Old 05-22-2009, 01:48 AM   #1
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Default Sti gauge cluster problems
There is actually no problems with the cluster but after i installed an 04 sti cluster in my 02 wrx my radio stopped working. Has anyone had this problem? I havnt checked the fuse yet so could that be a possibility? Any help would be appreciated. Thanks
crpwrx is offline   Reply With Quote
Old 05-22-2009, 02:28 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would say either a bad fuse or you pulled a connector loose going to the radio.
Old 05-22-2009, 07:57 AM   #3
zeroburnWRX
Member#: 209118
2006 STI
Default sti gauge problem
Hey man i just did this mod this weekend, and you have to pull out pin b28( should be yellow with green strip) it is a ground so every time you hook it up it will blow your radio fuse. (15amp fuse it should be). you don't have to cut the wire, i just used a small screw driver and pry it out. and used heat shrink strip on the end of it and then electrical tape for it. if you have any questions shoot me and email on here or at [email protected]. mine works perfect after i took that pin out.
Later
zeroburnWRX is offline   Reply With Quote
Old 05-22-2009, 01:09 PM   #4
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Damn thanks for the info brother. Gonna do this right now.
2005 STI Gauge Cluster Problems! anybody else seen this? Sebaruwrx Electrical & Lighting 1 11-09-2009 04:55 PM
Gauge lighting problem --- > MY00 GC8 with v5/v6 STi gauge cluster Anhdalai Interior & Exterior Modification 1 05-16-2007 01:00 AM
STi Gauge Cluster into a 2002 WRX, fuse problem MTR_Suby02 Newbies & FAQs 2 03-24-2007 09:32 PM
STi gauge cluster in MY02 problem... :( Speedo is off vipernj Interior & Exterior Modification 20 08-03-2006 10:17 AM
Another STI gauge cluster shorting problem thread tallicaguitar88 Electrical & Lighting 2 07-31-2006 02:01 AM
