Old 04-24-2002, 04:19 AM   #26
adamsrs
Member#: 3768
Jeremy, Im guessing its either a bank of injectors shorting out, or the timing. Im gonna check those first!
adamsrs
adamsrs is offline   Reply With Quote
Old 04-24-2002, 04:42 AM   #27
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
adamsrs
sounds like the best idea to me.
jeremy
Old 04-30-2002, 10:09 PM   #28
adamsrs
Member#: 3768
well after talking to jeremy I realized that i need to put new Gaskets in between my throttle body and manifold, and in between my Manifold and heads! Any one else have any ideas?
adamsrs
Old 05-01-2002, 03:08 AM   #29
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
huh, for some reason I have not gotten any PM's or emails from you. I would not purposly blow you off. weird.
ANyway, I did the same swap as you and like Aaron said, I had no problems like the ones you are mentioning. It definetly sounds like some sort of injector or timing problem. The cam sprockets have so many damn marks on them it's hard to figure out which one means what. make sure you are using the correct ones. A long time ago (about 6 months or so) I asked how many teeth go between cam gears and the crank gear and got a response. I don;t recall what it was but it is in here somewhere.
I would try swapping the two left injectors with the two right injectors and seeing what happens. I doubt it is a problem with the injectors but at this point you want to try to eliminate anything you can.
I didn;t see your post about blowing up your engine but if you did, I would 100% check to make sure you didn;t bend a valve. a bent intake valve can definetly cause that problem.
Even if you blow up only one piston, the shrapnel loves to go out the intake valve and bounce around in the manifold and end up in another piston. To get there, it has to go by the intake valve and a lot of times gets hit by it and bends it. Just last months I saw this happen on a smallblock chevy. one dropped valve destroyed the entire engine because of shrapnel getting into other cylinders.
anyway, keep us updated and if you have any questions, email me at swannie@imap3.asu.edu I have gotten emails from other people through this websites "email user" funstion so try again.
Eric
Eric SS is offline   Reply With Quote
Old 05-01-2002, 03:10 AM   #30
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
One more thing, from what I gather, the compression on the EJ22T with SOHC EJ25 heads is closser to 9.0:1 than 8.0:1 but no one has been able to confirm that that i know of. But, regardless, compression wouldn;t have anything to do with your problem.
Eric
Old 05-01-2002, 03:32 AM   #31
adamsrs
Member#: 3768
Thanks for finally getting in touch with me! i did bend all the valves in the 4th cylinder. I took it to get redone. They told me tat they vacuum tested it. So that shouldnt be the problem! But i'll check! Cna you please INSTANT message me? I would LOVE to talk to you in real time!
adamsrs
Old 05-01-2002, 01:56 PM   #32
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Actually the compression ratio for a 2.2T with SOHC heads and MY00 SOHC head gaskets has been done...
Wac did it a little while ago. See his homepage for details.
Fitz
Fitz is offline   Reply With Quote
Old 05-01-2002, 02:01 PM   #33
adamsrs
Member#: 3768
What si that website? And was it 9.0:1 or 8.0:1 ???
adamsrs
Old 05-06-2002, 02:41 AM   #34
adamsrs
Member#: 3768
I replaced my intalke manifold gaskets and throttle body gaskets. No difference. This next weeking I am gonna do a leak down and Compression test, and try and test the injectors to see if they are shorting out, or clogged. Also I am gonna replace the plugs to see if that makes any difference! Any other ideas?
adamsrs
Old 05-06-2002, 04:43 AM   #35
adamsrs
Member#: 3768
Also my Blitz Boost Gauge USED to read -54 at idle before my block swap, and now it reads a fluctualting 28-33 at idle. Is the lower compression casuing this altered Vacuum?
adamsrs
Old 05-13-2002, 02:56 PM   #36
adamsrs
Member#: 3768
So this weekend i tried to install an uppipe. It didnt fit right, so i put back the stock one. Now my car wont even START!
adamsrs
Old 05-13-2002, 04:17 PM   #37
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
that sucks... Hmm it'll be a while before I'm in far enough with my project to help you.. Good luck.
Are you running a stand alone Engine management system like TEC or anything or is all done on stock ECU and piggy backs?
Jon
omahasubaru is offline   Reply With Quote
Old 05-13-2002, 04:33 PM   #38
adamsrs
Member#: 3768
Stock ECU with JC Sports TC2
adamsrs
Old 05-14-2002, 10:28 AM   #39
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Yeah I can see that being a bit of a problem when you change the bottom end and lower compression.
What was the fitment problem you had with the up-pipe??
Jon
Old 05-14-2002, 02:30 PM   #40
adamsrs
Member#: 3768
The Legacy turbo uppipe is SLIGHTY different than the PDE WRX uppipe. The PDE one was about 1/4" shorter thus causing the turbo to hit the manifold and tranny. Oh well! it is still a great peice to LOOK AT!
adamsrs
Old 05-20-2002, 12:06 AM   #41
adamsrs
Member#: 3768
HEY! It runs now! My battery had dies and i would try to start it and it was just filling the cyliders with Fuel adn snuffing out the spark....I checked for spark, CHECK....I checked for Injector pulse...CHECK....I checked for Intake blockage, CLEAR....I pivoted my knock sensor so it wouldnt hit my coolant channel anymore...CHECK....WHat is my idle fuel pressure supposed to be at? I have it it 35 psi right now! It was at friggin 42 before!!!!!! WAY TOO MUCH! I need to adjust the valve lash cuz it is WAY loud! and i need to still fix an exhaust leak. BESIDES that i think im Ready to go! Thanks to all that have helped! You are worth your weight in gold! While it is not fixed competely it is DRIVABLE to get me to work etc...over time i will figure it all out! EVERYONE who offered insight, YOU Are great!
adamsrs
Parting out thread, interior, exterior, badges, engine, more. *merged threads* 1QCKWGN NWIC Private Classifieds 57 11-19-2008 02:07 PM
help, still misfiring **merged threads** snowmachine Normally Aspirated Powertrain 15 08-25-2005 07:21 PM
Lethargicman sighted **merged threads** psaeko Southern California Impreza Club Forum -- SCIC 7 03-11-2002 08:11 PM
Philly Region Times & Pics Merged thread speedrkj Tri-State Area Forum 62 02-12-2002 08:55 AM
Why I don't like 1 merged thread per rally ninrex Motorsports 11 02-05-2002 09:52 PM
