Old 05-21-2009, 05:41 PM   #1
MattD87
Member#: 126930
2012 Impreza Sport
Default Are 05 STi AXLES the same size as Late 04 STi?
I just removed a busted late model 04 STi axle from my car. I had a spare axle laying around which I had thought was from an 04 STi but turns out it was about .5" shorter at the threads. (Not sure if it's from an 05 STi, or something else?)
So now I need to order a new axle but want to make sure a late model axle is the same as an 05.
Thanks
MattD87 is offline   Reply With Quote
Old 06-04-2009, 06:22 PM   #2
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
I would like to know the EXACT same thing. Someone please answer, I know the spline is the same because I have already put 05-07 sti hubs/knuckles on my 04 sti, but I thought I once heard that the 05-07's are a little longer, which makes the stance of the rear a little wider, thats what i thought the trim piece was for along with the new 8" instead of the 04's 7.5" wide rims.
I need to know because 1 of mine broke and now I am looking for used ones to replace it & its much easier to find 05-07's then 04', but still just want to know if they are completely compatable or a little bit different (in length)
thanks,
kelly
KB'izzle is offline   Reply With Quote
Are 05-07 sti REAR axles the same length as 04 sti? KB'izzle Transmission (AT/MT) & Driveline 0 06-18-2009 12:57 AM
are 2.2 pistons and 2.5 pistons the same size as far as bore goes? azn2nr Built Motor Discussion 9 11-08-2006 06:53 PM
Are JDM sti axles the same as USDM sti axles? Capt Crunch Transmission (AT/MT) & Driveline 0 06-25-2006 02:34 PM
are 98-01 2.5rs fog lights, the same size as 02-03 wrx's?? 03boxer4 Interior & Exterior Modification 4 07-30-2004 09:30 PM
Are the painted side skirts the same size as the plastic ones that my car came with? RyanRock Interior & Exterior Modification 5 05-13-2004 06:33 PM
Message Board Statistics All times are GMT -4. The time now is 04:25 AM.
