Old 05-21-2009, 10:55 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default DeatschWerks 950cc Injectors?
I currently have a set of DW 850cc injectors installed in my car but I plan on upgrading my motor in the future and will surely need more fuel. Does anybody have experience with the DW 950cc injectors? I really dont want to totally redo my fuel system since I already have rails, lines, TGVs, etc wich are all setup for side feed injectors. Thanks.
dexterous is offline   Reply With Quote
Old 05-21-2009, 11:49 PM   #2
xxscaxx
Member#: 86459
2013 BRZ
pretty sure DW stopped making the 950's. unless they are like a special order or something or you buy them used from someone.
xxscaxx is offline   Reply With Quote
Old 05-21-2009, 11:55 PM   #3
STIBungy
Member#: 51684
06+wrx injectors flow about 950cc when modded.
STIBungy is online now   Reply With Quote
Old 05-22-2009, 12:11 AM   #4
socalLGT
Member#: 89752
08 STI
Side feed DW950 are a freak occurrence. Basically when DW has a large production run of injectors a very small percentage of the ones that should flow 850 end up freakishly flowing more. Those injectors are flow matched and grouped together for sale as "950's". For every couple hundred 850 injectors they might come up with one or two sets of 950's. So long story short they aren't exactly readily available. You just need to call DW and see if they have any available. I run a set in my car and they are fantastic.
socalLGT is offline   Reply With Quote
Old 05-22-2009, 11:24 AM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You could always up your static fuel pressure to get the extra flow.
Old 05-23-2009, 12:41 AM   #6
dexterous
Member#: 23553
2014 WRX - Daily
I actually have a new set of 950s that I purchased off a nasioc member. They included a specs sheet that shows ~950cc but for some reason I am skeptical of those numbers. I am contemplating sending them out for 3rd party confirmation. Does anybody think that confirmation is worth it or should I just trust DW?
Old 05-23-2009, 12:52 AM   #7
benw
Member#: 103320
2005 wingless
aspen white
DW doesn't mess around. That value is accurate!
benw is offline   Reply With Quote
Old 05-23-2009, 09:29 PM   #8
pekoso1
Member#: 168988
Is this true? ... Cuz i thought nobody makes side feed bigger than 850cc, I want to run E85 and i been looking for bigger side feed injectors but no luck.
I know that 07 Sti is top feed so i was looking into that as an option cuz with top feed injectors there is no problem getting bigger injectors.
If not true can someone then tell me how to do a top feed convertion on 04 Sti... Thanks
pekoso1 is offline   Reply With Quote
Old 12-29-2012, 11:53 PM   #9
Mordecai
Member#: 153673
Sorry to bring this post back from the dead - but I'm wondering if anyone can bring some more info about these injectors.
I bought a car w/these in and we're having some issues tuning them. Basically, the car will idle rich at times and learning fuel trims will be pulled -15%. AFR will sit anywhere from 13-14.5.
Are these injectors dw850ccs in all respects other than the fact that they just flow more than inspected? Has anyone else had any problems tuning these?
Mordecai is offline   Reply With Quote
950cc Injectors motoryder SCIC Private Classifieds 28 04-30-2010 11:51 AM
FS: Deatschwerks 565cc Injectors turboge SCIC Private Classifieds 11 10-23-2006 04:33 PM
FP16g, Deatschwerks 650cc injectors......brand new! DeKaP Engine/Power/Exhaust 24 10-15-2006 03:28 AM
Deatschwerks 565cc Injectors - Help Needed turboge Engine Management & Tuning 3 10-07-2006 03:15 PM
FP16G, deatschwerks 650cc injectors DeKaP Tri-State Area Private Classifieds 9 09-06-2006 09:34 PM
