Closed Thread
Old 05-25-2009, 12:12 AM   #1
shayrgob
Member#: 90959
03 wrx
Default Ignition fuse keeps blowing!
This isn't for a subie but that's ok.
I'm working on my cousins 97 GST. All i was doing was putting a boost gauge in it. Well, I couldn't find a suitable place to tap for 12V ignition so I went to the ignition wire off the ignition switch. I know that sounds sketchy but the previous owner had tapped it b4 so I thought I would use it too. Well, he started the car fine and then shut it off. After 5 min he started it again and it shut off by itself after a couple seconds.
I check the ignition fuse and it was blown! So...I went ahead and removed the boost gauge and returned everything back to stock and it still blows the fuse. When I ran the wiring from the top of the dash to the bottom I used a wire hanger so I thought that I ripped up some wires while shoving it down there. So I ripped the dash out! LMAO. But everything looks good. I even cut the ignition wire and wired it directly to the fuse box in the engine bay. It still blows! I then took out every single fuse and relay and even took the fuse box out from inside the car. It still blows! What's going on here? Am I missing something?
And to clarify. There is the ACC, ON, and STR on the ignition. You can put it in ACC mode and turn the radio/lights on fine. But as soon as you turn it to ON it blows. You can't even try starting it b/c it blows by then.
Let me know if you guys have any ideas b/c I'm burnt out and have no clue.
shayrgob is offline
Old 05-25-2009, 11:07 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You may have pinched a power wire somewhere while working on the install. The trouble may be under the hood rather than the dash. Go over any work you did there to see if you can find a pinched wire. I suggest you get the wiring diagram for the vehicle so you can see where the power for that lead ties to if you can't locate the trouble by looking over things. Your locale library may have the service info available.
Cougar4 is offline
Old 05-25-2009, 01:55 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
never--EVER-EVER tap the ignition wiring for power
that is one of the dumbest things that can possibly be kiddied
Uncle Scotty is offline
Old 05-25-2009, 02:15 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Nope.
The Electrical & Lighting forum on NASIOC is for technical discussion about any Electronics/Lighting related to any Subaru
Non-Subaru discussion goes to OT or use a forum specific to that make.
Mulder is offline
Closed Thread
Ignition fuse keeps blowing dubluv17 Electrical & Lighting 43 11-07-2010 06:35 PM
Speedometer/Window fuse keeps blowing Geoff Electrical & Lighting 0 05-31-2005 02:36 PM
*Urgent* Wiring some lights and fuse keeps blowing Subwoofer87 Electrical & Lighting 6 09-20-2004 11:23 AM
Radio Fuse Keeps Blowing Stilletto Electrical & Lighting 7 09-18-2003 12:12 AM
Main Fuse Keeps Blowing??? striklybidnis Electrical & Lighting 3 07-20-2003 11:36 PM
