Old 05-22-2009, 11:43 AM   #1
jayjay75
Member#: 85414
2004 WRX-AP Stage II
Default High RPMs at idle
I need some advice on a couple issues I'm having with my 04 WRX, mainly one issue. Sometimes when my car is at idle, my rpms hit between 2000 and 2500 rpms. This happens every so often out of no where. And at other times at idle, my rpms are normal. What could be causing this and what any suggestions on what i can get done to fix this? The other problem is my A/C. I had the A/C belt changed a couple months ago, but it was winter at the time and i didn't bother to turn on the A/C until yesterday when it was hot. It was blowing hot air when turned it on of the first time. Would the A/C belt being changed affect the A/C not blowing cold air anymore?
I have a Cobb Accessport Stage 2 currently installed.
PLEASE HELP ME!!
jayjay75 is offline   Reply With Quote
Old 05-22-2009, 11:49 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the cruise control cable may be too tight
Old 05-22-2009, 01:37 PM   #3
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
does the ac start to blow cold air if you leave it running for a long time or does it just never ever send cold air?
kbcr3 is offline   Reply With Quote
Old 05-22-2009, 01:45 PM   #4
jayjay75
Member#: 85414
No, it's not sending cold air at all...
Old 05-28-2009, 01:42 AM   #5
semper su
Member#: 211722
04 wrx
I have the same problem with my 04 wrx at stage 2 also sometimes when I go to shift and get off the gas and on the clutch my rpms will jump about 300-400 hundred before falling. Both of these issues happen at the same time for me. Wish I knew what it is.
semper su is offline   Reply With Quote
Old 05-28-2009, 01:46 AM   #6
n2oiroc
Member#: 141952
15 legacy 16 wrx
listen to this man. its easy and free to check. my friend had the same problem and the dealer charged him $500 and replaced the iac and didnt fix it. i loosened the cruise control cable and problem solved.
n2oiroc is offline   Reply With Quote
Old 05-30-2009, 05:03 PM   #7
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
interesting thanks
feint05 is offline   Reply With Quote
Low RPM at idle dpk777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-26-2007 12:43 PM
High EGT at Idle Nok's WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-17-2006 08:40 AM
Bouncing RPM at Idle...? Chigae Normally Aspirated Powertrain 10 08-02-2006 10:28 AM
RPMs at idle acting funny..? SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2004 01:06 AM
problem - fluctuating rpm at idle Jejunum Normally Aspirated Powertrain 12 03-30-2003 01:09 PM
