Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Closed Thread
Old 07-24-2012, 03:39 PM   #351
JNA Performance
Vendor Sales Rating: (82)
Member#: 184966
---- Visit Us @ ----
www.jnaperformance.com
__________________
LET US MATCH OR BEAT ANY PUBLIC ADVERTISED PRICE. PM US TODAY.
paypal:
Check Us Out On FACEBOOK
Customer Review Thread:
JNA Performance is offline
Old 07-25-2012, 10:26 AM   #352
JNA Performance
Member#: 184966
Looking to make some power? Look no further, JNA Performance is setting you up with nothing but the best when it comes to turbo chargers. We now carry popular brands such as Forced Performance-ATP-Blouch-IHI-PERRIN. Let us make you the perfect power pack that fits your power goals, from full stage IIII kits to turbo and injector packages. Weíre here to help; with knowledge from a name you can trust, let JNA be your number 1 online shop!
Let JNA Make The Perfect Package For You!
Forced Performance
The new TD05-68HTA is FP's successor to the standard MHI 18G turbo and utilizes Hydraulic Turbine Assisted (HTA) compressor technology, allowing the 68HTA to operate with less backpressure and lower compressor outlet temperatures to maximize low and mid-range rpm boost response. This means that the 68HTA compressor is capable of pushing a max volume of 47lb/min while still outspooling the standard TD05-18G. The 68GTA TD05 (2.4 inch inlet) compressor housing is coupled with a 7cm exhaust housing, designed for the best compromise between top end power and boost response. The TD05-68HTA uses an internal wastegate, includes an 8psi upgraded wastegate actuator and is intended to give the best performance when tuned between 18-28psi.
The TD05 68HTA is a true 350whp turbo with a noticeable but generally tolerable lag increase on a 2.0 WRX. The 68HTA is a good 'medium' sized turbo option for 2.5 WRX and STi models. You can expect the FP 68HTA to make between 320-360whp when tuned with proper supporting modifications
FP RED
There's not much to write about the FP Red Turbo for the WRX & STi, as most of the information on it is top-secret from Forced Performance. The FP Red is a huge Mitsubishi/Garret hybrid WRX & STi turbo capable of making 500+ hp at the wheels. However, although the FP Red has OEM-type Subaru flanging, this is not a simple bolt-on and go turbo -- the 3" inlet requires a Perrin inlet hose and removal of the tumbler generator valves. To reach the FP Red's full potential, extensive tuning and supporting modifications are required.
The standard configuration FP Red uses a Subaru type water cooled bearing housing with both water connections on the same side of the CHRA. The thread specifications for the wet housing are as follows: Oil inlet - 10mm x 1.5mm, Water in/out 14mm x 1.5 (same side). 30 psi appears to be the limit of the FP Red's internal wastegate. This turbo makes most of its power at high boost on race gas, while it is capable of producing high power numbers, it is laggy.
IHI
IHI turbos are a direct bolt-on for the 02-07 WRX utilizing the factory mounting points and attaching to the factory oil and coolant lines. Although these are a great upgrade for a 2.0L WRX, any 2.5L WRX should be considering some of the larger options as the power gains from the IHI turbos will be minimal (The VF39 is the OEM 04-06 STi turbo, the VF43 is stock 2007 STi turbo, and the VF48 is the 08 STi turbo so they are not upgrades for these cars).
IHI VF43: The IHI VF43 comes stock on the 2007 STi. It has almost identical features of the VF39 with a thrust bearing and a P18 exhaust housing, but the wastegate opening is larger to relieve boost creep issues. The VF43 is capable of 290 whp* on the EJ20.
IHI VF48: The IHI VF48 comes stock on the 2008 STI
ATP
ATP's range of bolt-on Garret turbos are designed to provide the performance of a dual ball-bearing turbocharger with the convenience of a stock-location turbo. The ATP WRX & STi turbos easily install in place of the stock journal bearing turbo, due to the high-flowing GT-inspired ATP WRX & STi exhaust housing and a series of custom engineered components built to suit the installation
In addition, ATP reccomends a higher flowing 3" turbo inlet, like the Perrin, Agency Power or APS. If you must use a stock-sized inlet, you will need to source a 2.4" to 3" reduction coupler, as the ATP turbos have a 3" inlet.We recommend using a matching-sized 3" inlet for minimal restriction, since GT turbos thrive with minimal inlet obstruction. ATP's tests have shown that these turbos, when used with the stock sized 2.4" inlet, produce significantly less power than when used with the 3" inlet. When coupled with a 3" downpipe, the 3" inlet promotes faster spool, and higher power numbers with less pressure at the manifold.
GT2860RS:
GT3071R:
GT3076R:
__________________
paypal:
Old 07-26-2012, 03:13 PM   #353
JNA Performance
Member#: 184966
JNA Performance is now an authorized dealer for BC Coilovers!! This month we are offering FREE SHIPPING on all coilovers ordered.
FREE SHIPPING on ALL orders this Month!
Sale Price $999!!!!
BR's IN STOCK
Sale Price $1225!!!!
Sale Price $1750!!!!
JNA Performance suspension sale!
Donít get caught at stock ride height! TEIN coilovers and lowering springs READY TO SHIP!!
__________________
paypal:
Old 07-27-2012, 10:16 AM   #354
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 07-28-2012, 11:47 AM   #355
JNA Performance
Member#: 184966
__________________
paypal:
Old 07-30-2012, 10:17 AM   #356
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 07-30-2012, 03:40 PM   #357
JNA Performance
Member#: 184966
Forced Performance
FP RED
IHI
ATP
GT2860RS:
GT3071R:
GT3076R:
__________________
paypal:
Old 07-31-2012, 10:09 AM   #358
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 07-31-2012, 03:41 PM   #359
JNA Performance
Member#: 184966
Let us HOOK you up!
Looking for a certain part? PM us and let us help
__________________
paypal:
Old 08-01-2012, 10:21 AM   #360
JNA Performance
Member#: 184966
Check out PERRINís 22mm and 25mm front and rear sway bars, endlinks and stout mounts! Want to create a package? PM us for details!!!
Front Sway Bar
Rear Sway Bar
Stout Mounts
Front and Rear Endlinks
Hotchkis Endlink Sets for 02-12 WRX and STI
Hotchkis Street & Competition Swaybar Sets for02-12 WRX & STI
__________________
paypal:
Old 08-01-2012, 04:17 PM   #361
JNA Performance
Member#: 184966
__________________
paypal:
Old 08-02-2012, 10:06 AM   #362
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-02-2012, 03:37 PM   #363
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-03-2012, 10:32 AM   #364
JNA Performance
Member#: 184966
JNA/Walbro Fuel Pump Adapter For 05-09 Legacy, 08+ WRX/STI
Adapter to Secure Your Walbro Fuel Pump to the Fuel Pump Basket found in your 05-09 Legacy, and 08+ WRX/STI. Many people perform the Walbro Fuel Pump mod but unfortunatey there is no way to secure the walbro to the basket leaving it unsafe and loose in the OEM fuel pump basket. This adapter securely mounts the pump to the basket making it a secure and much safer fit.
CNC Billet Aluminum
GoodYear Emission Control Fuel Line SAE30R7
Stainless Steel Hardware
MADE IN THE USA!!
NOTE* This is used for off road use only. This adapter is used to secure the pump to the OEM basket, and all other modifications to fit the walbro fuel pump are still needed for proper fitment.
WAS $59.99 NOW ONLY $39 (ONLY FOR A LIMITED TIME)
Add A Walbro Fuel Pump when purchasing our adapter for only $75
Purchase Yours Today:http://www.jnaperformance.com/index....product_id=881
__________________
paypal:
Old 08-03-2012, 04:14 PM   #365
JNA Performance
Member#: 184966
__________________
paypal:
Old 08-04-2012, 11:35 AM   #366
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-06-2012, 10:11 AM   #367
JNA Performance
Member#: 184966
Front Sway Bar
Rear Sway Bar
Stout Mounts
Hotchkis Endlink Sets for 02-07 WRX and STI
Hotchkis Street & Competition Swaybar Sets for02-07 WRX & STI
__________________
paypal:
Old 08-06-2012, 03:36 PM   #368
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-07-2012, 10:05 AM   #369
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-07-2012, 04:38 PM   #370
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Old 08-08-2012, 09:38 AM   #371
JNA Performance
Member#: 184966
HIGH PERFORMANCE STAINLESS STEEL CATBACK EXHAUST
NO TAPER, FULL 3" EXHAUST SYSTEM
FLAT FLANGE
STEALTH LOW PROFILE LOOK
GREAT SOUND
$2XX
02-07 WRX/STI
FULL 3 Inch Design
T-304 Stainless Steel
Stealth Catback:
-Ceramic Coating Rated up to 2000 Degrees.-
http://www.jnaperformance.com/index....product_id=967
__________________
paypal:
Old 08-08-2012, 04:53 PM   #372
JNA Performance
Member#: 184966
FLAT FLANGE
GREAT SOUND
$2XX
02-07 WRX/STI
FULL 3 Inch Design
Stealth Catback:
__________________
paypal:
Old 08-09-2012, 09:55 AM   #373
JNA Performance
Member#: 184966
FLAT FLANGE
GREAT SOUND
$2XX
02-07 WRX/STI
FULL 3 Inch Design
Stealth Catback:
__________________
paypal:
Old 08-09-2012, 03:31 PM   #374
JNA Performance
Member#: 184966
Powder Coated To Perfect!
Pink-White-Stealth Black-Silver-Blue. Limited quantities so hurry up and grab a set or pre-pay on the next batch!
$69 Picked up.
Red is the factory color and is regular price.
High Performance Catback Exhaust for 08-11 WRX/STI-Sedan
*Removable silencers, no tacky looking multi color tips
*3 inch's for the most flow possible (tapers to 2.5 at the y section)
*Made of 304 stainless steel
*Amplifies your boxers natural sound
*Less restriction, more power!
*Fitment: 08-11 wrx sedan, 2011+ sti sedan
MSRP: $450
SALE: $3xx.00
High Performance Catback Exhaust for 08+ WRX-Hatch
*Full 3" stainless steel piping
*Better throttle response and more power
*Sleek muffler is subtle yet will still turn heads
*Fully mirror polished finish
MSRP: $450
SALE: $3xx.00
__________________
paypal:
Old 08-10-2012, 09:43 AM   #375
JNA Performance
Member#: 184966
Sale Price $999!!!!
BR's IN STOCK
__________________
paypal:
Closed Thread
Garage sale: springs, sti catback, wrx hoodscoop, and more nkx MAIC Private Classifieds 42 07-03-2008 01:36 AM
GI: Invidia catback, dp, td04, and more i50caL MWSOC Private Classifieds 3 05-04-2007 06:48 PM
NNJ: TurboXS RFL catback, NX Ntercooler system, more raykwok Private 'For Sale' Classifieds 36 01-11-2005 12:07 AM
FS: So Cal - Catback, C/F Hood + more!!! Nodnero Private 'For Sale' Classifieds 23 08-03-2004 02:13 PM
CAI and catback so far, need more WorldRallyRedneck Normally Aspirated Powertrain 5 11-05-2002 06:49 PM
