Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-24-2009, 03:46 PM   #1
Banner
Member#: 116138
2013 BRZ
Default CV joint issues? Anyone had these?
My right front CV joint appears to be going on my 06 NA Baja. This car ONLY has 33,900 miles on it! (Yes, it's not my daily driver). I want to take it in and get the dealer to fix it, because obviously it is a manufacturer defect (Of course going to the dealer means I miss a day of work, they're no where near my job).
Needless to say, I'm not thrilled.
Has anyone else had this problem?
Banner is offline   Reply With Quote
Old 05-25-2009, 01:19 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
No no CV issues yet thankfully...
Isnt your dealer open saturday? (or whatever day you have off that isnt a sunday?)
Flowmastered87GL is offline   Reply With Quote
Old 05-25-2009, 10:59 AM   #3
Banner
Member#: 116138
2013 BRZ
I'm not sure if they're open Saturdays (the service department at least). Sometimes they are, but last time I checked they were closed Saturdays. Also I don't know if I want to be without the car for an entire week (as when they were open Saturdays, it was only like a half day, so I'd probably have to drop it off).
Getting this fixed is going to be a pain.
Old 05-25-2009, 11:27 AM   #4
twheats1
Member#: 147722
2004 Baja Turbo
00 R 1100RS
^It shouldn't take an entire day to change out a CV joint. (just installed a re-manufactured axle in my 04., it took a little over an hour) If your dealer is open half day on Saturdays that would be plenty of time for them to do it. (as long as they have the parts in stock)
twheats1 is offline   Reply With Quote
Old 05-25-2009, 02:31 PM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
ya if it takes too weeks fine... if the part is not in stock let them look at it, see its bad, order it and install it next week.
(and you have the car for the week between them looking at it and installing it)
Old 05-25-2009, 08:56 PM   #6
Benhart21
Member#: 149617
When you set up your appointment to have it fixed just have them give you a loaner car in the mean time. A decent dealer will have a small fleet of loaner cars for situations just like this.
Benhart21 is offline   Reply With Quote
Old 05-25-2009, 09:59 PM   #7
BajaGuy68
Member#: 127720
2012 Impreza Premium
Ice Silver Subie
When I had my 06' NA Baja, I had problems with the CV boots leaking grease. The dealership replaced the passenger side half-shaft(inner one) and six months later they replaced the drivers side one as well. I traded that one in for an 06' Turbo Baja and so far at 22K miles, no problems. It makes me wonder if that "quirk" is contained to the NA Baja's alone.
BajaGuy68 is offline   Reply With Quote
Old 05-29-2009, 05:16 PM   #8
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
My '03 NA passenger side one was replaced before the warrenty was up as well. dealer said it was common.
braveit1 is offline   Reply With Quote
Old 05-29-2009, 07:24 PM   #9
02BluWRX
Member#: 17924
2008 Prius
Mine is an 03 and I just had the passenger side replaced as it is near the exhaust manifold so the rubber was going. The other is getting there now and I just hit the 100,000 mark last week.
02BluWRX is offline   Reply With Quote
Old 06-02-2009, 10:16 AM   #10
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
All FWD and AWD vehicles regardless of make will have this problem. The reason is that rubber boot that covers the CV joint which gets road dirt and debris is also sitting below an engine that is a few hundred degrees and an exhaust(right side). That will cause the boots to dry out and crack, thus leading to splitting open.
I have seen 2 Subaru's where this happened within the first 36,000 miles. The norm is around 70k and higher.
blackfang is offline   Reply With Quote
Old 06-04-2009, 07:33 AM   #11
BajaGuy68
Member#: 127720
Ice Silver Subie
My first CV joint boot was replaced around 12k and the other at 15k. I think its the way they are "clamped on" from the factory. The dealership replaced the whole CV joint on both sides because my car was under warranty and it was easier.....according to their mechanic.
Old 06-07-2009, 03:43 PM   #12
Geffr1
Member#: 147375
2005 Baja
Atlantic pearl blue
Front passenger side went out--out of warranty. Dealer price $600-700. $60 for a rebuilt assembly and 2 hrs at the local tire shop got 'er done.
Geffr1 is offline   Reply With Quote
Old 08-26-2009, 09:34 AM   #13
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
I just replaced my Passesger side boot I cought it just after she ripped. we cleaned and inspected the joint it look good and we put it all back together..
holland_patrick is offline   Reply With Quote
Old 08-26-2009, 10:38 AM   #14
holland_patrick
Member#: 72014
05 Baja gone
Old 08-26-2009, 11:54 AM   #15
skullnbaja
Member#: 220083
2003 Baja Sport
I actually just took my 03 Baja to the dealer yesterday to replace the driver's side front axle and CV joint, only took them about two hours to fix. My car has 87k miles on it, but now I need the front passenger bearing replaced, that's a costly problem..
skullnbaja is offline   Reply With Quote
CV Joint Issues Thrasher722 Factory 2.0L Turbo Powertrain 7 12-22-2009 06:29 PM
Damn CV joint on a 2009 wrx...anyone have issues? Super_HKS Brakes, Steering & Suspension 4 10-27-2009 10:41 PM
anyone had these speakers? Kanchou Car Audio, Video & Security 13 02-25-2004 02:13 PM
anyone here capable of swapping out struts and cv joints on an 88 prelude? jmott Texas Impreza Club Forum -- TXIC 2 02-24-2003 12:22 PM
Recall ? Anyone who had the wrong grease in the CV joint. Sportback New England Impreza Club Forum -- NESIC 5 12-05-2000 03:32 PM
Message Board Statistics All times are GMT -4. The time now is 09:17 AM.
