North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 04-12-2010, 01:28 AM   #1001
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
1001... dang it Jesse!
Baja820 is offline   Reply With Quote
Old 04-12-2010, 01:56 AM   #1002
jesse_r
Member#: 200419
1998 forester
canyon red pearl
Haha I spend too much time on here
jesse_r is offline   Reply With Quote
Old 04-12-2010, 01:17 PM   #1003
Magnetrax
Member#: 198885
1991 Legacy SS
white
xissix, thanks again for the help yesterday. and for anyone who wants to get their fenders rolled, he is good with that eastwood roller.
Magnetrax is offline   Reply With Quote
Old 04-12-2010, 01:55 PM   #1004
Xissix
Member#: 85985
^^ Thanks for the props!
Xissix is offline   Reply With Quote
Old 04-12-2010, 05:53 PM   #1005
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ooooh a 1000 posts :P
Old 04-12-2010, 07:39 PM   #1006
crums family wagon
Member#: 193370
2005 STI
Aspen-White
Hey BIP nice set up! Looks nice and flush what size wheels are you running and the offset?
crums family wagon is offline   Reply With Quote
Old 04-12-2010, 07:47 PM   #1007
crums family wagon
Member#: 193370
2005 STI
Aspen-White
Well the other day I found a big pile of grease under the rear axle boot where it meets the wheel. I assume the axle boot is torn although i didn't see any thing. Is this a correct diagnosis or could it be more than that? And is it an easy fix?
Old 04-12-2010, 07:50 PM   #1008
Xissix
Member#: 85985
Could be the wheel bearing, could be the boot is torn, depending on the amount, could be from some yolkels leaky truck on the road . I had a pretty nice glob on my front inner fender last summer.
Should be an easy fix if it's the boot or the bearing. Used axles/bearing aren't too spendy, and can be swapped out in your driveway with basic tools and a jack.
Old 04-12-2010, 09:41 PM   #1009
jeffg
Member#: 2958
2001 WRX (GC8)
How long do used bearings typically last?
jeffg is offline   Reply With Quote
Old 04-12-2010, 09:50 PM   #1010
Xissix
Member#: 85985
Depends on how used they are
Old 04-12-2010, 10:54 PM   #1011
crums family wagon
Member#: 193370
2005 STI
Aspen-White
Thanks for the info. The boot looks as though it is being cradled by the pile of grease their is that much. Is it pretty easy to find out if the bearings are going out? Whats the best way to tackle this? Also if I grab the axle and move it right and left their is a little play in it, more on one axle than the other. Sorry I'm not much of a mechanic just an electrician.
Old 04-12-2010, 11:27 PM   #1012
wakeabyss
Member#: 148627
2007 FSXT
Since when is a 20 ton press a basic tool.
wakeabyss is offline   Reply With Quote
Old 04-12-2010, 11:32 PM   #1013
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
both front cv boots are torn on my wifes legacy. I worked on em for about four hours and finally gave up. its was tough. I do have a 24mm axle nut socket if you need to borrow it. lemme know if you are gonna do the repair yourself. I would be interested in seeing how the axle comes out.
Old 04-13-2010, 12:31 AM   #1014
Xissix
Member#: 85985
Doesn't everyone have a 20 ton press? Sorry, forgot about that, you could get the whole hub/knuckle assembly swapped out quick though with basic tools.
I'm not sure how to exactly to tell when a bearing is bad, other than it makes noise on the freeway or when turning. If it's like older american cars, it will get pretty darn hot when it gets really worn out, but with the brakes making so much heat, hard to tell by heat alone.
If it's just an axle/boot, that is a pretty quick swap. Lots of how to's on here on how to do it, or if you want I can help out.
Sure sounds like we need an fix-me-up/install day, anyone want to host
Old 04-13-2010, 01:11 AM   #1015
BIP
Member#: 217088
2005 WRX
Hey thanks. I'm running 18x9.5 +35 offset
BIP is offline   Reply With Quote
Old 04-13-2010, 01:18 PM   #1016
jmilne
Member#: 232232
2005 Legacy GT Wagon
Bright Silver Metallic
I'd be happy to if I can get some of the big empty boxes out of the middle of my garage. I know I've got a pile of parts that need to be installed.
jmilne is offline   Reply With Quote
Old 04-13-2010, 01:47 PM   #1017
Xissix
Member#: 85985
Sounds good to me, want to set something up? I'll be there to help as long as it's a Sat or Sun.
Old 04-13-2010, 04:29 PM   #1018
jmilne
Member#: 232232
Sure let me double check my calendar, I know we have some weekend things coming up so I don't want to double book. I have a Killer B oil pickup which is my next project, and am waiting for a BNR turbo, would be nice to have a hand with either one. Would be great to help with anyone else's project(s) too.
If someone can bring an extra set of jack stands and some tools I've probably got enough room in the garage for two cars to be worked on as well as plenty of parking on the street. Oh and a BBQ and big fridge too should we need those.
Edit: no 20 ton press though, so you might have to bring that!
Old 04-13-2010, 06:50 PM   #1019
crums family wagon
Member#: 193370
2005 STI
Aspen-White
I'd be up for a fix me up day. I have some basic jack stands if needs be. I also need to repack my rear struts I have the sti rear clunk going on and tracked it down to the struts.
Thanks for everyones info about my axle hopefully its just the boot.
Old 04-13-2010, 06:54 PM   #1020
crums family wagon
Member#: 193370
2005 STI
Aspen-White
I think I may have saw you this past weekend in Nampa on Midland. Do you live in Nampa?
Old 04-13-2010, 06:54 PM   #1021
wakeabyss
Member#: 148627
2007 FSXT
I'd be up for a fix me up day. I also need to repack my rear struts I have the sti rear clunk going on and tracked it down to the struts.
I thought that issue was fixed in 2005. You're not running 04 sti rear struts are you?
edit: now that think about it, your car was pretty low and I wonder if it's sitting on the bump stops and whether the previous owner trimmed the bump stops when he did the H&R springs.
Old 04-13-2010, 10:43 PM   #1022
CGM_WRX
Member#: 66280
2005 WRX Sedan
Crystal Gray Metalic
An install day sounds fun!
On a side note anyone with a street bike that lives near Boise want to help me out with something?
I work at the transportation department and they are currently revising the motorcycle license manual. They have asked me to try and get a photo of a bike in traffic for one of the sections in the book. You wouldn't get any monetary value out it if the picture ended up getting used but it might be cool to tell people that it is you. lol
CGM_WRX is offline   Reply With Quote
Old 04-14-2010, 12:16 AM   #1023
Xissix
Member#: 85985
I'll do it, but my bike isn't registered at the moment . Would be kinda fitting to have an American bike in the manual...
Old 04-14-2010, 12:20 AM   #1024
Xissix
Member#: 85985
For the install day, I'll bring my spring compressor, a jack, some stand and a few tools if needed. Can bring my fender rolling tool to if anyone is willing to donate to me paying it off
Old 04-14-2010, 08:24 AM   #1025
CGM_WRX
Member#: 66280
2005 WRX Sedan
I'll get more info on what type of photo they are looking for and get back to you ASAP. All they told me yesterday was they were looking for a bike in traffic.
Boise Thread For March Jaxx North West Impreza Club Forum -- NWIC 120 04-01-2002 03:48 AM
Boise Thread For Febuary Jaxx North West Impreza Club Forum -- NWIC 135 03-04-2002 09:22 AM
Boise Thread for January02 Austin North West Impreza Club Forum -- NWIC 74 01-31-2002 11:18 PM
Boise Thread for December Jaxx North West Impreza Club Forum -- NWIC 122 12-31-2001 11:39 AM
Boise thread for OCTOBER Jaxx North West Impreza Club Forum -- NWIC 141 11-01-2001 02:19 AM
