Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 05-21-2009, 12:59 AM   #1
mems3
Member#: 188617
Chapter/Region: PRSIC
2008 WRX Sedan
Default crappy bi-xenon kit wiring
ok so my friend bought this set of crappy HID bi-xenon conversion kit for his wagon and the thing is wired the wrong way meaning the low's are the highs and highs are lows.
which are the wires i need to switch to correct this?
mems3 is offline   Reply With Quote
Old 05-21-2009, 02:41 AM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
it would help to know the year of the car.
i am going to take a wild guess that this is an 02 youre talking about. it is the only model that you would *need* a bixenon kit.
if it is ideed an 02, you eed to switch the wires in the stock headlight connector.
middle is positive, outer two are grounds for low and high beam. flip the two outer connectors and you should be good.
jdubya301 is offline   Reply With Quote
Old 05-21-2009, 10:00 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
correct it into the ****can
get real lights
Uncle Scotty is online now   Reply With Quote
Old 05-21-2009, 02:52 PM   #4
MyRuRex
Member#: 21349
02 WRX Wagon
Had this issue also way back.... spore found the solution:
'My plug wires were Red White Blue (On the HID harness). I switched the outer plugs, but nothing changed. The only way i got them to work is arranging them Blue Red White.'
^^Your wire colors may be different BUT the positioning should be the same.
Basically from 1-2-3 to 3-1-2.
REMEMBER... this is all on the HID harness NOT the factory harness
Good luck....
MyRuRex is offline   Reply With Quote
Old 05-21-2009, 07:10 PM   #5
mems3
Member#: 188617
2008 WRX Sedan
sorry guys its a usdm 02 wrx waggon
Old 05-21-2009, 07:12 PM   #6
mems3
Member#: 188617
2008 WRX Sedan
worked! thanx
Wiring Bi-xenon HID's with Halogen Highbeams Saturn Electrical & Lighting 4 06-21-2005 03:55 PM
GC H4 Bi-Xenon HID Conversion Kit FatCatTurbo Private 'For Sale' Classifieds 24 08-07-2004 10:24 PM
Phillips bi-xenon hid Kit AzN121184 Electrical & Lighting 6 07-28-2004 12:23 AM
Has anyone tried a bi-xenon HID kit? DrD Electrical & Lighting 2 02-23-2003 11:56 AM
Bi-Xenon 9004 HID kits? andygold Interior & Exterior Modification 4 07-10-2002 10:42 PM
