Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 05-21-2009, 04:50 PM   #1
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Default Untuned stg2 wrx knocks on 12s door...
Hey, So I finally got the chance to get to the track last night. 2002wrx stg2+....Untuned.
Launching at 5200 and shifting around 68-7200 right before redline fuel cut. I couldnt get out the hole without spinning from a higher rpm launch or bogged out on a lower rpm launch. I couldnt figure it out...
Can I break 12s?...Or should I man up, save my engine and get a damn tune!? Im car 5068...btw
Gruppe-S Unequal Length Header - Wrapped
STI catless uppipe
HKS Downpipe - Wrapped
Ebay 3in catback
Stock BPV
K&N Air intake panel filter
GimmickMS AfterMAF hose
GimmickMS Turbo Inlet Hose
GimmickMS Pulley
Prodrive Topmount Intercooler Hose
Hallman Manual Boost Controller - 18psi
Syms Grounding Kit
Paranoid Fabrications Fender Braces
Steering rack Bushings
Perrin Subframe crosslock
Tein Flex Coilover
Tein EDFC Kit 12f -8r
Tein Rear Strutbar
Tein Front Strutbar
Cusco Rear Trunk brace
Front swayBar w/ Endlinks
Prodrive lip
GT Spec STI Grill
Stage 1 Exedy Clutch
JDM STI Hood Scoop
06 wrx rims w/ RE070s at 27psi
Piss 90oct for those wondering...
Yes. this is in the 2.0l thread as well but I figured it would get Way more attention in here...hopefully?
Marlons101 is offline   Reply With Quote
Old 05-21-2009, 04:50 PM   #2
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
what am I doing wrong? or Is the tune my limiting factor?
Old 05-21-2009, 05:14 PM   #3
C J
Member#: 132587
2006 JrTuned STi
Stock block 10.34@134mph
So I knew the 16bit ecu's were more forgiving but damn 18psi on stock map?
I don't think you are doing anything wrong with your driving, in fact it looks from your timeslip that you are driving the wheels off of it for being a stage 2 2.0 liter wrx w/ no tuning.
C J is offline   Reply With Quote
Old 05-21-2009, 05:15 PM   #4
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Hey Marlon, again nice time! I was going to PM back to say that you should probably be shifting 2-3 around 6500 and 3-4 around 6200-6300 by looking at how much it seems to fall off up top. A tune will definitely help to extend the powerband which is all you should need to get into the 12's. Although don't be surprised if you put it on the dyno and it doesn't make much more peak from your baseline, the AUC you gain up top is what you need at the strip.
OppositeLock is offline   Reply With Quote
Old 05-21-2009, 05:24 PM   #5
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
next time out I will try a lower shift point to try and stay in the power band. Also I need a high rep tuner to go Very Aggressive with a tune for me...Like blow **** up aggressive. hah. Not really concerned with dyno numbers ATM... But in 2,3,4 gears after 5200rpms I can feel the drop off of power from the stock map... NEEDS a tune I KNOW but...Soo closed untuned I hate it!
Old 05-21-2009, 05:25 PM   #6
wuuusaa
Member#: 92894
wow just wow.... your a clown.
Old 05-21-2009, 05:27 PM   #7
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Why mr. I blow engines? cause I wanna blow something up too? dont hate me.
Old 05-21-2009, 06:02 PM   #8
wuuusaa
Member#: 92894
Whatever Mr.I blow trannies.... you everyone that made fun of me blowing my engine something always happened to them. Anyways sorry for the thread jack, congrats sucka.
Old 05-21-2009, 07:21 PM   #9
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Wow 18psi with a MBC totally untuned? The stock ECU runs pretty rich and I'm willing to bet that is your only saving grace! With all the crap you bolted on you'll probably see some decent gains, run safer and have better drivability with a TUNE. The least you can do is pick up a tactrix cable and pay a couple bucks for an e-tune through EQ Tuning or whoever if you dont want to fork over the cash for an AccessPort.
Seriously though what are you trying to achieve? Be the first to run 12's unsafely with a untuned, mbc WRX? I dont even know if that has been done. Either way you can keep that record
edit: AND you're running these boost pressures on less than crappy gas? YOUR CAR HATES YOU.
Steve.804 is offline   Reply With Quote
Old 05-21-2009, 07:25 PM   #10
jason miller
Member#: 158313
2003 WRX
someone in maryland, str8gone i think, has gone 12's untuned; but he had ppg's...
jason miller is offline   Reply With Quote
Old 05-21-2009, 07:32 PM   #11
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
+1x1milliontrillion
he speaks the truth.
wanted to also comment why spend the dough on parts and not spend any dough on a tune? doesn't make any sense to me.
Illusive is offline   Reply With Quote
Old 05-21-2009, 07:34 PM   #12
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Steve!!! I WANT THAT RECORD!! HAHAHAAHAHAH!! NICE!! but no seriously...I want like a 12.6 on the stocker...ewg or meth or both. with a tune obviously...but a 12.9 untuned would be freakin awsome. and yes 90piss octane, my car does hate me.
Jason miller I have a 2002 wrx with a 05wrx 5spd if that makes ANY difference...lol
Old 05-21-2009, 07:35 PM   #13
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Originally Posted by Illusive View Post
+1x1milliontrillion
I LIVE IN ALASKA!!! NO DYNOS!!! NO PRO TUNERS!!! I can fly a tuner up here for 700 or I can get an email tune for 300.... I HATE!!!!! ALASKA...
Old 05-21-2009, 07:56 PM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I love Alaska, what part are you in?
KP is offline   Reply With Quote
Old 05-21-2009, 09:47 PM   #15
jason miller
Member#: 158313
2003 WRX
A tactrix cable and a basic stage two tune would probably be a lot safer than what you're running now...
And if you want some kind of record, you'll need to be shooting for Oppositelock's 12.49 on the stock td04. There's no "stock turbo untuned" record, and I wouldn't want to be the holder if there were. Anyway, meth injection and/or race gas will probably be required if you want to shoot for that 12.49 @ 109. He trapped 111 on another run with a slower time, btw. I'd bet $100 you don't ever get near that record, and it's a great way to break something. I'd get a tune of some sort and just enjoy the car without getting too caught up in any kind of record. Also, there's a chance you would be slower with a tune. You just may be running lean right now, which is obviously fast; but also a good way to blow a ring/melt a piston.
That was good driving though. Trapping 83 in the eight shows you were shifting the piss out of the car.
Old 05-21-2009, 09:51 PM   #16
Redline927
Member#: 77622
I dont understand that with all those mods, you wouldnt dish out another 300-400 bucks for a tune.
With that trap, and that 60', you probably wont get a much faster ET than that. 1.7 is probably all youll be able to pull with those tires, no LC, etc.. which is a very good 60'. Nice run, though.
maybe 12.999 with perfect conditions.
prove me wrong! good luck, have fun.
Redline927 is offline   Reply With Quote
Old 05-21-2009, 10:19 PM   #17
C J
Member#: 132587
2006 JrTuned STi
dont hate on MBC's!
Old 05-21-2009, 10:27 PM   #18
B00ST_Creep03
Member#: 199304
2003 bugeye
psm
just the title alone made me laugh.. "Untuned stg2 wrx knocks on 12s door"... very nice times though, run that bitch till it blows
B00ST_Creep03 is offline   Reply With Quote
Old 05-21-2009, 11:03 PM   #19
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
East side of Anchorage...
Yes, he has a tune and lesser mods. I dont see how my car when tuned wont get close to that. As if he clicked off a miricale pass?...anyway you just like the rest have no faith in the lil td04. all good though. And yes Im driving to break something. I have 6spd, sti engine and 30r going in this winter. Soo objective is just to last till the summer is over...
No tuners in alaska. No AWD dynos in alaska. I would need an email tune and seeing this was my first time at the track with the car. I SHOULD HAVE LOGGED but...I was trying to break 12s for my life...
And I do believe the tires are holding me back at this point...TOOO much wheel spin in the rear...sad. Track operators were suggesting I get halfway bald snow tires...
Originally Posted by C J View Post
dont hate on MBC's!
Have faith in the MBC! just dont get retarded with it..lol
That is the objective. and I didnt even think about it...but im sure I had some knock events during my passes lmao...
Old 05-21-2009, 11:27 PM   #20
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
Its just a very short matter of time before you burn a piston top or destroy a ring/land...
Since you are moving that much air, your timing map is probably over ran and you are running too much timing..
Don't believe me? Keep driving it
-Jerod
JSarv is offline   Reply With Quote
Old 05-21-2009, 11:34 PM   #21
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Nobody is in denial here...well im sure as hell am not. I know what the end result will be if I continue down this route. But Im looking at tuners I just dont know which one to goto yet...as It WILL HAVE TO BE AN EMAIL TUNE...No dynos and No PRO tuners up here in Alaska...
Log email log email log email log...run at track?...just the way it is...sucks to live in alaska. No dynos No tuners and Shipping hurts like a bitch.
Old 05-22-2009, 12:48 AM   #22
Hi-Speed Solutions
Vendor
Member#: 143099
2008 AW STI
Rockin' the hatch!
we bring up a tuner at least once a year. you read the last the day or two threads? Jarrad's coming up TWICE this year (if not more). June tune is still open.
Hi-Speed Solutions is offline   Reply With Quote
Old 05-22-2009, 01:14 AM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
while i agree with steves point about being untuned, the fact of the matter is that you will make less power tuned.
stock subaru ecu's attempt to run a crapload of timing, so if you're not resetting your ecu you are running max timing for your setup and octane . if you get tuned your timing will ultimately be lower (read safer) and thus you will be slower.
since your running the stock intake with a panel filter your fueling is most likely fine.
basically, you're running a good amount of boost and the max timing you can everywhere in the rpm band......something that would be hard to achieve on an opensource tune.
running like you are is unsafe with regards to a protune, but ultimately more powerful.
Old 05-22-2009, 07:59 AM   #24
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
He does have more mods then you....and has made over 300 pass on the stocker so iam sure he also has some practice under his belt. Not saying you cant do it but just putting some things in perspective. Good luck and i would vote for a clark email tune for 150 and have him make you a 100oct/torco map for the track.
Paul is online now   Reply With Quote
Old 05-22-2009, 03:22 PM   #25
Lboogie
Member#: 171611
2014 FiST
Blk
^ this
Lboogie is offline   Reply With Quote
knocking on heaven's door... ride5000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-27-2006 04:53 PM
home owners: do people knock on your door asking for donation or to sell something? friedbbq Off-Topic 16 09-29-2005 09:46 PM
What do you say when you are in the bathroom and someone knocks on the door?? HalfBaked Off-Topic 51 01-26-2004 08:31 PM
come and knock on my door. philip_g Off-Topic 23 09-13-2003 09:04 PM
The PM Mail Man is Knocking on Jamie's Door MGXsport North West Impreza Club Forum -- NWIC 4 05-26-2002 12:11 AM
