Old 05-22-2009, 01:00 PM   #1
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
Default Just replaced my front diff oil and now getting a grind in first
I just replaced my front diff gear oil with Motul 300 and i'm getting a grind if i try to put the car into first too quickly. for instance, if i'm stopped at a light and depress the clutch entirely and try to throw the car into first, i'll get a grind. if i depress the clutch, wait one full second, and throw the car into first, there's no grind. i'm also not getting a grind in ANY other gear. in fact, every other gear is shifting like butter!
the car only took 3 quarts of oil and that got it just above the "F" line on the dipstick. is that too much? is that what's causing the grind? do i just need to drain some oil or switch to the cocktail?
kbcr3 is offline   Reply With Quote
Old 05-22-2009, 06:46 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
drain a quart and put in a quart of Penzoil synchromesh
Old 05-26-2009, 04:37 PM   #3
kbcr3
Member#: 44170
2010 Forester XT
is having the level slightly above "F" bad? obviously, it's a dumb idea on the engine, but wasn't sure if it was terribly bad on the front gear.
Old 05-26-2009, 04:51 PM   #4
bige1919
Member#: 146333
If it's only slightly over the full mark I wouldn't worry about it. Anything more than half an inch or so over and you might want to drain some out to be safe.
bige1919 is offline   Reply With Quote
Old 05-26-2009, 05:19 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
I have found that the 5mt likes being just a bit over...rather than under by ANY
Old 05-29-2009, 03:32 PM   #6
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
+ one on the drain 1 qt and add 1 qt synchromesh. It's Silky smooth buttuh!
paintbing is offline   Reply With Quote
Old 05-29-2009, 08:25 PM   #7
hoffmanEstates
Member#: 122043
04 wagonier
psm
i get the same prob once in a blue moon. i run royal purple thou
hoffmanEstates is offline   Reply With Quote
Old 06-06-2009, 01:31 PM   #8
kbcr3
Member#: 44170
2010 Forester XT
it seems like the oil has kinda figured itself out as the grind is now only happening like once every other week. even then, it's not a hard grind. it's just a little "thunk. thunk." and that's it.
Old 06-07-2009, 12:00 PM   #9
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Did you change the oil? The decreasing 'thunk thunk' COULD mean you are rounding the edges of the dog teeth which = bad juju. Either the oil works or it doesn't. Did you ever drain 1 qt and add in 1 qt synchromesh?
Old 06-18-2009, 03:29 AM   #10
Rubr_Duky
Member#: 2159
2015 STi
Find Uncle Scotty's magic mix for Trans Fluid.
I used that, then changed back to regular stuff... found all kinds of things I couldn't do anymore. Changed back ASAP.
Rubr_Duky is offline   Reply With Quote
Just installed my RA 5 Speed. And now i have a problem Chandy69 Transmission (AT/MT) & Driveline 7 07-01-2007 02:33 PM
can i just replace my front rotors/pads? wrXiconZ Newbies & FAQs 16 04-23-2007 03:45 PM
Just changed my rear differential oil and noticed it was overfilled volkl23 Transmission (AT/MT) & Driveline 10 04-13-2005 04:09 PM
front diff/tranny and rear diff using different oils Asinine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-23-2004 09:43 PM
Change my tranny oil and now I get a tap/clank when I shift into 2nd fast 0260B4U Transmission (AT/MT) & Driveline 2 09-16-2003 06:49 PM
