in the other side? They should be really tight. You can only get them out by tapping them out from the inside of the wheel.
Either that or you have the wrong rubber gaskets on there. There's a thicker one and a thinner one. An extra one should've came in the box. I had to use the thicker ones to fit my re30's without it popping out. Maybe you need to have the thinner gaskets on there?
Magnum626 is offline   Reply With Quote
Old 05-27-2009, 07:24 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks.
j
Looks like you got the wrong caps...
Volk uses specific caps for their wheels are the majority of the time
According to Volk. Those caps (GT Low) are designed for
TE37 19" only
The 18x9 +35 TE's require
A-Flat Type caps
Give the company you bought them from a call and have them send you the correct caps.
Gruppe-S is offline   Reply With Quote
Old 05-28-2009, 12:31 AM   #4
Magnum626
Member#: 62856
MBP SQC#197
I've had those #4 GT lows on my CE28s in 17 inch.
My new Volk Center caps doza Tire & Wheel 2 06-17-2009 06:39 PM
WTT: my BBS center caps for ur STi center caps ipang1988 Wheels/Tires 6 06-03-2009 08:27 PM
Volk center caps, black lugs, OEM center pod housing, Sub box Nelly Private 'For Sale' Classifieds 26 04-02-2005 10:17 AM
Volk Center Caps, help! AaronWRX Tire & Wheel 3 10-02-2003 11:47 PM
TE37s, WRX offset vs. Volk center caps 98kPa Brakes, Steering & Suspension 6 08-22-2002 06:23 PM
Message Board Statistics All times are GMT -4. The time now is 04:52 AM.
