South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-18-2009, 01:55 PM   #1
bboyjunglist
Member#: 178855
2004 WRXagon
Dat Java Black P SOn!!!
Default Need help installing stuff
i finally got everything i need. now i need to install it. tbe, uppipe, downpipe, vf-22 turbo, injectors, tmic, fuel pump. things i would REALLY need help on is the turbo, uppipe, injectors, and tmic. anyone one with a garage, tools and exp want to help me out? help would get pizza and beer/soda/gatorade or if u just want to make extra cash and install everything give me a price.
bboyjunglist is offline   Reply With Quote
Old 05-18-2009, 03:00 PM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I can most likely help ya out just depends when. The turbo, uppipe, and tmic are a cake walk. Injectors kinda suck balls, but not horrible. I wont do those for ya, I didnt even do my own.
v8eaterWRX is offline   Reply With Quote
Old 05-18-2009, 03:07 PM   #3
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
I can help you do all of it... I've got the exp, garage, and tools.... all air too. Unfortunately though, I can't this week/weekend as i'm working and have plans with the GF.
If you don't get anyone to help you out by next weekend, we can do it all at my place... just sucks with the weather being so damn hot now.
Are the injectors PnP? And, I hope you have an aftermarket inlet tube. If not, i'd buy one (Samco, APS, Perrin... don't a generic one, will just end up collapsing). The engine oil that's sucked in through the PCV system eats the stock one alive and is more than likely going to tear/rip when removing your old Turbo.
irascible is offline   Reply With Quote
Old 05-18-2009, 07:22 PM   #4
bboyjunglist
Member#: 178855
2004 WRXagon
yea it wont be this weekend i am waiting on my injectors. they're the blue 06 565cc ones. not sure if i have the inlet tube. when i bought the turbo the guy gave me a blue samco y looking tube, is that it? since you have all the tools, i will take you up on ur offer. how long do you think it would take? would we be able to do everything in one day?
thanx brock. maybe you can join us when i decide to get it done in 2 weeks or so.
Old 05-18-2009, 07:52 PM   #5
What's A GC?
Member#: 189719
1997 Impreza L Wagon
2 tone - Black/gray
The injectors are PnP(Plug n Play) then. Also, that hose is the y-pipe for the intercooler. The turbo inlet runs under the intake manifold and into the turbo. The factory one is pretty restrictive and flimsy where it mounts to the turbo. Since you will have it all apart anyway, I would go ahead and replace it. If you do use a cheap/generic one just be sure to put clamps at all the flat spots where it could collapse and you'll be fine. Although, I have seen some with really bad vacuum fittings...
What's A GC? is offline   Reply With Quote
Old 05-18-2009, 10:51 PM   #6
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
As long as we don't run into any snags with the stuff you have, we could have it done in half a day easily. The hardest part is the turbo, but with that out the up-pipe and down pipe is a breeze. Injectors I can have replaced in no time at all along with the TMIC.
As GC said, that is your TMIC hose. I suggest a good silicone or hard inlet tube, do it right the first time. The best IMHO are Samco and AVO for silicone, and for a hard tube the APS.
Yah brock, you should come hang out.
What day do you want to do this? June 6 or 7th?
Old 05-19-2009, 12:26 AM   #7
bboyjunglist
Member#: 178855
2004 WRXagon
thanx for the tip man, but i think i will spend the extra buck now that i dont have to save for a wedding ne more. you should also come out if thats koo with irascible. will be at the meet this week, so i will see you b4 then.
i dont have gaskets for my tbe. should i get some or do you also prefer jb weld? i will see if i can buy the turbo inlet from autozone tomorrow. june 7th would be perfect! i am worried though, my turbo started smoking today when i went to the gym. smells like oil, but when i drove home there wasnt anymore smoke(of course i didnt boost on the way home). would it be safe to drive it to and from work until june 7th(chking oil very often)?
Old 05-19-2009, 12:53 AM   #8
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I'm not sure if Auto Zone will have a turbo inlet, they can probably order a stock one but I'm not sure about anything after market. If not theres a lot of shops in town that more then likely have one
KP is offline   Reply With Quote
Old 05-19-2009, 01:13 AM   #9
bboyjunglist
Member#: 178855
2004 WRXagon
yea i figured. ill see if i can find one on the forum.
Old 05-19-2009, 09:03 AM   #10
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Anyone's welcome over on the 7th.
Buy the gaskets, I would never recommend JB weld for a gasket replacement.
Autozone won't have the inlet, online used or authorized dealers. You have plenty of time to get one, so don't sweat it.
Don't worry about the turbo smoking, you'll be fine as long as you keep up on the oil level.
Old 05-19-2009, 09:20 AM   #11
YOitsDUCE
Member#: 116120
2006 Subaru WRX STI
I would be down to watch.. or lend a hand hahaha.. =D you should make this some sort of a meet/install day??
YOitsDUCE is offline   Reply With Quote
Old 05-19-2009, 11:24 AM   #12
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
If it wasn't so damn hot, i'm sure more would show up... lol, but yah swing by.
Old 05-19-2009, 11:28 AM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I'll try to swing by and lend a hand as well.
The smoke is normal and is indicative of oil bypass around the shaft seals in the turbo. Mine started to do it recently as well, but it goes away after the car warms up. Check your oil frequently though as you do not want to let it get low and it will pretty quickly depending on how much is escaping the turbo seals.
Get a decent turbo inlet, not the OEM unit again.
Old 05-19-2009, 11:40 AM   #14
x-techno-x
Member#: 197229
2006 impreza wrx
Most likely i can swing by as well! June 7th it is?
x-techno-x is offline   Reply With Quote
Old 05-19-2009, 12:04 PM   #15
YOitsDUCE
Member#: 116120
2006 Subaru WRX STI
LOL.. damn it.. i forgot about the heat.. BUt i will def swing by to either watch or help. Dont know what good i'd do but.. Im down. =D just keep us posted.. Im really forgetful
Old 05-19-2009, 01:42 PM   #16
bboyjunglist
Member#: 178855
2004 WRXagon
so i have a samco inlet on its way here. is there a website you guys use or a place locally where i can pick up ALL the gaskets i need? can you tell me exactly which ones to get? my tbe is a blitz nur spec r. it was on a sedan b4 and i have a wagon. do we need ne thing else? just trying to get everything so we dont run into problems.
Old 05-19-2009, 02:45 PM   #17
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Looks like it; i'll send you each my address.
Old 05-19-2009, 02:46 PM   #18
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Well, the gaskets are OEM; you can get them at subaru. Unless the down-pipe only bolts up to their CBE which uses a different flange, that i'm not sure of.
Old 05-26-2009, 11:12 AM   #19
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
So far, those who were intersted in stopping by/helping are:
YOitsDUCE, x-techno-x, kpluiten, v8eaterWRX
I'll send you guys a PM with my address and phone #.
Old 05-28-2009, 08:37 AM   #20
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
This still on? I haven't heard back.
Old 05-28-2009, 05:04 PM   #21
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
I know I need a timing belt done, clutch/flywheel replacement, and struts done!
i'm gathering prices/parts right now...not sure if I will be ready by then tho...i deff want to do a install day ( i never pay for ish to be done on my car by a shop!)
SedonaScooby is offline   Reply With Quote
Old 05-28-2009, 05:24 PM   #22
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
lol timing belt, clutch/ flywheel and struts in the same day as the other install. Seems like a lot of work unless you have the "Overhaulin" team.
Anyways what are you doing about a tune might want to have someone bring over a cable for a reflash.
Smoby is offline   Reply With Quote
Old 05-28-2009, 05:30 PM   #23
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Intake manifold gaskets also! Most of the time they can be reused but you do not want to be stranded if one tears. They are cheap like 8 bucks a piece.
And a contraption to test for boost leaks is nice to have. Pvc cap and schrader valve works well and is cheap.
Old 05-28-2009, 05:32 PM   #24
SedonaScooby
Member#: 143522
98 Forester L (RIP)
haha never said it would be all in one day or that i could even make it that day...just saying i got a list of **** that needs to be done as well!
Old 05-29-2009, 09:27 PM   #25
bboyjunglist
Member#: 178855
2004 WRXagon
we still on. been hectic week for me. been change of plans on the build though. goin e85 and need bigger injectors. ne one want to trade my almost brand new 06 565cc blues for modded (flow tested) injectors?
Install Day??? Need Help Installing Suspension ...And Motorcycle For Sale... BoardRider North West Impreza Club Forum -- NWIC 11 09-28-2005 07:10 PM
Need Help! weird stuff happening to my car subiee sTi Newbies & FAQs 7 07-08-2005 08:44 AM
I need help installing stuff! Capt Crunch Mid Atlantic Impreza Club -- MAIC 25 04-06-2003 08:38 PM
Help instaling stuff MrWRXNYC Tri-State Area Forum 2 02-16-2002 11:03 AM
Help! Need help installing my Boost Controller Sagalyn New England Impreza Club Forum -- NESIC 8 07-10-2001 08:12 PM
