Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 05-24-2009, 11:20 PM   #1
Scout255
Member#: 173115
Default Autocross Classing - Question on Downpipes
Hello All,
Currently I have a stock 06 STI that I would like to go to Stage 2. However, I also want to partake in a few local autocross events and would like to purchase a downpipe that is legal under the STU Autocross rules. I know that it needs a Cat and that it must not cause a CEL. However, I've searched a lot and have not found too much info on a good DP to use to get this end result. I plan on mating the DP up to the stock STI muffler.
Do any of you have suggestions on a good DP to go with? I've heard that the Perrin one is good, but have not seen too many others mentioned (other than a custum one made with an APS turboback exhaust, but I would prefer to go with an "off the shelf" solution).
Thank you in advance.
Scout255
Scout255 is offline   Reply With Quote
Old 05-24-2009, 11:51 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
A typical stage 2 tune raises boost, which is not legal in STU.
For a STU legal DP- SEARCH! There have been many threads on this subject.
speedyHAM is offline   Reply With Quote
Old 05-25-2009, 10:16 AM   #3
Scout255
Member#: 173115
I have searched and have not located any mention of specific downpipes in the autocross section.
This fellow: http://forums.nasioc.com/forums/show...light=Downpipe
Has made his own custom one (which I mentioend I did not want to do)
In this thread
http://forums.nasioc.com/forums/show...wnpipe&page=38
there are a few listed, such as the Helix/Perrin (which I also mentioned in my post).
In this thread people are posting their various experiences, however, most are dated from 2007 when the rule was put in place. Some later posted that their DP that did work originally no longer worked. As such, I was hopeing that someone could suggest something that has worked for them over the long haul.
I am also aware that changeing the boost mapping is illigal. I will have a STU legal map made, as well as a normal stage 2 map. I just want a downpipe that would not disqualify me from STU.
In short: I have searched, both here and on IWSTI and was looking for further input.
Old 05-25-2009, 12:22 PM   #4
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
There is a rule being considered that will make having any illegal map illegal. It was proposed in the May Fastrack.
Considering how anti-turbo, anti-AWD the SCCA establishment has become, this proposal will very likely go through.
So, the DP may be inconsequential.
Karen
CamaroFS34 is offline   Reply With Quote
Old 05-25-2009, 01:02 PM   #5
tuskenraider
Member#: 65699
15 WRX
WR Blue
The should change the ST designation to SP for "suspension mod only class".
tuskenraider is offline   Reply With Quote
Old 05-25-2009, 02:12 PM   #6
Scout255
Member#: 173115
Karen
Ah, did not see that. Thank you very much for shareing.
Hopefully this will not affect me, as I will be running open source and can flash it at home prior to getting to the track. Although it is a huge PITA.....
Old 05-27-2009, 06:55 PM   #7
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
it's not that big a PITA. I reflash mine before most races. the pita part is switching fuels (I run e85 for racing, 91 octane for long drives). I've gotten good at unhooking the fuel return line...
xcdhridr is offline   Reply With Quote
Autocross classing question Danny Boy Motorsports 1 07-16-2007 08:18 PM
Questions on downpipes euroauto Forester Forum 12 02-14-2006 11:28 PM
newb question on downpipe oooggss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-24-2003 11:55 AM
Autocross class question JGard New England Impreza Club Forum -- NESIC 4 04-15-2002 11:16 AM
2 Quick Autocross class questions bongo Motorsports 12 12-07-2001 09:41 PM
