Old 05-27-2009, 06:49 PM   #1
traction issuez
Member#: 86559
2005 RS Wagon
Default building a fuse box, what fuses for what??
i'm trying to put in a fuse box in my trunk, where it connects to various things such as alcohol injection pump and controller, along with other sorts of extra electronics so if anything happens i can trace problems down quickly. the fuse box is going be connected to a relay and that relay is going straight to the battery.
what i need to know is, how can i test which equipment needs what fuse? say gauges, what fuse what i put inline with it? how much amps do i need?
thanks
traction issuez is offline   Reply With Quote
Old 05-27-2009, 07:48 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
you can check the specs of the actual equipment. usually it lists the load.
other than that some others will probably chime in with a reasonable list of fuses that you would need for each individual piece of equipment.
jdubya301 is offline   Reply With Quote
Old 05-27-2009, 11:40 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
if you dont have the specs, then buy a bunch of fuses, and put the lowest amp-rating ones first. whatever blows, replace by a higher till it it doesn't blow. After a while, all will be rated for your equipment
Old 05-27-2009, 11:42 PM   #4
traction issuez
Member#: 86559
2005 RS Wagon
haha,yeah i'm actually doing that right now because i cannot think of any other way.
what pad for what product?HD uno/megs 105/205 ect subynation Car Care & Detailing 2 01-23-2010 03:23 AM
HELP! - Need fuse box diagram for 91 Legacy Ti (JDM model) seowitz Legacy Forum 1 07-06-2005 01:28 PM
WTB: interior fuse box for a 2004 wrx Wagon Joe Private 'Wanted' Classifieds 5 11-29-2004 07:56 PM
Can you do me a favor? Scan your fuse box for me... boneriffic General Community 2 08-10-2004 01:23 AM
Need fuse box diagram for the engine side Pakin Legacy Forum 3 05-22-2003 08:16 AM
