Old 04-22-2002, 05:58 PM   #1
Br0kWRX
Member#: 12317
Default 1/4 mile- when to shift into 4th?
At the track this past weekend, with 98MPH trap speeds i would always require a shift into 4th before the end of the 1/4 mile. I was shifting at like 7,200 RPM, but is that a good idea? do you think it would hurt my time shifting right before the end? maybe i should shift at 6,500 so i could pick up more speed?
I did try once to keep it floored, but i hit the rev limiter about half a second before the end.
Br0kWRX is offline   Reply With Quote
Old 04-22-2002, 06:07 PM   #2
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Default Re: 1/4 mile- when to shift into 4th?
Dude, I tried shifting into 4th earlier and I got the same trap speed. 98mph. If we had the 2.5 RS differentials, we would be able to use 4th gear well in the 1/4 mile.
kenshiro is offline   Reply With Quote
Old 04-22-2002, 07:16 PM   #3
jmott
Member#: 6713
2007 Prius
brown
you dont want to shift into 4th until you have to.
its overdriven and will slow you down.
take 3rd gear as high as you can.
jmott is offline   Reply With Quote
High Pitch Grinding Sound When Shifting Into 4th Gear mcrawford Newbies & FAQs 3 10-09-2007 01:10 PM
grinds when I shift into 4th 03 bug eye Transmission (AT/MT) & Driveline 3 06-21-2007 05:47 PM
hard to shift into 1st and 2nd when cold orionh2215 Transmission (AT/MT) & Driveline 2 11-12-2006 09:05 PM
Transmission grind when shifting into 4th. ShaneC Factory 2.0L Turbo Powertrain 10 06-19-2004 01:24 PM
1/4 Mile - Stay in 3rd or Shift to 4th scoobyrex Proven Power Bragging 12 07-29-2002 01:36 PM
Message Board Statistics All times are GMT -4. The time now is 09:05 PM.
