Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-20-2009, 08:52 PM   #1
Sparconx88
Member#: 161756
05 Wrx
Default [email protected] with stage 2 wrx?
So I live in Colorado where the altitude is obviously higher but my 1/4 mile times are absolutley unacceptable. I have a 2005 wrx with STi up pipe, 3inch invidia turboback, SPT short ram, and an open ECU tune on 91 pump gas at roughly 14psi. I went to Bandimere today which is a local drag strip only to have my car running a ****in 15.2.....My best 60ft was a 2.1 and im shifting just below 7 grand. This is basically the exact same time I was running when the car was stock last year. My only idea of what it could be is high temperatures. It was about 83 degreese or so at the track and I don't have a turbo heatshield or intake heatshield. Any ideas? A stage 2 wrx at this altitude should easily be about a 14.2 to a 14.5
Sparconx88 is offline   Reply With Quote
Old 05-20-2009, 08:55 PM   #2
C J
Member#: 132587
2006 JrTuned STi
[email protected]
practice makes perfect, just keep at it and the time will come down.
C J is offline   Reply With Quote
Old 05-20-2009, 09:00 PM   #3
Sparconx88
Member#: 161756
05 Wrx
I don't get it though I'm launching the car pretty damn hard like around 4700 to 5200 rpms and I'm shifting quick but its just not doing it
Old 05-20-2009, 09:01 PM   #4
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
seems low...
codesoccer is offline   Reply With Quote
Old 05-20-2009, 09:03 PM   #5
C J
Member#: 132587
2006 JrTuned STi
[email protected]
can you post up all the information from your timeslip? Just looking at the 2.1 60ft shows there is quite alot of room for improvement.
Old 05-20-2009, 09:28 PM   #6
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
shift lower around 6k rpm. and there is no reason you cant get your 60' into atleast the low 1.8. you say you are launching hard, are you getting wheel spin (i would think not at that track to nice of a prep job) so are you bogging off the line? I am in ABQ NM and were are a mile high just like you guys. Just keep at it it sounds like you just need more seat time. It will come with time.
*6STARS* is offline   Reply With Quote
Old 05-20-2009, 09:30 PM   #7
Sparconx88
Member#: 161756
05 Wrx
R/t .496
60' 2.167
330 6.346
1/8 9.781
1000' 12.743
E.t. 15.225 @ 90.01
Old 05-20-2009, 09:33 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Launch the car better. Get launch control added if you want, it's lots easier. Shift lower, 6500 is about right. A stock turbo 2.0 is dead at 7,000. With a 1.8 60' time and shifting lower you will be where you want to be.
Edit- Just saw 90mph. Something is wrong there. Even with awful driving you should trap higher than that. Datalog and be sure the car is running right and not knocking and pulling a bunch of timing.
Old 05-20-2009, 09:39 PM   #9
Sparconx88
Member#: 161756
05 Wrx
Thanks for all the help and info. I forgot to mention that I turned the heater on full blast in hopes to blow off some hot air the whole way down the track. I also didn't think about shifting lower so that could help. As for getting a low 1.8 60 I wish I could but im afraid to launch my car that hard being that it has a ****ty tranny and clutch I don't want to blow it up. I thought it was launching hard there was absolutely no bog what soever.
Old 05-20-2009, 10:15 PM   #10
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
I pull 1.7 on my 5 speed that is the only gear I'm hard on I shift like a granny in every other gear. The car is not running right it seems. Like it was stated above data log if you can.
Old 05-20-2009, 10:28 PM   #11
some dude
Member#: 100300
06 WRX
CGM
2.1 60 ft isn't terrible, and even with that you should be movin a lot faster at the end. I don't know how much altitude effects the ETs but stage 2 2.0L usually run in the 13's. So 15 second runs are waaay off.
some dude is offline   Reply With Quote
Old 05-20-2009, 10:42 PM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You should not IDLE your car all the way to the water box. Only start your car to MOVE it while waiting in line. Keep it off. This will help keep your TMIC cool. If you idle your car all the way to the lights, your TMIC is SUPER HOT. This is why I see STi's running 13's on stg2 tunes. hahaha it's just funny.
FuJi K is online now   Reply With Quote
Old 05-20-2009, 11:21 PM   #13
down2earthsubie
Member#: 171448
2003 wrx
psm
when i had a top mount i would go to walmart. buy a 10lb chunk of dry ice and stick it on ur intercooler. then take it off before you race. it will litterally freeze your intercooler. i ran 13.7 @ 95 mph on 91 pump and stage 2 in utah. same elevation as colorado pretty much
down2earthsubie is offline   Reply With Quote
Old 05-20-2009, 11:33 PM   #14
Sparconx88
Member#: 161756
05 Wrx
Thats a good idea I think ill try that next time. 13.7 sounds a lot more realistic
Old 05-21-2009, 12:48 AM   #15
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
7k shifts are a bit high for the TDO4. Shift sooner and you'll pick up some time/speed.
Also, your 14psi tune probably leaves alot to be desired
RonJitsu is offline   Reply With Quote
Old 05-21-2009, 02:39 AM   #16
subenerd
Member#: 72630
2004 STi
Definitely ice your intercooler if you have to wait in line. Also, if you want a better time, you're gonna have to drive it harder (especially the launch).
I also agree that 14psi is pretty tame.
subenerd is offline   Reply With Quote
Old 05-21-2009, 03:28 AM   #17
Farnk
Member#: 91093
2002 Wrx
Hot lapping on my stage 2 bugeye I ran a 13.7 @ 98 when I missed 3rd gear.
Also though for some reason that was my best time of the night lol.
Farnk is offline   Reply With Quote
Old 05-21-2009, 09:21 AM   #18
jpjester
Member#: 153624
2009 WRX Hatchback
Who tuned your car? Because it seems to me thats where your "epic failing". I see that you have an Open ECU Tune ... ummm 14 psi of boost, thats lame. Go to a new tuner as the one that did your car seems to be missing alot! If you don't have one around, drop the Open ECU Tune and get the Cobb Accessport and run the Stage 2 Map. You will see a drastic difference with a true quality tune. I understand the Cobb Stage 2 map is not the best of the best quality, as it's so generic. Yet, i can bet it's much better then your current one.
jpjester is offline   Reply With Quote
Old 05-21-2009, 11:59 AM   #19
Sparconx88
Member#: 161756
05 Wrx
Yeah I didn't do enough research when it came to the people that tuned my car. I live in Colorado and here there are a lot of reputable tunning shops. But because I was stupid and didn't realize who was about to tune my car I took it to a place called Racing Trenz. I guess there have been a lot of complaints about the shop and them messing with peoples graphs after the tune. As for using ice, I did a lot of that. How much boost can a stock wrx turbo handle?
Old 05-21-2009, 12:01 PM   #20
SubyWill
Member#: 166830
2003 WRX
i ran a 13.7 @ 98 in my wrx with JUST an ebay catted tbe. no tune no intake no nothing, and i was also hot lapping.
it's all in the launch man.
SubyWill is offline   Reply With Quote
Old 05-21-2009, 12:59 PM   #21
jpjester
Member#: 153624
2009 WRX Hatchback
It all depends on what supporting modifications, how much boost it can handle. The point here is not just to turn up the boost and you will get better times. You need all your timing corrected, A/F Corrected, Everything. I'd suggest posting in the section for Colorado and askin whats the best shop within 100 miles to go to. With a good quality tune and practice you will get much better times.
Locate the Shop after doing the Research on Here
Call them up and talk to the Tuner about your situation, your concerns.
Set up a date to go by the shop to have your car tuned properly (using a dyno) and have them look it over. You maybe surprised how bad your past tuner was.
Old 05-21-2009, 01:09 PM   #22
Obsessive
Member#: 77302
damn well better
bail me out of this ****
+1 - go to a different (reputable) tuner and have it tuned on the DYNO.
Your MPH is waaay too low for a stage 2. Even if you launched better, you wouldn't pick up 7-8mph. My old 05' 4EAT stage 2 with an OTS 91 octane Cobb map pulled 14.4's at 98mph with the stock converter and valve-body. It was getting 2.3-2.4 60's (mostly because of heat-soak, I could only launch at 4-5lbs of boost).
Obsessive is offline   Reply With Quote
Old 05-21-2009, 01:23 PM   #23
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
Give Harvey a call over at SupeRoopair in Boulder, he'll be doing my stage 2, E85 tune if I ever get my swap done.
I've also heard of good things about the guys over at MAC.
my4isflat is offline   Reply With Quote
Old 05-21-2009, 01:51 PM   #24
Sparconx88
Member#: 161756
05 Wrx
Yeah Mac and Superupair are very good shops as well as Revolutions in Colorado Springs. The car was tuned on a dyno using open source and then it was back on another dyno just to do some runs. I'm going to be super pissed if it turns out that it is the tune and not my driving. Id rather learn that I am a ****ty driver then to learn my car is running like ****.
Old 05-21-2009, 01:55 PM   #25
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
R/t .496
60' 2.167
330 6.346
1/8 9.781
1000' 12.743
E.t. 15.225 @ 90.01
You can shave over a second in ET and who knows how many more mph to your trap speed with a better launch and 1st-2nd gear shift. Get your 60ft to 1.7-1.8 and your 330ft 5.2-5.5.
I also second the notion that a tuned WRX should be making much more than 14psi. A few years back when I had my 02 WRX, my Cobb OTS map boosted 17-18psi and resulted in a 101 trap speed with a 2.0 60ft.
Steve.804 is offline   Reply With Quote
