Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 05-28-2009, 12:12 PM   #1
Quick
Member#: 17704
2009 STi
Default DCCD display help!
Ok, I've got a 2009 STi that's my track car. I am installing an AiM MXL Pista datalogger and would like to replace my stock cluster. The problem, however, is that my DCCD display uses the CAN bus to talk to the cluster. Previous models just used seperate wires (which makes wiring up an LED display pretty easy).
So, any ideas on how to get around this? Suggestions????
Quick is offline   Reply With Quote
Old 05-29-2009, 04:10 PM   #2
nbudros
Member#: 180475
2008 STi
are you replacing the whole dash?
nbudros is offline   Reply With Quote
Old 05-29-2009, 04:11 PM   #3
Quick
Member#: 17704
2009 STi
I am planning to... if i can figure out a solution.
Old 05-29-2009, 04:22 PM   #4
MasterKwan
Member#: 98961
2003 WRX
I'm skeptical that you're going to find one. You seem to be talking about reverse engineering the whole canbus setup. While I know that's doable, it won't be an easy task.
One possibility would be to retro-fit an earlier DCCD system into the car but, you'd probably have to switch harnesses, ECU and ABS systems too. You could also switch to an aftermarket ABS controller like the spiider. I believe it'll drive the earlier displays these days.
Old 06-02-2009, 02:06 PM   #5
Rocket_Rally
Member#: 74917
Most motorsport diff controllers (including the Plug and Play we have for the 2008-2009 as well as the standalone unit) also have a 0-5V output in additoin to the canbus driver to drive a seperate display
www.rocketrally.com
Rocket_Rally is offline   Reply With Quote
Old 06-02-2009, 02:12 PM   #6
Quick
Member#: 17704
2009 STi
www.rocketrally.com
Do you have a link to this unit (pnp or standalone)? I seem to be internet-tarded and can't find it...
FS: JDM sti with DCCD display Weiss 1993 - 2001 Impreza Specific Parts 3 12-28-2008 11:09 PM
WTB Version 5 (or later) Gauge Cluster with DCCD Display sptsi00 Private 'Wanted' Classifieds 0 12-09-2008 12:58 PM
DCCD Display qhatherly Transmission (AT/MT) & Driveline 2 01-18-2006 09:54 AM
DCCD Display Input? psyctto Electrical & Lighting 3 08-18-2004 09:36 AM
DCCD display hack idea ANZAC_1915 STi Forum Archive 22 07-20-2003 12:27 AM
