Old 05-21-2009, 07:36 PM   #26
wrx-chris
Member#: 152082
2007 wrx
satin white pearl
Originally Posted by RiftsWRX View Post
I don't even know where you guys are comparing the Saab vs this car?
This car is running less boost, due to a more restrictive setup, and due to a cooling deficiency. Add ~97% IDC's. I don't know where the armchair tuner thinks anyone is responsibly going to try and push more out of a setup...
Give me a better IC, and 20-21 PSI on the bottom end and you'll see 350 lb/ft of torque on a different car.
You guys really can't compare one car to another. Just use it as a general guide.
Jorge (RiftsWRX)
www.ProjectWRX.com
wasn't comparing....just noticed the number potential on the saab
wrx-chris is offline   Reply With Quote
Old 05-21-2009, 07:40 PM   #27
wrx-chris
Member#: 152082
2007 wrx
satin white pearl
Originally Posted by Tucker587 View Post
Yes same dyno (dynojet IIRC), as for the loss in torque... the 324tq achieved in my previous tune only lasted for so long before it dropped drastically. The 280 torque i put down on this tune holds for about 3k rpm more lol. As I write this im in the process of scanning the two dyno sheets. Ill keep u guys updated in about 10 minutes so you can see the differences yourselves.
that's awesome....this get's me pumped up to finish my project!!
Old 05-21-2009, 07:58 PM   #28
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Yeah, ultimately, remember, you make maximum torque at 1 RPM.
Soooo, the faster something spools, the more "torque" you can make, because you're producing more "twist", which is what torque fundamentally is.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-21-2009, 08:13 PM   #29
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
^if only more people realized that! Torque that is LATER in RPM is better for acceleration as it allows you to take advantage of your gearing! My protuned 07 STI (same turbo) makes 340awtq but that's because it's 22psi at 3k RPM
Originally Posted by arch4life View Post
seems right on track for 17.5-18 psi. could he not push any more psi? was that why he was crushing the bpv?
as far as identical to vf39, it is, except the wastegate is sprung a bit stiffer, thats why people say it holds better to redline.
you can do the same thing with a vf39 with a wastegate helper spring, or even a vf30, 34, 43, etc. (mebbe the 43 is sprung heavier too) top end flow is exactly in line between my vf30 and my vf39, same flow. verified via logs.
The VF-43 has the stiffer spring so I assume the vf-48 does too. I'm also pretty sure the vf-48 has a larger turbine housing which will allow it to hold to redline better than the other vf-series turbos.
I'm also curious as to why you crushed the BPV Jorge? Obvious there are a few needed parts to make more power, so what were you trying to or what did you achieve by doing this?
Congrats to the OP for the new power! Get the needed parts to let Jorge make some REAL jam with that turbo!
Steve.804 is offline   Reply With Quote
Old 05-21-2009, 08:33 PM   #30
Tucker587
Member#: 178695
2007 Subaru WRX TR
Garnet Red Pearl
Ok having problems w my scanner. Gonna try this at a friends house in a few srry for the delays! Thanks Jorge for chiming in, ur much better at explaining things than I am thats for sure lol. Seems to make more sense when I read your posts instead of mine. Hang on there fellow scoobarooers, this will be posted tonight!
Tucker587 is offline   Reply With Quote
04-07 WRX stock intake duct feenomenal Private 'Wanted' Classifieds 0 06-04-2010 10:48 AM
07 WRX VF48 1/4 mile results! Tucker587 Proven Power Bragging 9 09-06-2009 02:35 PM
vf48 swap into 07 wrx WR-eX (Honda) Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-16-2008 11:59 PM
07 wrx vf48 tuned at precision Tuning sprewellnore Proven Power Bragging 38 09-20-2008 12:33 PM
