Old 05-28-2009, 02:16 AM   #1
Zerogravity
Member#: 151638
2005 WRX Wagon
Default rod knock or valve knock
My car is making this noise when I shift or go over 3200 rpm..
is this valve noise or rod knock ?
should I get the same engine fixed or should I get a new block ? also how much would this cost both to fix or get new block ?
By the way this is not my CAR. but it sound very similar mines just doesn't do it unless you accelarete or shift over 3200rpm to 4000rpm FYI: if I accelarate like in the Video it does not do the noise..
Zerogravity is offline   Reply With Quote
Old 05-28-2009, 02:34 AM   #2
dvsone775
Member#: 192309
2004 WRX
I can only fathom how you feel at the moment....but that just doesn't sound right/normal. I'm trying to figure out a misfire problem. Good luck.
dvsone775 is offline   Reply With Quote
Old 05-28-2009, 03:29 AM   #3
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
I can't listen to the video right now, but I have a feeling I have the same sound you have. Only over 3000 RPM's, best heard in 1st or 2nd gear, under light-to-medium throttle input? Sounds like a rapid tapping?
If so, I too have been searching for the cause of that sound for hundreds of miles. I noticed it when I picked the car up with 127,000 miles on it, previous owner said he had heard it for plenty of miles as well. Figured it was a heatshield or something. Now coming up on 140,000 miles, no loss in power, and I haven't exactly babied the car the entire time either. My biggest guess is that is the timing belt tensioner. But hoping to find some other explinations (besides a bearing that is about to spin) before spending $100 on a new tensioner.
MConte05 is offline   Reply With Quote
Old 05-28-2009, 04:23 AM   #4
GundamFan
Member#: 212204
I am very sorry to say but that sounds like rod knock either way you have to take apart the motor. As far as fix vs buy a new block it just depends on how much machine work cost in your area, i would try to fix it if it makes financial sense since you would be rebuilding the shortblock which gives you a chance to upgrade or just rebuild to stock either way you end up with a near new shortblock.
p.s. this is my first post in the forum but i have been working on cars for about 10 years now
GundamFan is offline   Reply With Quote
Old 05-28-2009, 01:06 PM   #5
DausWRX
Member#: 134429
02 wrx
blu
that sounded like a rod knock but you should empty out the oil and stick your finger inside the oil pan to check for metal shavings just to be certain
DausWRX is offline   Reply With Quote
Old 05-28-2009, 01:41 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
straining the oil through an old sock or some such and seeing any 'gold colored' flecs will indicate a bearing issue
Old 05-28-2009, 02:28 PM   #7
Zerogravity
Member#: 151638
2005 WRX Wagon
=-( dammm this sucks !!!
how much does it cost to repair ? I just need some estimate to avoid having some mechanic try to rip me off.
Old 05-28-2009, 03:06 PM   #8
GundamFan
Member#: 212204
Guys with noise like that honestly if he just drains it all into a bucket it will look metallic, i been there, its soo sad
OP about the price it kind of depends on how much machine work cost in your area and how much damage there is.
Old 05-28-2009, 06:41 PM   #9
sleepyfu
Member#: 124219
2004 W(agon)RX
I don't think you have the same problem as the car in the video you posted. You are only hearing the tapping noise during 3k rpm or with light throttle input right?
sleepyfu is offline   Reply With Quote
Old 05-28-2009, 07:01 PM   #10
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
now thats rod knock.
turboL is offline   Reply With Quote
Old 05-28-2009, 07:27 PM   #11
Imprezed04
Member#: 202396
2004 STi
I spun a bearing in my 2.0L and only heard a tap when I went over 2500 rpm's...I couldnt tell if it was rod, or valve knock, and seeing as I've never spun bearings in any car before I was at a loss...my tuner took a listen to it and it turned out being I spun the #4 bearing..I'm doing a full engine build and upgrade, and considering I'm in Alaska, and shipping is outrageous, I'm spending $1723 on parts, and I'd guestimate about $300-$400 in shipping..
I've found engines here in Alaska, but they're asking more than that to buy them from a junk yard etc..I'm also doing all the machine work on my own here at the Crafts Center on Post, so that helps alot with getting my car fixed cheaper.
Call a couple shops in your area, that do machine work, and ask what it'd cost to machine your block..IF you have rod knock, its most likely tearing up the cylinder walls, so you'd have to have them machine it, and assuming you want to just rebuild stock, have them sleeve it as well. I'm boring mine +.020, for more displacement, and the pistons for that are the same price as factory pistons..Just depends on what you are looking for man. Call the shops first about the machine work and get quotes from them before ordering parts though. They get expensive quick.
Imprezed04 is offline   Reply With Quote
Old 05-29-2009, 04:53 AM   #12
Zerogravity
Member#: 151638
2005 WRX Wagon
Yeah ...
Old 05-29-2009, 04:55 AM   #13
Zerogravity
Member#: 151638
2005 WRX Wagon
damm this just ruin my summer..
Old 05-29-2009, 12:44 PM   #14
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
I think more people need to focus on this. Now you all are getting me worried too.
How many miles did any of you who spun a bearing go while hearing this noise before it happened? Mine has been going nearly 10,000 miles, maybe longer, but it is only audible under light throttle input and above 3k.
Old 05-29-2009, 04:35 PM   #15
Zerogravity
Member#: 151638
2005 WRX Wagon
my car has 73,000 and its just started.
Old 05-29-2009, 04:38 PM   #16
07 STI UGM
Member#: 172044
2007 STI AMS 30R
URBAN GRAY
Rod knock. Bad bearings.
07 STI UGM is offline   Reply With Quote
Old 05-29-2009, 09:48 PM   #17
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
Rod knock. I had the exact same problem. I bought ACL engine and connection rod bearings from Ebay for merely 80 bucks. Then found someone in town who had some STi rods so I wouldn't have to go get mine machined. Total cost me maybe 200 in parts, bought a gasket rebuild kit from 1stSubaruParts.com for only 250, and the rebuild took maybe ~22 hours in labor. It's a pain in the butt, and sorry to hear it happened, but it happens to the best of us. I also took advantage of it and upgraded my injectors and rods so while it's out, have some fun with it. But otherwise, this is not an expensive fix, but mind you it's extremely time consuming...
MrRicH is offline   Reply With Quote
Old 05-29-2009, 10:11 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
what oil and changed at what interval??
Old 05-29-2009, 10:44 PM   #19
gling
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
Is the noise coming from the center or the side of the block?
gling is offline   Reply With Quote
Old 05-29-2009, 11:21 PM   #20
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
that video makes me CRINGE.
scoobynoobEMT is offline   Reply With Quote
Old 05-30-2009, 02:00 AM   #21
Kamikaze03084
Member#: 37656
02 vf39 EWG
BLUEBARU
You have rod knock. Usually high pitch ticking noises would deal with head internals. Ultimately, you will need to replace your bearings. Try not to drive the car or it may lead to more damage.
Kamikaze03084 is offline   Reply With Quote
Old 05-30-2009, 02:07 PM   #22
Zerogravity
Member#: 151638
2005 WRX Wagon
sounds like from the side this is why i was thinking it could be valves. but every one else says its rod..
Old 05-30-2009, 02:09 PM   #23
Zerogravity
Member#: 151638
2005 WRX Wagon
damm this sucks I just got some estimates and the cheaps one was for 4,600 new 2.5 short block... this includes everything labor etc.... another place said 8,000
Old 05-30-2009, 02:14 PM   #24
bikergreen
Member#: 192157
04 BMW 325xi Wagon
Grey
O man I did the same thing and my oil was gold totally full of bearing - I bought a JDM motor and had it dropped in. Good luck and search lots for options there are lots of them. It the worst noise ever and when it happened to me I knew exactly what it was and I had an hour to sit in my car and think about it until the tow truck got there .
bikergreen is offline   Reply With Quote
Old 05-30-2009, 02:54 PM   #25
Zerogravity
Member#: 151638
2005 WRX Wagon
how much did it cost you to fix?
Newly Minted 257/WRX hybrid -- rod knock or noisy valvetrain? wigglesxjr Built Motor Discussion 45 12-09-2012 04:36 PM
Some knocking...rod knock or piston slap? mtcs Built Motor Discussion 41 12-03-2012 05:47 AM
WTB: V7 EJ207 Rods+crank, or AM rods+05 revised crank 5hif73r Private 'Wanted' Classifieds 0 12-28-2008 01:16 PM
HELP!!!! possible rod snap or floating valve..... rllyrckt Normally Aspirated Powertrain 8 02-23-2008 12:04 PM
Rod/valve Knocking?!?!?!?!?!?!?!?!? WRBlueRex04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-17-2008 10:27 AM
