Old 05-20-2009, 11:25 AM   #1
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Default How important is the placement of power steering line behind the grill
Ive been doing some cleaning up of the engine bay and have decided to remove the hardline from the powersteering line which goes behind the front grill.
I have then routed the shorter lines to the resivoir inside the engine bay.
How critical is that hardline behind the grill in terms of temperature cooling?? I.e is it essential??
is there a one way valve in those lines?if so where is it??
tino is offline   Reply With Quote
Old 05-20-2009, 08:28 PM   #2
wgknestrick
Member#: 32576
04 STI
Are you sure you aren't talking about the AC lines Tino?
The only hard PS line comes off the high pressure side of the PS pump and goes above the head and back to the steering rack. This can certainly be replaced with $80 worth of Summit fittings as seen here:
http://forums.nasioc.com/forums/show...+lines+rotated
Bill
wgknestrick is offline   Reply With Quote
Old 05-20-2009, 09:28 PM   #3
tino
Top Scoob 019
Member#: 43630
It's definately from the power steering line. It's a bent hard line which sits behind the grill for cooling of the fluid. Just wondering if it's essential?
I've still got the hard lines that sit in the engine bay. I'm just extending the rubber hose off the resivior and removing that hardline behind the grill.
Old 05-21-2009, 08:29 PM   #4
tino
Top Scoob 019
Member#: 43630
This is the part i want to remove
Old 05-22-2009, 05:59 AM   #5
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
My 2004 doesn't have that line... unless im retarded and dont remember =P
AKSubieDubie is offline   Reply With Quote
Old 05-22-2009, 09:55 AM   #6
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Neither does my 06
Im assuming there must have been some sort of production change in 04, maybe soon after the first run of sti's?
-Vic
ec2k1gt is offline   Reply With Quote
Old 05-22-2009, 04:11 PM   #7
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
He probably has a different car, I believe Australia gets different models then the US.
Dutch Scooby lover is offline   Reply With Quote
Old 05-22-2009, 07:35 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
This^
I have the jdm PS tank and cooler. I would keep it if you do any hard street driving or tracking. Subies heat up their ps fluid and blow their racks often at autox and track events.
scby rex is offline   Reply With Quote
Old 05-22-2009, 07:39 PM   #9
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Older GC models STi's also had them fitted.
Because of the quicker steering rack the oil heats up more.
I am guessing the JDM/AU models have a quicker steering rack then the EUDM/USDM models, so FHI decided to fit this cooler.
I can't say I've seen them on the EUDM models either.
Old 05-22-2009, 07:41 PM   #10
tino
Top Scoob 019
Member#: 43630
Yeah I have an adm model. When I was playing around with I snapped the hard line. Most probaly going to put a ps cooler in it's place.
Old 05-22-2009, 07:49 PM   #11
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I think that is the best option.
I believe FHI only sells a complete set, with the tank and all in it.
They don't sell replacement hardlines i think, and the price of the complete set is nothing short of amazing.
Old 05-22-2009, 07:56 PM   #12
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
You make it sound like you could buy an engine swap for less than the PS setup!
Chi_San is offline   Reply With Quote
Old 05-22-2009, 08:08 PM   #13
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I've seen the price for a GC STI PS cooler setup,and that worked out to about 800$, without install, quoted froma shop which has very low pricing.
A bit steep for 3 feet of copper/steel pipe, and a different lid on the PS reservoir.
Old 05-23-2009, 11:15 AM   #14
scby rex
Member#: 104878
02 wrxbastardchild
I got my jdm tank, and all the lines and cooler for 50 bucks. A steal, as theres one in the classifieds now for 160.
Old 05-25-2009, 03:42 PM   #15
Mechie3
Member#: 120152
Just saw this thread:
http://forums.nasioc.com/forums/show....php?t=1769142
That guy has a JDM power steering line. Definitely not on the USDM cars. Yours is either a cooler, or simply a placeholder so they woulnd't have to change supporting hardware.
Mechie3 is offline   Reply With Quote
Old 05-25-2009, 03:47 PM   #16
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
GC8 STI's have the same cooler as the first one.
This one is just another version of it, with more cooling capacity addes by the spiralled metal.
Both are functioning oilcoolers.
Old 05-29-2009, 01:45 PM   #17
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i actually just picked that one up, it is the one with the extra cooling fins, i have already blow one rack, and one pump so i am hoping this will solve the problem, and its a heck of a deal from what i have seen before
seanathanq83 is offline   Reply With Quote
Old 05-29-2009, 02:11 PM   #18
dunk
Member#: 15359
What happened to the your steering rack? Just curious what the symptoms were when it blew.
-Duncan
dunk is offline   Reply With Quote
Old 05-30-2009, 02:30 PM   #19
seanathanq83
Member#: 173241
-Duncan
felt like power steering was not working as good, then slowy got worse, untill it was pretty much no power steering, i was told i blew out the regulator seal or something by the dealer. its supposibly the main seal in the steering rack
Old 05-30-2009, 02:38 PM   #20
Chi_San
Member#: 53558
2005 Baja Sport
I drove an XT6 that had Power Anti-Assist. You would turn the wheel so far, then the power steering would start to work against any more movement of the wheel. It took like 12x the effort to turn past that point that a non-assist car would require while stopped, and that was while it was moving.
I'm gonna get a quickrack when my steering rack goes out, if it ever goes out.
Old 05-30-2009, 09:10 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
Yup, mine is exactly like that one. I got mine from kingpin when they were in business.
Old 05-31-2009, 12:20 PM   #22
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Does anyone have an engine pic of what this adds on the engine bay side? I want one of these, but not at the expense of clutering up the bay.
D Money is offline   Reply With Quote
Old 05-31-2009, 12:35 PM   #23
seanathanq83
Member#: 173241
mine should be here like tuesday, but it looks just like the stock resovoir, you just have two lines going behind the grill
this is the pictures the guy i bought mine from had http://forums.nasioc.com/forums/show....php?t=1768364
Old 06-01-2009, 06:26 PM   #24
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
damn, won't work for mine. My powersteering res has been relocated.
Went rotated? Tired of the stock power steering lines? SloRice Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 305 09-12-2016 06:46 PM
How important is the vacuum line behind the intake manifold? KAX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-22-2008 10:49 PM
whats the diameter of coolant feed line to the turbo? dvang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2006 11:11 AM
is this power steering line or transmission fluid line? thanks racerxl99 Transmission (AT/MT) & Driveline 2 04-05-2006 07:53 AM
Does the STI front strut tower brace get in the way of a/c lines like the Cusco one? Paulie Brakes, Steering & Suspension 2 06-23-2002 10:18 PM
