Old 05-26-2009, 12:32 PM   #1
stierzy34
Member#: 92113
2011 WRB WRX Hatch
Stage 2
Default Problems with AC and Idle!
So two things that I have noticed.
First, whenever I turn on my air conditioner, it will begin to on but will never seem like it will fully turn on. Hard to explain but the noise that starts right when you turn on your AC, happens the whole time for me.
Second, I am not sure if this is from the AC but the car is barely idleing. It will drive okay in the upper RPMs but when the clutch is pushed in, the car just about dies and idles very rough. I have checked the hoses once and in the process of retightening them again.
Any ideas on either of them?
stierzy34 is offline   Reply With Quote
Old 05-26-2009, 12:49 PM   #2
furryfootstool
Member#: 200526
had a similar issue a while back. clean up my iacv and tightened up a few loose hose clamps(vacuum leak) and the issue was gone
furryfootstool is offline   Reply With Quote
Old 05-26-2009, 01:12 PM   #3
stierzy34
Member#: 92113
2011 WRB WRX Hatch
Stage 2
hmmm, thanks. I will look into both of those. I am planning on making a trip to the dealership here soon to get a new gasket. also made sure to retighten any hoses. Thanks for the help and if anyone else has any advice let me know!
problem with ac SUBBY03WRX Mid Atlantic Impreza Club -- MAIC 3 08-12-2008 12:13 AM
problems with heat and AC MYnewWRX Service & Maintenance 1 12-02-2006 01:31 PM
hey homeowners, i have problem with AC, need some debugging koloa Off-Topic 12 06-25-2006 09:28 AM
Anyone else have a severe problem with water and ice cubes!? kevinsUBARU Tri-State Area Forum 2 07-25-2001 07:23 PM
Tire problems with Ford and Continental now N/A General Forum Archive 2 09-15-2000 08:37 AM
Message Board Statistics All times are GMT -4. The time now is 01:25 PM.
