Old 04-23-2002, 11:46 AM   #1
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Have a Nice Day? Clutch problem... with new clutch...
Ok... I finally got my clutch replaced by the dealer. It had a million issues including the decel noise.... now everything is gone. Shifts are much smoother no noise its great. Except for one thing, now whenever I bring the clutch to the engagement point in an attempt to move the car say 6 inches the whole front end shakes and vibrates. It is even worse if the car is under any load such as an incline... If I rev it to about 2K before slowly letting the clutch out it isnt as bad but it will still do it. Should I take it back to them? Or should I give the new clutch a few hundred miles to wear in. I was driving around a parking lot yesterday to try and get use to the clutch and after about 20 minutes it seems to be a lot better, but today the problem is back!
My poor baby! The scratched her at the dealer too! GRRRRR......!
Any advice?
Evaider is offline   Reply With Quote
Old 04-23-2002, 01:03 PM   #2
Bronco
Member#: 6134
98 rs
Rally Blue
Angry
I had a similar problem with my car, Clutch chatter at about 55,000 km (30,000 mi). The dealer ship replaced the clutch disc, release bearing and machined the flywheel....and also replaced the Transmision housing. The service manager told me what happens is the release bearing wears into the aluminum nose piece that the release bearing rides on and once this happens is it will start to hang up on the ridge that is worn into it. I have about 10,000 km since work and all is well.
Bronco is offline   Reply With Quote
Old 04-23-2002, 02:11 PM   #3
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
They replaced the clutch, flywheel, and release bearing already... So maybe they need to replace the transmission housing now? ugh.
Old 04-23-2002, 03:35 PM   #4
Bronco
Member#: 6134
98 rs
Rally Blue
Ask the dealer if there was any wear on the nose piece , a groove of any sort can hang the bearing and not allow the clutch to release smothly. I had no idea this was the problem I thought I had a weak clutch. I mentioned it i passing when I was getting some work done. When I brought the car in for the work the dealer had already ordered the housing before even looking at it. That would suggest it is a fairly common problem. They also replaced the short block to eliminate a piston noise.
Old 04-23-2002, 10:47 PM   #5
TerenceT
Member#: 9510
04 FX35
Pearl White
aftermarket or oem clutch?
TerenceT is offline   Reply With Quote
Old 04-23-2002, 10:52 PM   #6
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
OEM clutch, flywheel, bearing, and pressure plate.
Old 04-24-2002, 10:00 AM   #7
Bronco
Member#: 6134
98 rs
Rally Blue
All is stock before and after repair
Old 04-24-2002, 11:32 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
clutch shudder in these cars is perfectly normal, you just gotta learn how to drive around it.
jeremy
Old 04-24-2002, 12:03 PM   #9
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
jeremy
ahhh. no. I dont think this is normal. This is about 1000X worse than normal. It feels like the transmission is going to fall out. And it didnt do it this bad before they replaced the clutch. It honestly feels like the car is going to fall apart you can physically see the front end shake. Is that normal? If it is I want a refund on my car!
Old 04-24-2002, 01:15 PM   #10
TerenceT
Member#: 9510
04 FX35
Pearl White
ok, my theory.. noone has prove me wrong or right
1) factory pressure plate is weak on some cars, in fact, so weak it has trouble holding the clutch disk in causing it slip while the cluth is engaged
2)this slipping cause the disk to overheat and wrap, wrap disk would bent when cold, so during start up, you get shuddering
i would bring your car back to the said dealer immediatly since supposedly you get a new clutch. in that case, i am leaning towards installation error. have them check the clutch slave cylinder cable to see if it's loose
Old 04-24-2002, 03:54 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
actually the clutch plate can't warp....it's not a solid metal object...clutch shudder is caused by uneven wear on the disc surface. You are hitting hte high points when you are shuddering...htis normally happpens right at the friction point...it happens on all cars but is most noticeable on AWD cars cause the powertrain can't flex easily.
jeremy
Old 04-24-2002, 05:40 PM   #12
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
jeremy
So what does this mean? Its a brand new clutch it should not be worn unevenly, was it installed unevenly then? Should I take it back? Or will everything eventually wear down so that it is even and not as noticeable? It is frustrating having to deal with this when driving, it makes the car almost un-driveable.
Old 04-25-2002, 12:29 AM   #13
TerenceT
Member#: 9510
04 FX35
Pearl White
jeremy
1)it doesn't explain why it only happens when its cold.
2)had and quattro before, never happen, awd also
3)i hope it doesn't happen on all car
Evaider, you are talking about cold shudder right? it goes away in a mile or so and worst when you are trying to start from stop signs? feels like you have a 3 puck race clutch kinda shudder right?
Old 04-25-2002, 01:54 AM   #14
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Shudder all the time. Doesnt really go away but gets a tad bit better after driving it for a while. Highway driving doesnt seem to count, only stop and go type driving. And i ahve no idea what a 3 puck race clutch feels like but ill just agree.. hehe
Old 04-25-2002, 03:19 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
1)it does not only happen when it's cold...you only feel it when it's cold, i can make it shudder when it's nice an hot...you have usually burned off the unevenly worn area.
2)i'm guessin A4 which is a transverse mounted engine...they way the power plant sits it tends to absorb the shudder much nicer...and subaru uses a 50/50 center diff to control power output...IIRC Audi's varies depending on load...therefore the shudder is transmitted to the tires..not the car.
3)i can tell you it happens on all cars
you may wanto call about your concern but i don't see how clutch shudder would make a car undriveable?? it just takes more skill and care to drive it. And there is no cable...it's a hydraulic clutch system.
jeremy
Old 04-25-2002, 09:34 AM   #16
Bronco
Member#: 6134
98 rs
Rally Blue
My car had a cluch chatter when first starting and got better once it warmed up, but it was still there if you shifted hard. It was great after the clutch and transmision housing were replaced. Like I said before the dealer had ordered in the housing before he had the transmition out to inspect it.
Old 04-26-2002, 12:42 PM   #17
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Heres an update for everyone.... Its 99% gone. I rarely notice it anymore. So give it another week and it should be 100% gone.
Old 04-27-2002, 05:58 PM   #18
sperry
Member#: 8636
WRX, OBXT, NA Miata,
F250SD, no more SVX :(
Evaider--
I had the same warranty clutch swap done on my car. Right after getting it, the clutch shuddered at low rpms and the pedal was *very* soft. After about 300 miles, the pedal feels like it used to, and the shuddering is gone. I think it just needed breaking in.
--Scott
sperry is offline   Reply With Quote
Softer clutch pedal after with new clutch? txl146 Transmission (AT/MT) & Driveline 3 01-24-2010 10:20 PM
Problems with new clutch. Please Help!! auto-f Newbies & FAQs 12 01-04-2008 09:09 PM
Slipping clutch issue.. with new clutch kit, evsoul Transmission (AT/MT) & Driveline 7 09-05-2006 01:39 PM
Having problems with new clutch Stiletto Transmission (AT/MT) & Driveline 3 06-20-2004 04:24 PM
