North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 04-07-2010, 12:10 PM   #951
shiza
Member#: 95623
I will most likely bring my truck out. If you can find a trailer I can tow it if you break.
shiza is offline   Reply With Quote
Old 04-07-2010, 05:45 PM   #952
jeffg
Member#: 2958
2001 WRX (GC8)
We could always get you home if something happens. No worries there.
jeffg is offline   Reply With Quote
Old 04-07-2010, 10:46 PM   #953
kpatcht05
Member#: 185936
2013 WRX STI Limited
Satin White Pearl
Where can I find more details about the Rally x?
kpatcht05 is offline   Reply With Quote
Old 04-07-2010, 11:11 PM   #954
jesse_r
Member#: 200419
1998 forester
canyon red pearl
ok so i checked out the wrx sedan today theres a whining noise coming from the front he said the clutch is new so i assume thats it or maybe throwout bearing? but it felt like a totally different car than my wagon . my car as far as i know only had a catback doubt it made much of a difference. i never got my wagon on a lift. i can see the dinky td04 and downpipe on the sedan the one on the wagon looked bigger
jesse_r is offline   Reply With Quote
Old 04-08-2010, 02:23 AM   #955
shiza
Member#: 95623
There's a thread in the Autox section of idahomotorsports.com
Old 04-08-2010, 05:34 PM   #956
BIP
Member#: 217088
2005 WRX
As in less power or more? Does it squeal the whole time or does it get louder when you depress the clutch?
BIP is offline   Reply With Quote
Old 04-08-2010, 05:37 PM   #957
BIP
Member#: 217088
2005 WRX
And does anyone have torque specs for upper strut bolts and lower mounting bolts front and rear?
I found some on club wrx and just want to cross check for validity.
Old 04-08-2010, 10:23 PM   #958
jesse_r
Member#: 200419
1998 forester
canyon red pearl
yea i just feel less power but i really didnt hit it hard i will tommorow or tonight he installed the clucth bout 3 months ago he says its not broken in . ill get info tonight or early tommorow. btw i seen you today round noon by fairview i think
Old 04-08-2010, 11:42 PM   #959
jmilne
Member#: 232232
2005 Legacy GT Wagon
Bright Silver Metallic
Are you talking about the nut on the strut top? I think they are 14.5 ft/lbs. The diagram I have shows the lower front bolts as 112 ft/lbs. Not sure on the rear, I only have a diagram for the Legacy.
jmilne is offline   Reply With Quote
Old 04-09-2010, 12:22 AM   #960
BIP
Member#: 217088
2005 WRX
Yeah the strut towers I see are between 13.5-14.5lb. and then the lower bolts that connect to the hub I saw on an 02 wrx they said were at 129lb. Can't wait to free those up without an impact
Hey jesse must have been a different red rex, my car and i were at BSU from 8 30 till 2 30. Maybe the wagon had more done than you thought, or was running more boost. Maybe someone else could chime in on the clutch squeal, I've never had to replace one.
Old 04-09-2010, 12:33 AM   #961
wakeabyss
Member#: 148627
2007 FSXT
Scoobymods.com is your friend.
This is for a forester: http://www.scoobymods.com/attachment...0&d=1068435015
http://www.scoobymods.com/attachment...2&d=1068435094
wakeabyss is offline   Reply With Quote
Old 04-09-2010, 12:35 AM   #962
wakeabyss
Member#: 148627
2007 FSXT
PB blaster+breaker bar+ cheater bar=cake
Old 04-09-2010, 12:39 AM   #963
jesse_r
Member#: 200419
1998 forester
canyon red pearl
it was running bout 12-13 psi (boost gauge) im gonna bite the bullet and buy the sedan he has proof clutch was replaced with a stage 2 clutch less than 3 months ago . if anything ill end up parting it to get my money back.
my fault yours is a wrx that was an sti Or atleast had a sti spoiler. i almost got into an accident on i84 wen i saw the wrb bug eye with the morettas parked in nampa micron looks great even from a couple hundred feet
Old 04-09-2010, 09:29 AM   #964
jmilne
Member#: 232232
Yeah, this will make your life much easier. Only way I could get the lower rear bolts off of my Legacy.
Old 04-09-2010, 09:46 AM   #965
Xissix
Member#: 85985
Thanks! I often wonder how easy it is to see from the freeway.
Xissix is offline   Reply With Quote
Old 04-09-2010, 11:27 AM   #966
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have had to add heat to this formula to make it work on a 17 year old car
Old 04-09-2010, 11:41 AM   #967
BIP
Member#: 217088
2005 WRX
Yeah I definitely have the PB blaster and breaker bar ready.
Jesse you're going to bite the bullet? Pretty close to same car you had last week, except less trunk space, less dents, stock, and pretty close to the same price with clean title. Sounds like a good deal haha.
Old 04-09-2010, 01:48 PM   #968
jesse_r
Member#: 200419
1998 forester
canyon red pearl
haha those were my exact thoughts
Old 04-09-2010, 03:17 PM   #969
jesse_r
Member#: 200419
1998 forester
canyon red pearl
So I went to drive the car.it whines when its in gear when accelerating. The more I step on it the louder it gets then ill take it out of gear. And. The whinnning continues. It gets softer as the speed drops. But when its in Gear The whinningis softer when decelerating
Old 04-09-2010, 04:07 PM   #970
Xissix
Member#: 85985
Anyone know how to check oil pressure on a 97 2.5NA engine? Search function is down and I'm getting nowhere on the legacy specific sites.
Old 04-09-2010, 04:08 PM   #971
Xissix
Member#: 85985
Sounds trans/diff related, does it sound like gear whine or other? Maybe it has straight cuts
Old 04-09-2010, 05:50 PM   #972
jeffg
Member#: 2958
2001 WRX (GC8)
Could be CV joints as well. Did you look under the car for any obvious oil leaks or grease?
Old 04-09-2010, 05:51 PM   #973
jeffg
Member#: 2958
2001 WRX (GC8)
Do you have an oil pressure guage? There are a couple of oil galley plugs that you can use on the top of the engine. You will need an adapter. The plugs are M18x1.5. You may also need some hose depending on who big your gauge or sending unit is.
Old 04-09-2010, 07:14 PM   #974
jesse_r
Member#: 200419
1998 forester
canyon red pearl
i have a feeling its eithers the new clutch or wheel bearing
Old 04-09-2010, 08:16 PM   #975
Xissix
Member#: 85985
I have a guage but it's for std fittings, looks like I'll need an adapter, thanks Jeff!
Boise Thread For March Jaxx North West Impreza Club Forum -- NWIC 120 04-01-2002 03:48 AM
Boise Thread For Febuary Jaxx North West Impreza Club Forum -- NWIC 135 03-04-2002 09:22 AM
Boise Thread for January02 Austin North West Impreza Club Forum -- NWIC 74 01-31-2002 11:18 PM
Boise Thread for December Jaxx North West Impreza Club Forum -- NWIC 122 12-31-2001 11:39 AM
Boise thread for OCTOBER Jaxx North West Impreza Club Forum -- NWIC 141 11-01-2001 02:19 AM
