Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 05-22-2009, 03:40 PM   #1
Harry
Member#: 23390
2010 WRX STI SE
Question Yokohama AX tire?
So, AX gurus, I have another stupid question about AX tires:
Background: Thanks to AI, I won two free Yokohama tires of my choice. I run a 2006 WRX wagon in DS, in the WDCR SCCA and AI clubs (Washington DC area, really hot summers ). 3rd year AX'ing but not really competitive. Ran last year on old RA-1 (235/40/17); this year, I started on used A6s but they are pretty worn out and useless in the rain. Rims are 7 x 17, 50 offset (thanks, Eduardo!) Only mods are 29mm FSB, still on stock struts. Max neg front camber (-1.1), with 1/16 toe out up front.
Talked to a Yokohama US guy who said that the new AD08 may be a better choice (aka faster) than their only DoT R-comp (A048), which he said was older technology. [I understand that their new R-comp, the A050, is not available in the US now and may not ever be. Certainly, didn't make the 2009 AX tire cutoff.]
Question: Should I get the AD08, which would be a great street tire, good AX tire in the rain and wear way slower than Hoosiers A6 or should I get the A048, which are older technology and slower than A6's, anyway?
I'm thinking about the AD08 in 245/40/17 for gearing, which should just clear my rear struts (darn narrow wagon!)
Thanks,
Harry
Harry is offline   Reply With Quote
Old 05-22-2009, 03:44 PM   #2
BrianGT
Member#: 75339
Yes... get the AD08 for autocrossing. I wouldn't run wider than 235/40-17 on your narrow wheels. I run 255/40-17 AD08s on my 17x9 wheels, and they are not wide enough
pics: http://www.briangt.com/gallery/bmw-tires
These tires are awesome, and IMO are a good bit better than the Dunlop StarSpec tires. The A048 might be a better track tire, but for autoX, the AD08 heats up quicker, and would be legal for running in Street Touring classes if you ever decide to move out of DS.
BrianGT is offline   Reply With Quote
Old 05-22-2009, 03:54 PM   #3
mla163
Member#: 104922
2013 BRZ
The AD08s are a great ST* tire, but won't be as competitive as R-comps in DS. They would make great summer tires or rain tires. But (I would imagine) a similarly prepared DS wrx on A048s would have a leg up on you.
You may also want to just buy regular old tires for the wrx or another car.
Or you can come over to STU and be outgunned like me.
mla163 is offline   Reply With Quote
Old 05-22-2009, 04:02 PM   #4
Chiketkd
Member#: 71634
In hibernation...
Harry you could get two AD08's in a popular size (e.g. 255/40/17 for the 2wd STX guys) and sell them. Then use the money towards a fresh set of Victoracers, RA-1's, or something more competitive like the V710, A6, etc.
Chiketkd is offline   Reply With Quote
Old 05-22-2009, 07:08 PM   #5
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Or a set of A048's in one of those Corvette sizes for maximum profit
Old 05-22-2009, 08:14 PM   #6
Harry
Member#: 23390
2010 WRX STI SE
Unhappy great
Just when I thought I had it narrowed down to two choices, the guru comes up with a third (better) choice. Not crazy about getting tires, betting on the come that I can sell them to some Honda guy, tho.
- Harry
Old 05-23-2009, 09:57 AM   #7
BrianGT
Member#: 75339
yeah, pick up a pair of 285/30-18 and sell them to the RWD STU guys
(BMW E46 M3 guys)
Old 07-10-2009, 09:42 AM   #8
Harry
Member#: 23390
2010 WRX STI SE
Thumbs up went with AD08's
Decided to wimp out and just get the AD08s. Picked them up this week from RT (Thanks, Sam & Paul!). And thanks again to AI for the two free tires. Consistency (slow) cup for the win!
A BIG thanks to NASIOCer who recommended only 235/40/17 vice the 245s I was thinking about. NO WAY the 245s would fit. There's about 1/4" clearance on the rear struts, on my 17 x7 E50 rims with the 235/40/17s. The stack of all four 235s measured 36 3/16, so section width is 9.05 for a 235 on a 7" rim.
Did a quick test drive last night to scrub off the mold release and to get a feel for them. The sidewalls seem a little more flexible than the used 225 A6's I used to run but them seem to stick pretty well. I'll try them out this weekend at the WDCR AX at FedEx
Any thoughts on starting AX pressures? I was thinking maybe 40F/35R and then check the chalk?
- Harry
Old 07-10-2009, 10:11 AM   #9
Butt Dyno
Member#: 17301
is the "dark side"
We were running something like 37/34 at the Pro, and they seemed pretty happy. But we have camber, so 40/35 sounds reasonable.
Old 07-10-2009, 01:29 PM   #10
Chiketkd
Member#: 71634
In hibernation...
+1 Those definitely sound like good starting pressures. I'd personally run the rear pressures higher for rotation.
Old 07-10-2009, 01:32 PM   #11
Harry
Member#: 23390
2010 WRX STI SE
Default higher?
Chike:
Do you mean higher than the front (i.e., above 40) of just higher than 35#?
- Harry
Old 07-10-2009, 01:37 PM   #12
Chiketkd
Member#: 71634
In hibernation...
Harry,
I'd personally run them higher than the fronts, at least 45psi. However, we have different driving styles. My advice, try the 40F/35R for this event and start to 'feel out' these new tires. If you find the car pushing in the slower stuff, maybe try even pressures (F&R) at the next event and go from there.
Old 07-10-2009, 05:43 PM   #13
Harry
Member#: 23390
2010 WRX STI SE
Talking pix
Some more spam:
Stack of fun (and $$):
It's hardly Mini-Stompy but probably can't go any wider on the wagon:
Old 02-24-2011, 08:16 PM   #14
jutes85
Member#: 127232
E92 M3
98' Foz
bumping this up.
I'm trying to decide if its worth getting the A048's as a dedicated autox tire and run something less extreme for the street, e.i. FK452's, Ecsta's, etc. Right now the plan is to get the AD08's and pull double duty on them, but I don't know what is more cost effective - cheaper in the long run. Both sizes will be in 295/30/18.
jutes85 is offline   Reply With Quote
Old 03-01-2011, 07:42 PM   #15
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Noted....since I'll be on your old tires this season
irish44j is offline   Reply With Quote
FS: Track/AX tires - 225/45-17 Hoosier GACs, Kuhmo Victoracer 225/45-17, 225/50-16 jpmarotta Wheels/Tires 8 04-11-2011 10:55 AM
Stock Wheels, Hankook AX Tires george3 Wheels/Tires 5 07-15-2008 06:40 AM
FS: Yok AX Tires,24mm Whiteline FSB,NOS Perry Trice TXIC Private Classifieds 0 07-26-2006 10:23 PM
GT wheels and Ax tires 4 sale/delivery at Richmond Va./VMP autocrosses Richard A. Mid Atlantic Impreza Club -- MAIC 7 03-14-2001 06:29 AM
What's the best 17" STS Ax tire? Richard A. Brakes, Steering & Suspension 6 02-22-2001 07:02 PM
