Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 05-26-2009, 12:32 PM   #1
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Default Question for those that have swapped on an STI gas tank
What did you do where the 3 fuel lines from the gas tank hook up to the 3 hard lines coming out of the RS interior? I have 2 problems.
First off, I don't know which ones connect back where. I might be able to figure this out on my own unless someone can help me.
Second problem is the stupid clip in lines the STI tank came with. The RS has 3 hard lines, two are regular old lines you use hose clamps on and the third is a clip style line. The STI tank has a single regular style line with a clamp and 2 clip style lines. The clips are both the same size and they will both hook to the clip on hard line. Now I'm guessing one of those will get hooked up but what should I do about the other one? The line itself isn't a rubber line so I can't just cut off the clip and push it on over the hard line. Is there an adapter or something?
Cyclops is offline   Reply With Quote
Question for those that have increased their car's value via swapping... RChampion Subaru Conversions 13 11-01-2006 12:11 AM
For those that have swapped w/STi interior Donzo Interior & Exterior Modification 19 08-29-2006 06:36 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
Neutral switch question for those that have done AT to MT swap Legacy777 Subaru Conversions 2 08-28-2004 03:49 PM
Question for those who have swapped their ej25 for an ej20t ivbdn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-12-2001 01:29 PM
