Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 12-17-2000, 10:50 PM   #1
WRX-1977
Member#: 3282
2006 Mazda 6s GS 5dr
Glacier Silver Metallic
Post Subaru routine maintenance ????
I'm new to the world of Subies..but I definitely have the "fever". I have always owned Hondas/Acuras and I'm used to their maintanence schedules, and associated costs. I know SOA recommends that you replace the timing belt every 60k miles. Do they also suggest replacing the water pump at the same time..as in a Honda/Acura? Also, what's the approx. cost for a timing belt replacement. I assume that with a flat boxer engine..the timing belt is right up front....and easier to reach, hence a lower cost. Also..does SOA recommend valve adjustments...etc?? Rumor has it that the WRX will have a timing chain..a definite in my eyes. Any and all info would be thoroughly appreciated....
WRX-1977 is offline   Reply With Quote
Old 12-18-2000, 04:26 AM   #2
KC
Member#: 442
13 Crosstrek XV
00 S2000
Post
As far as I know, the 2.5RS doesn't get a new timing belt until 100K.
Also...according to here: http://www.geocities.com/clintsc9/ImpSpecs/ImpP05.jpg
The New WRX gets a belt also. (It's down the bottom) Changing required according to this documentation at 100,000 Kms (Roughly 60,000 Mi).
You can whet your appetite for the new WRX here: http://www.geocities.com/clintsc9/Im...mpreza2001.htm
It's the European version, but it shouldn't be that mush different than here.
--KC
[This message has been edited by KC (edited December 18, 2000).]
KC is offline   Reply With Quote
Old 12-19-2000, 07:22 PM   #3
Pilot
Member#: 513
Post
PhaseII SOHC 2.5 liter motors should have their valves adjusted at 120K miles.
Pilot is offline   Reply With Quote
Old 12-19-2000, 09:21 PM   #4
WRX-1977
Member#: 3282
Post
What's the approx cost to get the timing belt replaced....and what about the water pump? Does SOA suggest replacing the water pump at the same time as the timing belt...or do you just wait for it to go??
routine maintenence MYnewWRX Service & Maintenance 9 12-14-2006 11:50 PM
Garage Near Nampa For Routine Maintenance OnTheGas North West Impreza Club Forum -- NWIC 0 11-19-2005 12:15 AM
NASIOC.com will be down for routine maintenance from 4:30 - 4:40am EST 24 Off-Topic 3 10-07-2005 04:57 AM
96 Legacy Outback - Routine maintenance parts rogue Legacy Forum 6 03-08-2004 03:00 PM
question on routine maintenance? spike Service & Maintenance 4 04-27-2003 01:02 PM
