Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 05-25-2009, 10:30 AM   #1
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE, Whiteline, H&R & KW suspension in stock
Racecomp Engineering "Regular Guy" Functional Lowering Springs for GR
Chassis 2008+ Subaru Impreza STI
Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI. Incorporating the knowledge gained from designing a growing list of suspension and brake performance parts for the true track day and autocross enthusiast, Racecomp Engineering is proud to announce the latest addition to their line up. The Regular Guy Functional Lowering Springs for the 2008+ Subaru Impreza
STI are designed as the ultimate performance spring upgrade for the newly redesigned GR chassis.
Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the extremely limited suspension travel available. Shorter bumpstops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street.
Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a new performance spring has been produced that adds to available bump travel, matches the excellent OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
Continuing the “Regular Guy” theme from previous Racecomp designs, the springs are colored black for a low key look. Coupled with the minimal drop, most people would be hard pressed to find anything different from stock….until the road curves.
320 lb/in front and rear
Shortened bump stops included front and rear (12mm shorter front, 18mm shorter rear)
Introductory Pricing-$425
Whiteline Suspension
'08+ STI and WRX
Front/rear swaybars
BSF30Z-22mm adj. frt
BSF30XZ-24mm adj. frt
BSF39Z-22mm adj. frt
BSF39XZ-24mm adj. frt
BSR49Z-20mm adj. rr
BSR49XZ-22mm adj. rr
Front and rear endlinks
KLC39-front adj.
KLC066-rear adj.
Front upper strutbars and lower stressbars
Front roll center kits, anti-lift kits and rack bushings
Rear camber kit, diff lock and subframe bushings
04+ STi, 02+WRX, 2.5I sedan and wagon
Front/rear swaybars
02-03 2.5I
BSF10-22mm frt.
BSF11-22mm-wagon frt
BSR33XZ-24mm rr
02-03 WRX and wagon
BSF12Z-22mm adj. frt
BSF33XZ-24mm adj. frt
BSR33XZ-24mm adj. rr
BSF36XZ-24mm adj. frt
BSR37XZ-24mm adj. rr
Front anti-lift kits, rack bushings, subframe lock bolts, outrigger bushings and roll center kits
Everybody knows what this stuff looks like so no links or pics sorry.
Shipment will be here mid-May because of a backorder on the '08+ swaybars etc. I have alot of the '08+ STI/WRX parts coming in because of they are extremely popular items this spring.
PM me for pricing
I will not offer a group buy, I will try to match or beat any reasonable pricing on Whiteline without having to do this. It takes toomuch time and I do not want to sit on your money until I feel I have enough orders to fulfill a large shipping order.
In stock
RCE Tarmac Zeros-$1850
RCE Regular Guy springs '08+STI-$425
RCE Yellow GD chassis-$415
RCE Black-$415
RCE Wagon-$385
RCE swaybar kits '04-06 STI-$400
RCE/GTworx adj. camberplates for front and rear. GD chassis
KW Suspension
KW V3 for GD STI and WRX-pm for pricing
KW V3 for '08+ STI and WRX-pm for pricing
H&R Coilovers
I have a few sets of GC('93-00) and WRX('04-07) H&R coilovers for sale.
Street Performance Coil Overs
Lowers 1.0 - 2.5 inches on average
Fine tune lowering to what you want
H&R Street Performance Coil Overs are the suspension solution for discerning drivers—from daily drivers to serious tuners—can appreciate the awesome handling and superb ride comfort. H&R is the originator of the true coil over system for the street. Each custom valved shock is tuned with a precision-engineered progressive rate spring to create a finely tuned suspension system. The fully threaded shock body allows for adjustable vehicle lowering—to where you want. This feature helps balance vehicle weight, resulting in a lower center of gravity and improved performance and control.
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
dalesalignment&brake is offline
Closed Thread
RCE, Whiteline, H&R, Hawk, DBA in stock and better pricing dalesalignment&brake VIC Vendor Classifieds 1 06-11-2009 11:05 AM
Whiteline Distributor-Lots of suspension in stock dalesalignment&brake Canada Region Vendor Classifieds 0 09-14-2008 07:51 PM
Whiteline and RCE Suspension in stock dalesalignment&brake VIC Vendor Classifieds 0 05-14-2008 08:43 AM
Whiteline and RCE Suspension in stock dalesalignment&brake VIC Vendor Classifieds 0 05-14-2008 08:31 AM
RCE Tarmac II and KW Clubsport in stock dalesalignment&brake VIC Vendor Classifieds 0 05-05-2008 04:29 PM
