Old 04-22-2002, 04:24 PM   #1
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Default running like poo
Since it's warmed up, my car is hesitating something fierce... it's an 01, fookin' intake, amsoil filter, mrt complete exhaust (and accompanying CE)... it's got 43,xxx on it. Any ideas / suggestions?
AO
m750 is offline   Reply With Quote
Old 04-22-2002, 04:40 PM   #2
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
youre the specialist so I'm assuming you've got the good gas in 'er and tried the hard reset (map reset that is).
Good luck!
doobie is offline   Reply With Quote
Old 04-22-2002, 04:55 PM   #3
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
hmmm, since it's warmed up (er, did, it's freakin' 34F in vt right now, and snowing!!), my car has been running fairly well. i ran a tank of 93 (mobil) 2 tanks ago, and it ran great, and then some 89 (mobil), and it ran like ****. this morning i filled it up with 93 (mobil) and it's running great again. 93 from now on.
odd, since we're supposed to "not notice a difference" between the different octane ratings . . . hmmm... <scratches chin>
peter
slater is offline   Reply With Quote
Old 04-22-2002, 05:13 PM   #4
m750
Member#: 2278
8Sti | 07 allez
White | Comp
specialist? smeshalist.. I've been typically running 87, and it's been fine... since I noticed the hesitation 2-3 weeks, I've gone to 89, but the weather has been fluctuating so much it's not consistant. it's got 43k on her, maybe it's time for a tune up. I put the plugs in about 20k ago, the air filter is prolly dirty too... maybe time for a new fuel filter too. I'll try the earthing mod too, but it seems a bit gimichy though.
As for the ecu reset, well, I've got a scanner, so a hard reset isn't necessary, but I'd figure there's an inherant problem that's causing this, of course I haven't reset my ecu in monthes, but I know the code will come back. Ah, alas it is time to fix my leaky exhaust too.
AO <--- wishing his car had 4300, instead of 43000
Old 04-22-2002, 05:28 PM   #5
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
could try changing spark plugs, air filter, fuel filter, and pcv valve.
They're all relatively cheap items and probably need changing soon anyways... Try running premium gas and see if that does anything too...
jhonas is offline   Reply With Quote
Old 04-23-2002, 08:34 AM   #6
m750
Member#: 2278
8Sti | 07 allez
White | Comp
well... I did the simplest thing that I could think of, I used the odb-II scanner, and cleared my code, well, well, well... she's back.
So, I've cured the symptoms, but what is the cause? maybe I got a bad batch of gas, It's posible, I'm all over these days, and I guess I'm not all that selective about the gas I run (time to start being consistant w/ my gas purchases. I'm planning on a tune up in the comming weeks, oil, air filter cleaned, fuel filter, plugs, maybe the earthing mod. We'll see.
AO
My dinner makes your dinner look like poo. Strider Off-Topic 85 01-08-2010 08:14 AM
Looking for local help. Stage4 WRX running like poo b0dh1 Tri-State Area Forum 31 04-28-2007 08:50 PM
frankenstien runs nicely cold but like poo when warm? wrxwinnipeg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 12-26-2006 01:53 PM
Car running like poo, please help diagnose dedfish New England Impreza Club Forum -- NESIC 17 01-25-2005 08:45 PM
Does this sound like poo to you? (venting) Fat Ugly Soccer Mom Tri-State Area Forum 27 11-08-2002 06:23 PM
