Old 05-20-2009, 05:43 PM   #1
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
Default 04 sti cluster swap into 02 problems...
I just swapped an 04 sti gauge cluster into my 02 wrx. I cut the wire for the buzzer and, I also cut the wire that makes your fuse blow over and over. The problem I'm having now is that my gas gauge and engine temp gauge are not working at all if anyone can help that would be great.
thanks
skate enjoi is offline   Reply With Quote
Old 05-20-2009, 05:44 PM   #2
JSA
Member#: 154320
2002 Grandpa Wagon
With a small FP Green...
The B harness of the cluster has nothing to do with that side of the cluster.
Which wires exactly did you cut? The wire for the buzzer is the same as the radio fuse blower.
JSA is offline   Reply With Quote
Old 05-20-2009, 07:30 PM   #3
skate enjoi
Member#: 120716
2002 psm ver7 wrx
I must have an 05 cluster then because the wire that is the buzzer and the wire that blows the fuse are two completely different wires...
Old 05-20-2009, 07:42 PM   #4
JSA
Member#: 154320
2002 Grandpa Wagon
In the middle cluster is the yellow w/green tracer...I might be wrong but that one controls the buzzer but in turn blows fuses. Cause as soon as i cut the B28 wire I wasn't blowing fuses but I had no buzzer.
Some say you have to cut an additional on the right hand harness. A9.
Forgot what color/trace it is though
Old 05-20-2009, 08:34 PM   #5
skate enjoi
Member#: 120716
2002 psm ver7 wrx
I have both of those wires cut, thats not my problem... My problem is my gas gauge isnt working at all
Old 05-20-2009, 08:59 PM   #6
JSA
Member#: 154320
2002 Grandpa Wagon
Are you sure it wasn't a pre existing problem before the cluster swap?
That's strange...
Old 05-20-2009, 09:23 PM   #7
skate enjoi
Member#: 120716
2002 psm ver7 wrx
I put my stock gauge cluster in and it works fine
Old 05-20-2009, 09:27 PM   #8
JSA
Member#: 154320
2002 Grandpa Wagon
I'm not knowledgeable on motherboards/circuits. But I would take the back off and see if there are cracks/breaks etc...
Definitely sounds like a problem with the cluster now...which sucks. They are expensive
Old 05-20-2009, 09:32 PM   #9
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
I had the same issue. See if you can play the needle up and down for the fuel and temp gauge. Same issue happened to me when I was putting tape behind the dccd and diff light.
scooby_wooby is offline   Reply With Quote
Old 05-20-2009, 09:53 PM   #10
JSA
Member#: 154320
2002 Grandpa Wagon
So on yours, the needle wasn't clicked down all the way?
Old 05-20-2009, 10:12 PM   #11
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
When my cluster was acting up, my gas gauge and temp sensor was stuck and it wont even do the sweeping motion. All I did was move the gas needle from empty to full and back and i did the same thing to the temp sensor. Move it from hot to cold and back. I reinstalled it and bam! The gauges swept like it meant to be.
Old 05-20-2009, 10:50 PM   #12
skate enjoi
Member#: 120716
2002 psm ver7 wrx
Ill have to try that out tomorrow because I did put electrical tape over the diff and dccd lights
Old 05-20-2009, 11:43 PM   #13
yaya20
Member#: 130354
You probably slightly dislodged the needles when you were taping over the DCCD light. Same thing happened to me with the gas light a week ago. I was able to press it back in and the next time I started it, it swept and was reading properly.
yaya20 is offline   Reply With Quote
Old 05-27-2009, 01:30 PM   #14
skate enjoi
Member#: 120716
2002 psm ver7 wrx
the thing is, my needles still sweep, my gas gauge is now all the way at the top, my engine temp gauge doesnt work, when I turn on my left turn signal it doesnt blink on my cluster and Im pretty sure the little light for my brights is always on in the cluster too
Old 05-27-2009, 01:45 PM   #15
JSA
Member#: 154320
2002 Grandpa Wagon
Hmmm...if everything worked before, sounds like a definite cluster problem.
Old 05-27-2009, 01:48 PM   #16
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
i have the same problem, my fuel gauge doesnt go right to the top when fuel and the temp gauge doesnt read at all but my stock cluster works, everything sweeps the way its supposed to though.
bugeyesubie is offline   Reply With Quote
Old 05-27-2009, 04:15 PM   #17
skate enjoi
Member#: 120716
2002 psm ver7 wrx
Im not sure if it worked before or not...
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
Fix: Rear Diff Light Stays On - STI Cluster Swap Into WRX pioneer_sti Electrical & Lighting 15 10-01-2007 11:35 AM
04 sti full swap into 02 wrx sedan jobxiii Subaru Conversions 0 09-10-2007 09:51 AM
'05 STi Cluster swap into '05 WRX - need actual install instructions WRblueX_Guy Electrical & Lighting 13 03-24-2007 01:29 AM
STI cluster swap into a WRX Gr8fulDave Warranty Issues & SOA Problems 14 08-01-2005 04:55 PM
Message Board Statistics All times are GMT -4. The time now is 01:10 AM.
