Closed Thread
Old 06-11-2009, 03:23 PM   #51
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
Originally Posted by DS1 Motorsports View Post
The R180 sedan axles will work in the wagon. I used them in my own car to double check and no issues
-Dylan @ Ds1
they will work but won't it be wider? i am already pushing my fender clearance and have them rolled. no way will i be able to fit 17x9 and 245's under there with a sedan axle haha
PCSkiBum_21 is offline
Old 06-11-2009, 06:22 PM   #52
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Arco- Bigger diameter = More load surface
-Dylan @ Ds1
Would the load surface difference from the stock STi be a much bigger contribution to me and outweigh the use of my WRX ACT Streetlight lightweight flywheel? (No pun intended)
arco is offline
Old 06-12-2009, 04:20 PM   #53
Xenri
Member#: 166777
2011 WRX Wagon
two questions:
1. You mentioned that the driveshafts out of the 1993-2001 Imprezas were best for the swap with an r160 because of a "correct center support". Now, if you get one off of the 2002-2007 version, what do you have to do to make it work? I do not have it in front of me yet, but I thought I would get a jump on it if I need to do something tricky...
2. I have heard through the grape vine that if you are swapping a 6 speed into a female axle styled car that you can RESUSE the stubs off of the original transmission in the car. is this true, or do I need to get a stub kit to make the conversion in an 07 6 speed?
Thanks in advance, and a vote for a sticky!
Xenri is offline
Old 06-12-2009, 05:32 PM   #54
DS1
Vendor
Member#: 111780
PCSki- The axles won't determine the width, the lateral links will.
arco- yes
Xenri- 1. they both will work in the GC/GF chassis but the newer one will sit slightly lower.
2. you cannot reuse the 5mt stubs in the 6mt's.
-Dylan @ DS1
DS1 is offline
Old 06-12-2009, 06:56 PM   #55
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
-Dylan @ DS1
ohhhhhhhhhhhh. thank you!
Old 06-13-2009, 05:31 PM   #56
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
Dylan, I just got some parts for my swap from the dealer and I thought I'd share the part numbers incase anyone needs them. Add them to your info if you think they are helpful.
All for the 2004-2007 6mt (may fit other models)
Clutch fork shaft (long part the clutch fork pivots on) - 30532AA020 - ~ $30
Clutch fork shaft plug (threaded cap that holds the fork shaft in) - 30550AA000 - ~$13
Output Shaft Oil Seal (oil seal for the driveshaft interface) - 806735210 - $11.50
Clutch fork spring (spring that connects clutch fork to bell housing) - 30546AA060 - $5.20
I see you already have the axle seal part numbers, but those were ~ $10 a piece.
All prices are from my local dealer and are likely more expensive than getting them on line, but no one online would help me figure out the part numbers so I thought their help was worth extra cost.
kpluiten is offline
Old 06-13-2009, 05:40 PM   #57
kpluiten
Member#: 120273
06 WRBWRXWGN
Also, I wanted to share that while the right and left front axle oil seals look the same, they are not. They have different part numbers because of a very subtle change on the inside lip that contacts the axle. If to hold the two side by side, the little micro groves spiral clockwise on one and counter-clockwise on the other. I assume this help push back rogue oil while the axles are spinning. Don't let the dealer tell you " they're probably the same... it shouldn't matter too much" which is the answer I got. You must order one of each: 806735230 and 806735240. I forget which is which, but it was stated in the original post.
kpluiten is offline
Old 06-13-2009, 06:48 PM   #58
Xenri
Member#: 166777
2011 WRX Wagon
Kpluiten, are all those random clutch fork parts necessary if you were to buy a transmission from the dealer? I got mine brand new through them, and ordered a clutchfork along with the trans (as well as a mount and shift linkage), but do I also need to order the stuff you have listed there? I wont be able to actually look and see what all I have until the crate gets here from japan...
Xenri is offline
Old 06-13-2009, 08:01 PM   #59
kpluiten
Member#: 120273
06 WRBWRXWGN
I'm not sure to tell you the truth. I needed everything cause the box I bought used was completely stripped of everything except harness and seals. I just decided to do the seals cause they are cheap and I don't want a leak after all the work of putting it in the car from a lousy 10 dollar seal.
My transmission came out of a totaled 2005 STI with <10K.
kpluiten is offline
Old 06-15-2009, 05:28 PM   #60
ALTIMIT_09
Member#: 138527
2004 WRX 4eat vf39'd
im i doing it right?
Tranny:
2005- Part# 32000AH150
Ratios= 3.636 / 2.375 / 1.761 / 1.346 / 0.971 / 0.756
3.90 final drive (front and rear)/ Male front axles. LSD Front diff/DCCD Center (36F/64R Bias Open)
Clutch = Pull
MY car 04wrx:
2002-early 2004 WRX 5mt/4eat
Final drive: - 4eat 4.11 Front and rear
Front Axles = Female
or this I dont know
Late 2004-2005 WRX 5mt/4eat
Final Drive: 4eat 4.11 Front and rear
Front Axles = Male
Im using an r160 so:
Subaru Part #'s
3.90 - 38104AA010
And I dont know if I got female or male axles
ALTIMIT_09 is offline
Old 06-16-2009, 08:55 AM   #61
yaya20
Member#: 130354
2011 535i
I'm getting ready to do a JDM V8 swap into my 05 WRX. I believe I have all the parts necessary for the swap, but I still have one question...
I recently replaced the clutch/flywheel in my 5 speed with an ACT Stage 2 setup. I know the setup will work in the 6 speed, but will I get more benefit from it or running the oem STI clutch/flywheel I got with my swap?
Having just spent the money on the 5MT clutch/flywheel setup I feel like I should run it...
Any thoughts?
yaya20 is offline
Old 06-16-2009, 04:52 PM   #62
Xenri
Member#: 166777
2011 WRX Wagon
personally, I would hate to go back to a stock set up after running a light weight flywheel and a performance material clutch. Yea the STi stuff is bigger, but I would wait on that til you kill the ACT stuff. if nothing else, you have the stockers on hand if ur clutch goes unexpectedly, then you can throw a stage two STi set up on yours. I am in the same sitution with an exedy stage 3 kit. Can make myself toss that money out when I can still use it...
Xenri is offline
Old 06-16-2009, 05:09 PM   #63
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
+1 on that. keep the act until that needs to be replaced then go sti aftermarket.
Old 06-16-2009, 09:40 PM   #64
DS1
Vendor
Member#: 111780
Altimit_09- To determin if you have male or female axles look at the inner cup of the axle to see if it has a roll pin through it right by the side of the trans. The 3.90 ring and pinion is correct.
-Dylan @ Ds1
DS1 is offline
Old 06-16-2009, 10:47 PM   #65
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
ok 6mt with auto axle and r160 3.9. I'm confused on the front cv shafts. Can you explain in more detail? I seem to be missing something.
hybrid gti 2 is offline
Old 06-17-2009, 12:21 AM   #66
DS1
Vendor
Member#: 111780
Which part are you confused on?
-Dylan @ DS1
DS1 is offline
Old 06-17-2009, 12:36 AM   #67
ALTIMIT_09
Member#: 138527
-Dylan @ Ds1
Thanks Dylan for the reply, just gotta find the ring and pinion, do you sell them, or know of a source?
Old 06-17-2009, 12:43 AM   #68
ALTIMIT_09
Member#: 138527
looks like you have an 02 wrx so that means:
your tranny
(06 mt 6spd)
2006- Part# 32000AJ760
3.90 front final drive-3.54 rear final drive/ Male front axles. LSD Front diff/DCCD Center (41F/59R Bias Open)
Clutch = Pull
your car (02 wrx)
Final drive: 5mt= 3.90 Front/3.54 Rear - 4eat 4.11 Front and rear
Clutch = Pull
you need:
"male axle 6mt and you have a female front axle car you will need these":
806730042 Oil Seal LH x1
806730041 Oil Seal RH x1
38415AA110 Axle Stub x2
805329010 C-Clip x2
Old 06-17-2009, 12:57 AM   #69
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
why 06 sti trans? Hard to find. Was thinking of what ever I can find and swap to 3.9 r160 if needed or maybe r180 in a deal I found.
After reading more I saw the part numbers for the axle stubs. So I understand now.
Old 06-17-2009, 01:16 AM   #70
DS1
Vendor
Member#: 111780
The 06'-07' boxws may be a little more than the earlier boxes but when you take into account the money for a ring and pinion and install (or your time spent installing it) the cost is usually about hte same unless you find a screaming deal on an early box.
-Dylan @ DS1
DS1 is offline
Old 06-17-2009, 01:21 AM   #71
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
from my experience..i would ditch the 3.90 R&P mod in the r160. i blew 2 r160 diffs before i upgraded to a a full r180 rear end. this was in my old wrx.
the whole point of upgrading to a 6mt is to have fun and not really worry about breaking any drivetrain parts besides an axle..lol. the r160 can not handle hard shifts and/or donuts/drifts.
swift2fly is offline
Old 06-17-2009, 01:36 AM   #72
ALTIMIT_09
Member#: 138527
how hard of a shift are we talkin 5k drop from launch control?
Old 06-17-2009, 01:41 AM   #73
swift2fly
Member#: 70810
07 impreza STi
the first r160 i over heated from drifting all night..i just warped the internals.
the 2nd one i just grenaded..i drove my wrx hard so i don't recall after how many times i launched it before it blew.
i had a V9 spec-c tranny with the 35/65 torque split so the majority of the power was always sent to the rear after a hard lauch.
Old 06-17-2009, 08:03 AM   #74
ALTIMIT_09
Member#: 138527
ok i will not be doing that, ill have the DCCD from the donor car, ill try to keep it even split.
I should be ok for the sprited driving, with the vf39 stage 2.
Thanks for the info.
Old 06-17-2009, 11:55 AM   #75
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
-Dylan @ DS1
Yea found a deal. Yet what about the dccd wiring? As I understand that if left alone if can distroy the center diff over time. Yet that's just what I read.
Next question what parts are required to swap to the r180 rear diff? 04 sti parts but how much of them are required to keep the 5x100?
Closed Thread
The 2008+ sti 6 speed trans swap thread - the facts and parts needed for the swap STiGuy23 Transmission (AT/MT) & Driveline 54 08-20-2016 02:55 PM
6 speed swap question! Axles! Help! (have read all faq's and relevant threads) arch4life Subaru Conversions 6 09-12-2009 08:51 AM
Brand New Complete 07 STI 6 Speed Swaps for WRX, all necessary parts included! $4450 P&L Motorsports Inc. Drivetrain 14 12-03-2008 12:44 AM
I need help fast with 6 speed swap, clutch wont release all the way javastiwagon24 Transmission (AT/MT) & Driveline 7 04-16-2007 10:20 PM
New 6 speed swap/r180 rear end What fluids??? dan avoN7 Transmission (AT/MT) & Driveline 10 04-14-2006 12:43 PM
