Old 04-22-2002, 12:53 PM   #1
2Point5RS
Member#: 3639
Default 30k Mile tune-up..
What is all included on the 30k mile tune-up? All that I have planned to do is the oil/filter, air filter, differential gear oil, spark plugs/wires. I'm going to top off the brake fuild resevoirs, and power steering resevoir. And of course check the brakes. Is there anything else I need to do? Also, I was looking at the rear differential, and what kind of tool is that for the drain and fill plug? What size is it?
Thanks
Matt
2Point5RS is offline   Reply With Quote
Old 04-22-2002, 12:55 PM   #2
2Point5RS
Member#: 3639
Blah.. can someone move this to S&M? Thanks
Old 04-22-2002, 01:34 PM   #3
spiralsmurf
Member#: 16085
2005 STi
i changed the tranny oil, fuel filter, spark plugs, engine oil/filter, air filter, rear diff oil, and coolant. you dont need to change your spark plug wires unless they are damaged.
spiralsmurf is offline   Reply With Quote
Old 04-22-2002, 01:52 PM   #4
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
IIRC, the rear diff drain is like a 3/4" square. You could use your 3/4" drive ratchet with no socket on it ('cuz that's a common tool to have in your toolbox ).... or you could just pay someone the $20 to do it and have them fill with Red Line gear oil and never have to touch it again.
Chuck is offline   Reply With Quote
Old 04-22-2002, 02:36 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
30k mile tune up includes :
oil change
tranny oil change
rear diff oil change
plugs & wires
fuel filter
air filter
tire rotation
brake bleed
coolant change
If the brake fluid and power steering fluid is low, then don't top it off yet. First, find the leak source. They don't go low that often unless there is a leak in the system.
tmat3 is offline   Reply With Quote
Old 04-22-2002, 02:50 PM   #6
2Point5RS
Member#: 3639
The brake fluid reservoir is about 2/3 full, and the power steering if just missing a drop. (nothing to worry about) So, I won't do anything about the power steering, but I will check the brake lines, although I haven't noticed any leakage on the ground. Where would be a good place to start looking?
Old 04-22-2002, 03:13 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
replace your PCV valve too.
ColinL is offline   Reply With Quote
Old 04-22-2002, 03:44 PM   #8
2Point5RS
Member#: 3639
Thanks to Richard L., I know what the hell that is!!
http://www.i-club.com/forums/showthr...&highlight=PCV
Old 04-22-2002, 04:08 PM   #9
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
The rear differential drain/fill bolts are 1/2" square. So your 1/2" drive for your ratchet will work just fine...
jhonas is offline   Reply With Quote
Old 04-22-2002, 06:07 PM   #10
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
As your brake pads wear, the pistons move out farther & more fluid is contained in the calipers, and this makes the level in the master cylinder fill reservoir lower. If you don't pay attention to your brake pads, the "brake" light will come on when the level reaches a certain point, and MAKE you aware that something is wrong. Do not "top it off" unless you have just replaced the pads, or you pay close attention to them. Otherwise, you may run out of pad. Almost happened to me once with a previous car - ran the brakes hard and forgot to check 'em for a couple weeks afterward, plus they wore fast anyway. The light in the dash saved my rotors.
Fred
Fred is offline   Reply With Quote
Old 04-23-2002, 09:27 AM   #11
2Point5RS
Member#: 3639
I have a little less than a 1/2 left on the brake pads.. Should I just wait until I put new pads on to top it off?
Old 04-23-2002, 09:55 AM   #12
Fred
Member#: 3560
06 STi, 02 STi
It's up to you, 2point5RS. Base your decision on whether you check your pads often enough to catch 'em before they wear out.
I still have about 1/3 original pad left, and have replaced my fluid 3 times - at 15000 miles, at 30000 miles, and after I installed my stainless steel lines a couple of weeks ago.
Fred
Old 04-23-2002, 10:14 AM   #13
2Point5RS
Member#: 3639
I check them fairly often.. about every oil change. I'll just get to them before they start making noises.. Thanks Fred.
30k mile Tune-up (need help..) goldice42 Service & Maintenance 1 09-11-2006 11:43 PM
30K mile tune up Vacca Rabite Normally Aspirated Powertrain 6 09-28-2005 08:54 PM
30K Service/Tune-Up Q's Impreza2003 Normally Aspirated Powertrain 13 07-27-2005 12:33 AM
30k Mile Tune-Up scoobieREX Service & Maintenance 16 05-16-2005 01:29 PM
30k miles tune up. RotarFreak North West Impreza Club Forum -- NWIC 5 02-04-2002 04:41 PM
