Old 04-22-2002, 12:57 PM   #1
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Thumbs up Redline Tranny & Diff Fluids
I just had Redline 75W90NS put in the tranny and 75W90 in the rear diff. WRX with 13 months and 30,300 miles of hard highway and some city driving.
Conclusion, a highly recommended fluid for you hard shifting 5MTs. The greatest benefit came from increase in the speed and smoothness of the synchro engagement. This resulted in faster and smoother up and down shifting. Honestly, it made my transmission feel as good as or better than new. It did not seem to reduce noise once your were in gear, but coming out of and going into gears is now smooth and fast like teflon coated butter through a goose.
On the flip side, it did nothing to help the "can't get it into first gear when rolling at more than 10 MPH" problem.
All in all, highly recommended for your 30K change, or sooner. And at about $44 for the fluids worth my money.
Wilkey
Ginseng is offline   Reply With Quote
Old 04-22-2002, 01:32 PM   #2
Drexel
Member#: 16566
2008 G35
Liquid Platinum
Default NS
I am curious as to why you used the NS w/out any friction modifiers in the tranny?? How is it hooking up? I was also under the impression that the rexes were using diff oil w/out friction modifiers? I put the Shockproof Superlight in the tranny and the NS in my Diff and all seems well. The tranny is very smooth but the reverse issue is stilll there. I can shift into first much sooner now than i could before though. Not a huge change but i run our local track once a week so its peace of mind more than anything!
www.midamericamotorplex.com
Drexel
Drexel is offline   Reply With Quote
Old 04-22-2002, 03:44 PM   #3
Ginseng
Member#: 3800
2002 WRB WRX Sedan
In searches, the 75W90NS appeared to be a good choice for reliable MT synchro operation. In fact, the Redline bottle implies that this is the fluid of choice for the gearbox. I found that the synchro operation is very smooth and very fast with this fluid. As I knew the change was coming, I paid particular attention to the shift quality pre and post change. I'm satisfied so far.
Redline recommends the 75W90 for hypoid and LSD gearsets. Since the LSD operation is somewhat more difficult to sense in normal driving, I'll have to pay attention over the long run.
Reverse seems to engage about the same as before, maybe just a bit smoother. But then again it's only been 100 miles and I've only been in reverse twice. I'll be back with more impressions over the next day or so.
Wilkey
Old 04-23-2002, 07:30 PM   #4
Ginseng
Member#: 3800
2002 WRB WRX Sedan
Thumbs up
Well,
It has now been two days and almost 400 miles after the switch to Redline driveline fluids. All I can say is wow. The tranny just gets silkier. And another benefit, getting it into reverse is now almost completely trouble-free. The reverse gear on this WRX had been balky since day one. Sometimes it took (de)clutching and jockeying the shifter towards reverse once or twice before it went in. Oftentimes it made a very audible "crunch" as it went in. Now it just slides right in. No slipping out of gear, just smooth, smooth, smooth.
Wilkey
Old 04-25-2002, 02:26 AM   #5
nixx
Member#: 7581
2001 Impreza 2.5RS
Default Re: NS
Drexel
Since Ginseng is doing lot of highway driving he doesn't need a tranny oil with too much friction cuz most of the time hes not gonna be changing gears. Friction is good for synchros but not as great for bearings; vice versa for friction oils.
Diff oil you MUST USE frictionless oil.
COBB Gear Oil Article
nixx is offline   Reply With Quote
Old 04-27-2002, 09:37 AM   #6
Corn-Picker
Member Sales Rating: (3)
Member#: 8679
2010 The most hated
vehicle on the internets
Someone emailed redline not too long ago and redline said to use 75w-90 NS in the front and 75w-90 in the rear.
I love my redline differential fluids. Thier consistency is great. Even if it's -10¡ÆF outside and your car is cold, the shifter action is still like warm butter. And the shifter feel does not change from -10¡ÆF and a cold car to 100¡ÆF and a car running WOT. Great great stuff.
Corn-Picker is offline   Reply With Quote
Old 04-27-2002, 12:19 PM   #7
Drexel
Member#: 16566
2008 G35
Liquid Platinum
Default oil
Nixx,
Yeah, i was pretty sure you should be using the NS in the DIff, glad some else caught that!
Drexel
Old 04-28-2002, 01:14 PM   #8
no_rex_yet
Member Sales Rating: (7)
Member#: 7351
04 330cic
I am running NS in the rear diff. Is this bad? Should I change it?
no_rex_yet is offline   Reply With Quote
Old 04-29-2002, 12:09 PM   #9
Ginseng
Member#: 3800
2002 WRB WRX Sedan
no_rex,
I don't think you should have any real difficulty with NS in the rear diff. In fact, I've heard that some people actually put in a blend of NS and non-NS in the rear diff to promote more aggressive lockup. The NS is the formula without friction modifiers and thus is not as "slippery" as the regular, hence the NS or non-slip designation.
Wilkey
Old 04-30-2003, 07:48 PM   #10
scoobteach
Member#: 29973
2001 Impreza 2.5 RS
I should point out that I talked to a technician at Redline and he said the Cobb article was flat-out wrong about MT-90. MT-90 and MTL are GL-4 oils that should not be used in a Subaru transmission. He also said Shockproof has solids that are bad on the synchros and the best choice was 75W90NS in both tranny and diff, since Subaru LSDs are not clutch-type LSDs that need friction additives.
scoobteach is offline   Reply With Quote
Old 05-02-2003, 04:42 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The limited-slip units are sealed viscous coupling types and are not affected by the type of oil used in the diffs. The purpose of the friction modifiers as in the Redline 75W90 is to reduce gear and bearing friction and lower operating temperatures.
Tranny & diff fluid changes are cake R_W Service & Maintenance 54 04-16-2009 09:47 AM
about to do a 6mt tranny and diff fluid change...where to get fluid? OneArmedScissor Texas Impreza Club Forum -- TXIC 9 10-21-2007 01:07 AM
Which Redline Tranny/Rear Diff Fluid to use for 6Spd??? NotoriousD Service & Maintenance 3 04-29-2006 03:39 PM
Which Redline Transmission/Rear Diff fluid to use? Info please! NotoriousD Transmission (AT/MT) & Driveline 3 04-25-2006 10:30 PM
Replacing Tranny & diff fluids instructions omahasubaru Normally Aspirated Powertrain 7 06-25-2001 03:19 PM
