Closed Thread
Old 05-29-2009, 02:31 PM   #26
ej20ajk
Member#: 113223
08 WRX NB R180
Dylan/DS1:
I'm in the middle of doing a 6 m/t swap on my 02 wagon. I'll be using all parts from a donor 04 JDM STi sedan including rear crossmember, R180 diff, driveshafts and Brembo brakes. I'm finding conflicting information on rear lateral links, since I'll be running R180 and Brembos. Is it stock wagon or use the STi ones?
ej20ajk is offline
Old 05-30-2009, 01:05 PM   #27
DS1
Vendor
Member#: 111780
The sedan links are longer and can cause interference issues with the whells and the quarter panel.
The axles are longer but we have used them in wagons with the stock wagon links and have had no adverse effects.
-Dylan @ DS1
DS1 is offline
Old 06-02-2009, 02:57 PM   #28
06WRX Wag'n
Member#: 158837
2006 WRX Wagon
Originally Posted by DS1 Motorsports View Post
ThreeEleven- You are the second guy they have told this to. It is wrong, if you have an 06' or 07' 6mt you will need a 3.54 rear end. Your stock is 3.70 and will not work.
-Dylan @ DS1
I might have been the first one to mention it to you. I ran into the same issues as ThreeEleven, which is why I ended up at DS1 for the install. The install has been great. The pizza was good too. Thanks DS1.
Russ
06WRX Wag'n is offline
Old 06-02-2009, 03:49 PM   #29
SYBugeye
Member#: 200805
03 WRX
Sonic Yellow
here is a question on the axle part. can you not just swap the female knuckle with a male knuckle to use stock wrx axles...im pretty sure that you can do this just want to make sure
of course this is mostly for the front i know you will have to swap out the drive shaft and rear diff but instead of putting sti hubs and everything on you can jsut swap the knuckles out so you dont have to change the whole setup
SYBugeye is offline
Old 06-02-2009, 04:16 PM   #30
Xenri
Member#: 166777
2011 WRX Wagon
sweet write up. I was looking for the driveshaft info for DAYS this is awesome. Wish I had had this a couple months ago when this project started....
Xenri is offline
Old 06-02-2009, 05:13 PM   #31
JSarv
Member#: 163445
l33t *******
[email protected]
I know it does not pertain to "swapping" but if you are looking for a 6 speed and drive on the interstate frequently - you will be VERY disappointed with jdm 5/6 ratios..
I love how it drives, don't get me wrong - love the ratio's but had to take it on the freeway 2 days in a row and find myself driving at or below the speed limit because of revs - gas mileage went OUT the window on the freeway and gained almost 2 mpg around town over the 5mt...
But there is absolutely NO wait and no need to downshift to pass - that is for DAMN sure
JSarv is offline
Old 06-02-2009, 07:23 PM   #32
DS1
Vendor
Member#: 111780
SYBugeye- The Female and Male reference refer to the inside (transmission side) of the axle.
Jsarv- for those of us who road race the JDM 5/6 is perfect
-Dylan @ Ds1
DS1 is offline
Old 06-02-2009, 07:35 PM   #33
555
Member#: 20161
1998 Impreza ST
555
Hey Dylan its been over a month since I paid for 32000AJ350 07` sti transmission . Would you gonna send it or not?
555 is offline
Old 06-02-2009, 08:48 PM   #34
SYBugeye
Member#: 200805
03 WRX
Sonic Yellow
so it is possible to keep the wrx hubs and swap the hats of the axles for the 6 speeds...?
SYBugeye is offline
Old 06-02-2009, 09:59 PM   #35
AspenWrx25
Member#: 111738
2008 FXT Sport
This is similar to the question that I have. Im swapping a '04 6speed into my '08 FXT Sports and want to know if I can keep my stock hubs and brakes since they share the same bolt pattern?
AspenWrx25 is offline
Old 06-02-2009, 11:49 PM   #36
DS1
Vendor
Member#: 111780
555- you have PM
SYBugeye- inner or outer cups?
AspenWrx25- Yes you can retain your stock axles/brakes but depending on which production 04' 6mt you have you may need to pop out the stubs and install 05'+ seals
-Dylan @ DS1
DS1 is offline
Old 06-03-2009, 12:35 AM   #37
AspenWrx25
Member#: 111738
2008 FXT Sport
-Dylan @ DS1
Thanks for the info Dylan.
One more thing, if I were to use the STi axles, is it still the same that I can retain my FXT hubs/calipers etc? Also which one was it that I need to look for that WILL need the 05+ seals? Thanks again!
Old 06-03-2009, 02:32 PM   #38
SYBugeye
Member#: 200805
03 WRX
Sonic Yellow
put the sti axle hats that go into the tranny on wrx axles that go into the hub...i would have to say the inner cups
SYBugeye is offline
Old 06-05-2009, 06:53 PM   #39
rougeben83
Member#: 115154
2005 Outback XT
White on grey
can you reuse your 5mt starter or do you need the one that came with the 6mt?
rougeben83 is offline
Old 06-06-2009, 09:13 AM   #40
JSarv
Member#: 163445
l33t *******
[email protected]
You can use either... I reused my 5mt starter - flywheel size (OD/Ringgear) does not change in diameter...
-Jerod
JSarv is offline
Old 06-08-2009, 04:23 PM   #41
Xenri
Member#: 166777
2011 WRX Wagon
Anyone got a price check on the yolks that convert the STi shaft to the r160 bolt pattern? I am having a hard time coming across any auto shafts thanks to the 6 speed swap demand lol. Looking into other options now...
Xenri is offline
Old 06-09-2009, 02:52 PM   #42
23-10
Member#: 168215
2003 WRX
Originally Posted by JSarv View Post
Dylan - I found some stuff -
V7-8 Non Dccd 6 speeds may or may not come with LSD front diff...
Is that typical or is that in the forrester and wagon?
Some had Open front diffs others had Suretrac diffs:
http://forums.nasioc.com/forums/show....php?t=1225160
23-10 is offline
Old 06-10-2009, 09:39 PM   #43
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
i have another wagon question. i have a 2005 wrx wagon, so i'm 5x100. i know i need to beef up trans very soon and i want to swap. i have cobb bbk front and rear so i'd really like to swap 04 sti trans that has 5x100 also. i keep finding conflicting stories on this. can i re-use my wagon axles into an 04 sti tranny?
from what i gather i'd need the shorter driveshaft (4eat?). i'm just tired of trying with no success to track down the right information. could somebody 100% tell me everything that i will need to swap 04 sti in? also i'm confused all to hell about making dccd work. if i don't hook it up would i have an open differential? how would i make the dccd work without swapping over an sti wiring harness?
thank you in advance, feel free to pm me a response if you want to keep it out of this thread. i will also take a link if this scenario has already been done. thank you thank you thank you.
PCSkiBum_21 is offline
Old 06-11-2009, 11:26 AM   #44
DS1
Vendor
Member#: 111780
You can reuse your front axles/hubs. If you do the R180 rear you will need axles/hubs/diff. You will also need to get mounting brackets and rotors from Cobb to keep your rear calipers.
You will need a 4EAT driveshaft or STi driveshaft (see info about correct yoke part numbers for STi shaft).
As far as DCCD, www.dccdpro.com
-Dylan @ Ds1
DS1 is offline
Old 06-11-2009, 02:09 PM   #45
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
thank you so much! for the rear axles/hubs what would i get? the wagon axles are shorter than sedan, so is there a wagon year axle that mates with the r180? 5x100 preferrably so i don't have a mixed set up. (5x100 front 5x114 rear)
Old 06-11-2009, 02:33 PM   #46
DS1
Vendor
Member#: 111780
The R180 sedan axles will work in the wagon. I used them in my own car to double check and no issues
-Dylan @ Ds1
DS1 is offline
Old 06-11-2009, 02:35 PM   #47
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Flywheels:
02'-05' WRX all use the same clutch and flywheel (except very early 02's). The 5mt clutch can be used with the 6mt but is a smaller diameter than the 6mt unit. The WRX slave cylinder can be reused on all 6mt's.
How does the change in diameter make a difference? I have a lightweight flywheel that is in my 5mt and will be doing the swap. i don't know if i should still keep it since i can use it or swap it out.
arco is offline
Old 06-11-2009, 02:49 PM   #48
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
Originally Posted by penusai View Post
for the male tranny with stubs sticking out.
Early 2004 Axle Seal Part Numbers:
Left: 806730041
Right: 806730042
http://forums.nasioc.com/forums/show...seals+stubs+06
Im looking at an 806730041 right now labeled RH on the bag. Im not sure theres any difference between the right hand and left hand side. in fact they look exactly the same as cam seals.
SBW is offline
Old 06-11-2009, 02:52 PM   #49
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
heres a special question.
'00 coupe rs.
As much of the STi stuff I can use from a 5x114.3 STi.
Hubs, brakes, axles, diff, d/s
Can I use the control arms?
darksc00by is offline
Old 06-11-2009, 02:58 PM   #50
DS1
Vendor
Member#: 111780
Arco- Bigger diameter = More load surface
SBW- Yes there is a difference between LH and RH
darkscooby- control arms and lateral links are longer in an GDB chassis. You can use them but you may have camber / Tire clearance issues.
-Dylan @ Ds1
DS1 is offline
Closed Thread
The 2008+ sti 6 speed trans swap thread - the facts and parts needed for the swap STiGuy23 Transmission (AT/MT) & Driveline 50 02-21-2015 07:33 PM
6 speed swap question! Axles! Help! (have read all faq's and relevant threads) arch4life Subaru Conversions 6 09-12-2009 08:51 AM
Brand New Complete 07 STI 6 Speed Swaps for WRX, all necessary parts included! $4450 P&L Motorsports Inc. Drivetrain 14 12-03-2008 12:44 AM
I need help fast with 6 speed swap, clutch wont release all the way javastiwagon24 Transmission (AT/MT) & Driveline 7 04-16-2007 10:20 PM
New 6 speed swap/r180 rear end What fluids??? dan avoN7 Transmission (AT/MT) & Driveline 10 04-14-2006 12:43 PM
