Old 05-18-2009, 08:58 PM   #1
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
Default 03 GR2 with 05 sti prodrive spring with 04 top hat
is the 05 sti prodrive spring's rate too agressive for the 03 gr2 shock?
i do not want my strut to blow too soon from aggressive spring, I know the 02-03 prodrive / swift sport spring would fit perfect. just wondering if
this set up gona be too bumpy or not.
I currently have 03 gr2 with 02 RS stock spring on, so comfy level on bumpy wise, how different?
thanks
also, where do you guys find those (match or not match) data? is there a formula or website? I tried KYB / prodrive website to get their spec, but can't find any...
qualityracer is offline   Reply With Quote
Old 05-20-2009, 06:35 AM   #2
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
indytruckboy is offline   Reply With Quote
Old 05-20-2009, 08:50 AM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
thanks
Yes it'll be too stiff. If the vendor doesn't have spring rates listed you can usually find them at the manufacturer's website or around here on the forums. Link posted above is a table of known springs and rates. Very useful. The column about what struts they work with is just opinions from peoples' use. Some may like a strut spring combo more than others.
If people say your GR2 struts are 10% stiffer then I wouldn't go picking a spring that is more than 10-15% stiffer. Stock WRX springs are 160/120. That means you should look at springs in the 185/140 range, maybe a little higher.
That means your best options are:
Prodrive WRX spec
Swift WRX spec
Tein H-tech bugeye spec
Espelir ASD
As you increase spring stiffness you need a stiffer damper to control it. As you add a stiffer damper you begin to increase the vertical acceleration felt inside the car. You are reducing the amount the suspension compresses and rebounds over a given bump. You will feel more of the bumps and road imperfections. Without having test data to compare one setup to the next its hard to say how anything will compare to your stock setup or what you are running now.
I don't know of the RS spring rates are softer than WRX rates or by how much. I have a feeling that your GR2 dampers are the same ones designed/sold for the WRX. If RS springs are softer then you could very well be over-damped. The car isn't oscillating properly when you hit a bump and the shock you feel is much larger. It is entirely possible that you could improve ride quality just by switching to a set of stock WRX springs.
Scooby921 is offline   Reply With Quote
konis prodrive springs group N top hats $600 Richmond WRX MAIC Private Classifieds 4 01-24-2009 07:41 PM
Will 05 sti prodrive springs fit 04 sti? silverey3 Brakes, Steering & Suspension 4 07-14-2007 07:34 PM
V8 STI pink springs and rear top hats SubeSTIle Suspension/Brakes/Handling 14 08-09-2006 08:37 PM
04-05 sti prodrive springs. chibich Private 'For Sale' Classifieds 13 01-26-2006 08:16 AM
Impressions of 04/05 STi Prodrive springs? AaronWRX Brakes, Steering & Suspension 4 09-16-2004 08:08 AM
