Old 05-19-2009, 09:21 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Does the NA Block Have the Same Oil Gallery Plugs as the Turbo Block?
As the title says, and if so, do they use the same thread and pitch as the turbo plugs?
How many of them are there that aren't in use already?
Old 05-20-2009, 12:13 PM   #2
Subarudave09
Member#: 209316
14 XV
freeze plugs u mean??
Subarudave09 is offline   Reply With Quote
Old 05-20-2009, 12:51 PM   #3
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
does they use? nice
watchunglava is offline   Reply With Quote
Old 05-20-2009, 03:27 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, the oil gallery plugs. Different things.
Old 05-20-2009, 05:00 PM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
on the turbo motor, there's one on the back passenger side next to the turbo, and another one underneath the alternator.
rougeben83 is offline   Reply With Quote
Old 05-20-2009, 05:07 PM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Right, and all the info I've been able to find is for the turbo motor. I'm wondering if the NA motor has the same plugs, in the same place, with the same diameter and thread pitch.
Old 05-20-2009, 05:10 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
well, you could always look at yours The one underneath the alternator should be there too since that's where the factory oil pressure sensor is.
Old 05-20-2009, 05:14 PM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, I found the one under the alt when I re-sealed the oil pump over the weekend (which still leaks, dammit!).
Old 05-20-2009, 05:57 PM   #9
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
this is something I would like to know, also. plug size and thread pitch/type specifically.
Old 05-20-2009, 06:00 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The turbo ones are M18x1.5 I guess I'll be the guinea pig to find out if the NA ones are the same.
Old 05-20-2009, 06:07 PM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
cool. I'll bet they are. You asking so you can get a sending unit adapter or are you just replacing them?
Old 05-20-2009, 06:09 PM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Putting gauges in. I'd like to know how high the oil pressure is getting since I can't stop the pump from leaking.
Old 05-21-2009, 01:49 AM   #13
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I have never taken the plugs off, but I would be pretty darn sure they are the same. It doesnt make sense that Subaru would use 2 different sized plugs just because one block is semi-closed vs. open deck.
I will assume you have tried a new crank seal....
What kind of sealant are you using?
~Josh~
Old 05-21-2009, 02:09 AM   #14
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
they are the same i just pulled one off of my n/a block to put on my turbo block.
midnight2.5rs-t is offline   Reply With Quote
Old 05-21-2009, 12:08 PM   #15
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
New front main (crank) seal, new pump-to-block o-ring, new sealant (the actual Subaru part number called for in the manual).
Aftermarket oil pressure gauges and oil gallery plug... Q gopsu Newbies & FAQs 12 12-05-2009 06:08 PM
Oil Pressure/Oil Temp/Oil Gallery plug WRenXhaven Electrical & Lighting 28 05-28-2009 01:54 PM
Where is the oil gallery plug under the intercooler? Pic inside Donnie_Doritos Newbies & FAQs 7 07-13-2008 08:47 PM
To the local's who've done a gauge install: Where is the front oil gallery plug? Schleppy New England Impreza Club Forum -- NESIC 12 01-14-2006 08:33 PM
Wanted: the plug you remove to put in an oil gallery plug North Ursalia New England Impreza Club Forum -- NESIC 15 07-01-2005 02:41 PM
