Old 05-21-2009, 08:13 PM   #1
team trucha racing
Member#: 118484
04 sti RotatedGT35
wrb harman motive tunned
Default 04 sti hid headlights on 05 wrx?
what has to be done to get 04 sti hid headlights on a 05 wrx? is it plug and play? or do you have to do some wire modding and if so how hard is it? please help guys im selling my sti headlights to a kid with a wrx and need to give him a solid answer..
thanks... rob
team trucha racing is offline   Reply With Quote
Old 05-22-2009, 05:47 PM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
It's not plug and play, but not far from it. Please do a seach, as this has been disscuess 1000 times before...But since im bored, and only have 15 minutes of work left before the long weekend I will chime in.
There is nothing you need to do on your end to make things any easier other then possibly include the leveler switch from the dash, if you do a seach under my name, you will find a write up on how to DIY wire the leveler swithc that you can forward onto your customer.
He will need to either build, or buy a headligh wiring harness, this should include a relay that when activated by the stock lowbeam harness, will pull power directly from the battery, as to not overload the stock WRX harness.
Although this may not be as descrirpitive as you may have been looking for, like is stated earlier, if you do a search under my name, you will find all the threads you will need as i have done this swap in the past, and made some threads pertaining to it with pictures.
**EDIT**
Here is the info for the levler switch wiring: As far as the wire harness to power the ballasts, ANY quality HID wiring harness that has a relay and doesnt rely on the stock wiring (meaning it pulls the power directly from the battery) will work. These can be sourced anywhere from $10-$100 If i can find where i purchased mine, i will post that link as well. best of luck with the sale.
If you didnt get the plugs with your headlights, and cant find plugs for it, here are the pins for the USDM 6 pin (8pin with 2 dead pins levler switch)
if you need the schematic for the leveler system let me know i have it.
Switch Headlight
Pin Pin
SW0 - 7 1
SW1 - 6 2
SW2 - 3 3
SW3 - 4 4
+12V- 2 5 +12V
GND - 8 6 GND
skingfreak is offline   Reply With Quote
Old 05-22-2009, 09:03 PM   #3
team trucha racing
Member#: 118484
04 sti RotatedGT35
thanks bro i dont want to pull my leveler im just selling him the headlights and want to get them to turn on and off and get the high beams to work.
Old 05-23-2009, 07:02 PM   #4
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
High beams are P&P and the low's only require the harness like i stated the turn signals are PnP as well.
But why not inlucde the leveler switch? It does nothing for you without the STI headlights. Nothing at all. So it seems like your selling an incomplete set. But that is for you and him to decide. Just my .02
Old 05-25-2009, 04:03 PM   #5
team trucha racing
Member#: 118484
04 sti RotatedGT35
i sold these for dirt cheap but thanks for the info.
Old 05-25-2009, 08:38 PM   #6
antho!
Member#: 159057
2004 ts wagon
aspen white
hey rob, if you don't care about leveling, it's pretty easy, you have three options
1. buy the oem sti wiring harness from lightwerkz (easiest, safest, i did this and it works perfectly )
2. make your own wiring harness that draws power from your battery, and has inline fuses, and relays, etc. (saw some bug eye guys do this with their jdm/sti headlights, i'll post links if i find them again)
3. cut and splice the plugs to your current low beam wires (some say this works, but others say this could causes malfunctions with your wiring harness)
hope this helps, good luck, pm me if you have any more questions
antho! is offline   Reply With Quote
WTT 04/05 STi HID headlights for stock wrx headlights Project Barnie South East Region Private Classifieds 9 02-10-2011 11:44 PM
sti hid headlight on a 2002 wrx giuseppelosi Interior & Exterior Modification 2 12-05-2009 02:00 PM
04 sti cv joints on 05 wrx nickd05wrx Transmission (AT/MT) & Driveline 1 02-28-2007 06:18 PM
04 STi Shift Trim on 05 WRX Console? D-Speed 2.5 Interior & Exterior Modification 2 12-27-2005 12:12 PM
04 STI complete headlight and 05 cleared STI headlight housing + more SpoolinU Private 'For Sale' Classifieds 25 09-24-2005 09:09 PM
Message Board Statistics All times are GMT -4. The time now is 08:30 PM.
