Old 05-19-2009, 02:31 AM   #1
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
Default FP RED 390whp/380wtq TMIC Hybrid Engine
First off thanks to the people at Central Florida Turbo for great work!
Just got tuned there the other day on 93 octane at 20psi. Was tuned on stock ecu on their mustang dyno. I have to get a picture of the graph but it was really smooth and flat curve.
EJ257 block with EJ20 heads
CP Pistons
Cosworth high pressure/volume oil pump
ARP Head Studs
Brian Crower 272/272 Cams
Brian Crower Valve Springs & Retainers
FP RED 8cm
850cc fuel injectors
Turbo XS catless tbe
TGVs Deleted
Perrin short ram intake
ACT street clutch
This setup was also done on a big generic TMIC which was a limiting factor in the end due to so much heat soak with a FP RED hiding right under it... I will be getting a FMIC in a couple months and getting retuned. Oh yea still on stock 5 speed
toutanje is offline   Reply With Quote
Old 05-19-2009, 03:08 AM   #2
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Any pictures or dyno sheets?
VladiWrX is offline   Reply With Quote
Old 05-19-2009, 03:12 AM   #3
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
nice numbers. what clutch? where are you in florida? more info on the tuning shop?
evan_impreza is offline   Reply With Quote
Old 05-19-2009, 03:29 AM   #4
toutanje
Member#: 153465
WRX now FS!
Shop is in Orlando, the owner has a 700whp STi that ran a 10.4 I believe.
Old 05-19-2009, 06:49 AM   #5
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Sweet! Ill be moving to Orlando in a couple months, so thats good to know. What clutch are you running? how long are you expecting the 5 speed to last you?
Old 05-19-2009, 07:13 AM   #6
TurboDXsti
Member#: 106671
2006 Sti
grey
i have a similar setup , can't wait to get my ride running , things are looking positive now
TurboDXsti is offline   Reply With Quote
Old 05-19-2009, 10:26 AM   #7
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Looks like a nice build, congrats. Any work done to the heads? When are you seeing your 20psi in 3rd gear?
That's incredible you're still on the stock 5-speed
Steve.804 is offline   Reply With Quote
Old 05-19-2009, 10:32 AM   #8
penusai
Member#: 102808
1995 v8 EJ207 v7 6sp
30r swap in progress
i think everybody is waiting on the sheet =)
even though you only posted this 8hrs ago haha
penusai is offline   Reply With Quote
Old 05-19-2009, 10:40 AM   #9
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 [email protected]
wow very nice and on the stock trans very nice! hopefully it holds the power for awhile.
boostdog is offline   Reply With Quote
Old 05-19-2009, 11:32 AM   #10
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
i'm waiting on the dyno sheet too but i would like to see what the car has to offer with more boost.. the fp red probably likes it more in the 24psi? i dont know im just guessing. i bet with a fmic, ewg and meth would be awesome.
when do you get full boost?
ownnij is offline   Reply With Quote
Old 05-19-2009, 11:37 AM   #11
bgod
Member#: 100274
Great numbers.
As a former owner of an fpred, it's a great street turbo.
But wow, you must really need a front mount down in florida with the heat down there.
bgod is offline   Reply With Quote
Old 05-19-2009, 06:28 PM   #12
the real suby dude
Member#: 125497
02 Alpine White M3
Rouge Engineering !!!
Thats pretty good expescially on a mustang ...
Now get to the track asap ..i wanna see what this thing does
I think the one by you is Moroso?
GET THERE ASAP !!! lol
the real suby dude is offline   Reply With Quote
Old 05-19-2009, 07:16 PM   #13
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
stock unported heads? how do you like the cams?
Old 05-19-2009, 07:16 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
im curious as to how people attribute heat soak to being an issue when you're on the dyno with fans blowing?
i guess if your up pipe and down pipe arent wrapped, no turbo heat shield or turbo blanket, and no fans......then i can see an issue.
Old 05-19-2009, 09:48 PM   #15
toutanje
Member#: 153465
WRX now FS!
heads are not ported, just springs and cams (which are badass by the way) I need to upload a video of how the car idles with em.
Old 05-19-2009, 09:54 PM   #16
juanmedina
Member#: 133146
Please do! I have ported heads and the same cams with a VF39 , I will start the car on Thursday finally
Old 05-20-2009, 06:42 PM   #17
toutanje
Member#: 153465
WRX now FS!
in 3rd gear 20psi hits at 3800rpm
Old 05-21-2009, 12:18 AM   #18
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
nice job, GL with the 5 speed it probably hates you
I want your setup + PPGS + FMIC + C16
jmlaser is offline   Reply With Quote
FP RED Turbo 400whp/400wtq EJ257 Hybrid Engine toutanje Proven Power Bragging 21 06-26-2009 08:07 PM
WRX hybrid FP Green 7cm/3" TMIC 750cc Delta SAIKOU Proven Power Bragging 28 01-15-2008 11:55 AM
Advise requested from those running: FP Red.. what engine mods do you have??? TurboQueef Built Motor Discussion 3 11-13-2007 08:54 PM
FP Red with TMIC 4ST-AIR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 10-11-2007 09:11 AM
Utec Tuned For Fp Green 390whp Pump Sti drella258 Engine/Power/Exhaust 9 01-16-2007 08:26 PM
