Old 05-22-2009, 01:00 AM   #1
JohnJ
Member#: 186769
02 old wagon...
Default My 18g wagon...
I had my car tuned by Doug from Topspeed while he made a trip down to Sojax in Jacksonville. My tmic was holding me back a little. Doug tried hard to break the 300hp mark, but it was just heat soaking like crazy. I have to say I was pleased for all of about a day, but yet again the bug for more power has crept into my brain.
Final results were... 299.1whp 271.1wtq
Modlist...
Blouch TD05 18g^7cm
DW 750cc
TurboXS tmic
Walbro 255
K&N drop in filter
Stromung catless downpipe
Stromung catless midpipe
Cobb catback
Grimmspeed catless uppipe
Cobb APv2
Boost was set to 18psi, I'm still on the stock tranny. So I went a little conservative, but a new tranny is in the works.
So I'd like to ask for any advice for more power... Keep in mind this is my daily driver, never see's track time and I'd like to keep it on 93 pump gas. Eventually I might go rotated, but for now I want to make the most of what I've got. Any and all suggestions are welcome.
JohnJ is offline   Reply With Quote
Old 05-22-2009, 01:04 AM   #2
phlegmon
Member#: 26223
2016 Focus RS
1992 NSX twin turbo
race gas, meth, or E85 tune
phlegmon is offline   Reply With Quote
Old 05-22-2009, 01:05 AM   #3
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Can you elaborate on how your TMIC was holding you back? I have the same TMIC and havn't had any problems making over 300.
Dirtyhobo010 is offline   Reply With Quote
Old 05-22-2009, 01:09 AM   #4
lovethebugeye
Member#: 116929
2008 :shifty eyes:
I would definitely run meth. With the same setup tuned without meth and tuned with it ended up being around a 40whp difference, granted the tune without meth was pretty shoddy, it adds a nice kick in the pants.
lovethebugeye is offline   Reply With Quote
Old 05-22-2009, 01:14 AM   #5
JohnJ
Member#: 186769
02 old wagon...
Well the cooling at Sojax consisted of one small blower, ice and water spray. So it wasn't really getting reliable cooling. But after looking at the APS and Spearco tmic's, mine looks way small. Also this was on a DynoPack.
Old 05-22-2009, 02:40 AM   #6
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
heck turn the boost up the turbo should be more efficient, and blow cooler air
seanathanq83 is offline   Reply With Quote
Old 05-22-2009, 05:29 AM   #7
rico_q808
Member#: 155896
Chapter/Region: HIIC
2006 WrX
bLuE
I say turn the boost up as well, thats whats holding you back. Add some meth to that as well
rico_q808 is offline   Reply With Quote
Old 05-22-2009, 08:04 AM   #8
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^+2 on the meth
Run cooler make more power and keep your tmic
Old 05-22-2009, 11:28 AM   #9
JohnJ
Member#: 186769
02 old wagon...
I've tried looking at what boost levels are normally at with 18g's but searching doesn't yield a whole lot specifically. What's still considered a relative safe level?
As for meth I'm still undecided. I've looked and read for hours and hours about safety, reliability and all that, but the idea of another tank to fill and watch isn't sold on me yet.
Old 05-22-2009, 11:58 AM   #10
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
^when I was tuned on my 02 WRX with a similar turbo (blouch 18g 8cm^2) my boost was set at 20psi. And that was with the Hyperflow TMIC which I think is the same as the TurboXS. TMIC must have been heat soaked to shiet. Just go with a FMIC
Steve.804 is offline   Reply With Quote
Old 05-22-2009, 01:19 PM   #11
seanathanq83
Member#: 173241
i run 23 tapering to 21 on my 20g, on stock 205. i say turn it up to 20-21 this is alot better efficiency range for the turbo. you could run water injection that would keep it cooler, and would not really require much difference in the tune, and if you ever felt like it, add a little bit of meth in there and you are good to go
Old 05-22-2009, 01:52 PM   #12
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
i see you are still running the stock intake. that is what's more than likely holding you back, that 18g needs to breath!
mongoosaroo is offline   Reply With Quote
Old 05-22-2009, 02:53 PM   #13
JohnJ
Member#: 186769
02 old wagon...
^^^ Really? I was told by Doug to keep the stock box. I've heard many a horror stories related to shorty intakes. Any suggestions?
Old 05-22-2009, 02:59 PM   #14
03_Impreza_Al
Member#: 146606
That's crazy tq for a 2.0! Looks good.
03_Impreza_Al is offline   Reply With Quote
Old 05-22-2009, 03:32 PM   #15
turbocat
Member#: 120151
13 BRZ, 07 WRX
Wagon, 94 Land Cruiser
I was thinking the same thing...
Just try an intake, and see if your car wakes up a bit.
About your intercooler... My friends car, with a smaller turbo, at 22-23psi is making 328hp and 340ftlbs on pump, with only an STI TMIC, and he used to have a TXS TMIC. I'm thinking the IC isn't the restriction.
Just My$.02
turbocat is offline   Reply With Quote
Old 05-22-2009, 03:44 PM   #16
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Blah on 93 plus meth Topspeed has my stock EJ205 with 18g boosting 26 psi.
CoolRex is offline   Reply With Quote
Old 05-22-2009, 03:44 PM   #17
JohnJ
Member#: 186769
02 old wagon...
I'm able to pick up an APS tmic for cost, so I'm thinking of trying that. It's huge compared to the TurboXS. As for intakes, would a cai or one more like the cobb be better? Also a new inlet will be going on soon.
Thanks for the replys so far.
Old 05-22-2009, 03:46 PM   #18
JohnJ
Member#: 186769
02 old wagon...
If you don't mind me asking, what kind of numbers are you putting down?
Old 05-22-2009, 03:51 PM   #19
jason miller
Member#: 158313
2003 WRX
Just because you can get a tmic with a larger surface area, doesn't mean you will be doing much good. What splitter/shroud are you using? My txs tmic is still a little larger than the sti shroud, and anything larger would just be more area without air flowing through it...
jason miller is offline   Reply With Quote
Old 05-22-2009, 04:01 PM   #20
rico_q808
Member#: 155896
2006 WrX
bLuE
I say just take a few days of researching different things before you just start buying parts.
Old 05-22-2009, 04:26 PM   #21
207STi
Member#: 197062
1998 Swapped Impreza
black
If heat soak is your problem, then why is going FMIC not being considered? Am I the only one that thinks the benefits of a FMIC (VERY rare heatsoak), outweighs the shortcomings (lose a few hundred rpm in spool)? Just my 2 cents..
207STi is offline   Reply With Quote
Old 05-22-2009, 04:29 PM   #22
jason miller
Member#: 158313
2003 WRX
^^I didn't say that in my post, but I agree. The next logical step in my mind from txs tmic is a good fmic...
Old 05-22-2009, 04:49 PM   #23
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
350hp 340 tq on Topspeed's DynoJet which reads much lower than a Dynapack like you were tuned on.
Old 05-22-2009, 04:49 PM   #24
JohnJ
Member#: 186769
02 old wagon...
I have considered going with a fmic, spool was my only concern I guess. I know with a good tune I shouldn't see too much more lag, but I'll admit, I'm a spool sissy...
And I've done alot of research and reading for a long time, I'm just so back and forth sometimes. Believe me I've worn that search button up top to death.
Old 05-22-2009, 09:49 PM   #25
seanathanq83
Member#: 173241
i like the tmic for the stealthness, you should be making more on a high reading dyno like that, heck you should be getting close if not hitting 300 on a mustang dyno. but i say get a new turbo inlet, i have a aps inlet, and i love it. on a wrx it can be put in without the intake coming off, but the coupler is a little of a pain. i have kept the stock box though
P&L Motorsports Tuned 18g Wagon dr doom Proven Power Bragging 14 04-04-2008 07:41 PM
perrin turbo inlet hose does this fit around my 18g having hardest time Works Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-02-2004 09:42 PM
anyone want to put on my 18g? slaterdrew Texas Impreza Club Forum -- TXIC 9 06-29-2004 09:37 AM
Should I sell my 18g and a get a Green or wait till my motor is built? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-29-2004 03:01 PM
My current TS wagon, previous RS and my mom's wagon GS116 Member's Car Gallery 3 05-18-2001 11:15 AM
