Old 05-26-2009, 03:02 AM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Need lights aimed 45+ from center for 06/07 WRX
I'm sick of driving at night and not being able to see anything that's not within the 60 degree or so forward cone of the headlights. The fogs don't help much either.
Without putting on a rally pod on the hood (this is a daily driver), what options do I have to add some kind of light to illuminate a wider field of view?
I don't care about HID bright/white... I just care about simply being able to SEE a wider field of view, and higher view. (I drive some windy, hilly roads at night.)
chimchimm5 is offline   Reply With Quote
Old 05-26-2009, 03:12 AM   #2
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Get a light bar, add two 500FF's in fog pattern, aim at 45's. Problem solved.
Carter is offline   Reply With Quote
Old 05-26-2009, 03:20 AM   #3
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Is there a faq on this (didn't see any)? I'll look up what you recommended, but I have no idea what 500FF really means. (Like this?)
Amazon.com: Hella 5750941 500FF Light Kit: AutomotiveAmazon.com: Hella 5750941 500FF Light Kit: Automotive
So I guess the rally innovations bar should be good? Doesn't seem to be any other choices out there.
Can I run this off the fog light circuit or will that blow the fuse?
Or do you have to do the "tap the battery" thing?
Old 05-26-2009, 03:35 AM   #4
subaru3169
Member#: 55252
* pullup bar *
if you get the kit, it'll come with its own relay harness and switch.. so tapping anywhere is not necessary
subaru3169 is offline   Reply With Quote
Old 05-26-2009, 09:23 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
You do use your high beams, don't you?
If the illuminated cone is too small, you can just drive faster. The perceived field of view will progressivelly narrow, as you won't have time to look anywhere but right in front. Also. it decreases the chance of a deer jumping in front of your car from the side - unless it's already there
Old 05-26-2009, 01:20 PM   #6
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Of course I use my high beams.
And "drive faster"? ...you are being silly.
Old 05-26-2009, 01:22 PM   #7
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Thanks! I'll get the kit then.
Looks like rally innovations $250 bar is the only option.
It seems something like this does not need to be that expensive.
Old 05-26-2009, 01:23 PM   #8
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Oh... is there a way to aim the fog lights?
Old 05-26-2009, 04:42 PM   #9
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Yes, I was being silly . And Hella 500 fog lights are your best bet. Don't get the pencil light ones, they project a very narrow spot very far (ie good for straight driving).
However, a light bar isn't mandatory. Lot of people figured a way to attach the hellas using random combination of Home Depot nuts, bolts, and bars. I brought my car to a friendly garage with a few L-shaped metal pieces, and they put them quite well for less than 100$.
Have a look here.. might inspire you
http://forums.nasioc.com/forums/showthread.php?t=673117
Old 05-26-2009, 11:01 PM   #10
raptor12r
Member#: 175737
07 WRX
Satin White Pearl
I had my front bumper off the other day and the OEM foglights do have adjustment knobs on them. Im pretty sure its just for up and down.
raptor12r is offline   Reply With Quote
Old 05-26-2009, 11:16 PM   #11
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Thanks for the info... crud.. that doesn't do me any good.
Old 05-27-2009, 12:39 AM   #12
DC16A2
Member#: 174357
2002 OBS
I would do this if I lived in more wilderness and less NYC:
http://forums.nasioc.com/forums/show....php?t=1746938
Effective, and it's not going to cost you anywhere near $250 =)
DC16A2 is offline   Reply With Quote
Old 05-27-2009, 02:34 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
silly n000bs....FOR THE 06-07 IMPREZA
from
http://www.danielsternlighting.com/p.../products.html
for the low beams.....
65W Osram Ultra High Output (2100 lumen, H9 burner on H7 base, race and special-purpose use): $29.40/ea
and for the hi-beams
http://cgi.ebay.com/ebaymotors/TOSHI...Q5fAccessories
The HIR 9011 replaces a stock 9005/ HB3 high beam bulb.
doing the above is one of the most shocking lighting improvements I have ever seen by just changing bulbs
doing anything else without trying the above first is just plain dumb
Old 05-28-2009, 09:17 PM   #14
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
Agree with Uncle Scotty. The H9/H7 upgrade is nice (I've never been a fan of the sharp-cut Euro pattern, but I'm an old fart), but the first time you fire up those HIR 9011s in the deep dark you'll crap your pants at the light booming from your grille. The only thing with the 9011s is that you have spend 30 seconds with a pair of dikes nibbling off a bit of the locator tab. Most places that sell 9011s have already marked out the part that needs to be nibbled off.
Captain Ned is offline   Reply With Quote
Old 05-29-2009, 01:04 AM   #15
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
from
I'm listening to Uncle Scotty!
I'll step 1 with the HIR 9011's.... as I'm fine with the low beams, but when I'm alone I want to highbeam and light up the FOV.
Old 05-29-2009, 01:18 AM   #16
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I don't understand what this means. You mean take a dremmel and grind down some tab that is on the bulk or the headlight housing?
EDIT: O I C...
http://shnu.us/HIR%20Trimming%20Stock.htm
Old 05-29-2009, 02:19 AM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Someone is veeeery confused
The Hella 500FF comes in driving beam only.
The Hella 500 comes in fog, amber fog, and driving.
You'd want 500FFs mounted as high as possible and aimed out to the sides.
Ooooorrrrr....
You could get Hella 1000FFs in Driving Beams which are brighter, more efficient, project farther down the road, have a more even beam, and provide ample illumination to the sides even while pointed straight ahead.
Stock Lows:
Stock Highs:
Hella 100FFs:
See how far off to the side (in this picture, looks like "closer") the 1000FFs throw the light?
Old 05-29-2009, 02:37 AM   #18
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Yes. VERRY confused.
How would a 9011 high beam compare to a 1000FF?
Old 05-29-2009, 02:40 AM   #19
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The reflector shape is what matters. The 1000FFs are "only" an H1 bulb, yet they're far, far brighter than the stock low beams, which also use an H1 bulb.
Old 05-29-2009, 10:30 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
d0000000000000000000000d..........
forget the ****ing aftermarket lights FOR THE ****ING MOMENT
do what I suggest and THEN see what you are missing------not much at that point, I'm sure
go from there
Old 05-29-2009, 12:59 PM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
go from there
Your fairy magic light bulbs aren't going to make his beam wider. Sure, things like HIR will make the existing beam pattern brighter, but that's it. Since he asked for a wider beam, not a brighter beam, I chose to answer his question.
Old 05-29-2009, 01:49 PM   #22
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Yeah, so to clarify:
I'm annoyed with not being able to see when the road bends at > 80 degrees (no street lamps). During the day grandma's could take the bends but at night, DUE TO THE LACK OF LIGHT, you have to slow to a crawl. That just annoys and disrupts a nice cruise.
That is... when I need to turn my head 45 degrees to see the road ahead... *I need illumination there*.
I'll probably still get the 9011 for the cool of it, but it sounds like I'll need aux lights to aim in those directions.
Old 05-29-2009, 03:04 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
and a set of hella micro de's if the Osram 65w + 9011HIR is insufficient
blasting through places where you have limited sightline at nite is a FABULOUS way to get to meet Bambi and all her friends, up close and personal
regardless of the lights on the car
Old 05-29-2009, 03:53 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I've owned the driving and fog Micro DEs. Both suck.
Well, +1 to that.
Old 05-29-2009, 04:06 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
but are easy to aim and install just about anywhere
which is a real problem with these cars
without adding a brush bar style mount and LARGE lights
I have been all over this one and there are few real options that work.
the lower opening, outside upper corners are pretty easy, but that is too low for a proper driving light....and too high for a fog
where did you get your HIDS from for 06-07 wrx gindobuck Electrical & Lighting 4 03-23-2009 11:46 PM
FULL BREMBO SWAP FOR 06-07 WRX everything needed ( NEW ) JUST TESTING WATERS 06wrxlbart Suspension/Brakes/Handling 5 08-29-2008 09:02 PM
FULL BREMBO SWAP FOR 06-07 WRX everything needed ( NEW ) JUST TESTING WATERS 06wrxlbart Tri-State Area Private Classifieds 10 07-31-2008 01:16 AM
wtb tires 225-45-17 or stock 06-07 wrx bhhamblin RMIC Private Classifieds 3 01-03-2008 07:09 PM
light weight rotors for 06-07 WRX 2evo1wrx Brakes, Steering & Suspension 9 03-10-2007 01:31 AM
