Old 05-28-2009, 09:01 PM   #1
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Question Noise from Clutch/Flywheel, and weird short shifter problem
Hey guys. I just brought home my 02 WRX wagon (142k miles, 5MT) last night and am starting to diagnose the trouble areas. It has noticeable clutch shudder, but that's not what concerns me.
The car is making this weird noise that comes from right under the throttle body, and appears when I push the clutch in. It sounds similar to an old A/C condenser bearing. It's not constant, sort of like Morse code. Clutch fluid looks good and is at proper level. It was overfilled when I brought it home and leaked down the cylinder. The clutch feels new as I can launch at 142k miles. At some points when you play with the shifter while stopped it sounds like a light grind going into gear. It also happens when in gear and decelerating. Pretty much goes away when accelerating. Can anyone offer some guidance? I've not had tranny problems in my Subarus before. Thanks.
MYfirst00 is offline   Reply With Quote
Old 05-28-2009, 09:45 PM   #2
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Also, I've just taken out the shifter to test and the noise is still there, no matter what height or angle the fork is at.
Sounds like a throw out bearing and input shaft bearing issue resulting in noise as well as clutch shudder as I research more...
Crude Transmission Deceleration and Acceleration Noise after Clutch/Flywheel Install caterpill Transmission (AT/MT) & Driveline 271 05-20-2015 05:36 AM
FS, NY: STI short block, STI cams, oil pump, 03 WRX 5spd, clutch, flywheel, and more. chrisarella Engine/Power/Exhaust 12 09-03-2009 08:06 PM
FS, NY: STI short block, STI cams, oil pump, 03 WRX 5spd, clutch, flywheel, and more chrisarella Tri-State Area Private Classifieds 15 06-19-2009 08:52 AM
Short Shifter Question. STi and Kartboy short shifters bambams247 Transmission (AT/MT) & Driveline 5 08-09-2004 06:52 PM
short shifter problem Qaveboy Transmission (AT/MT) & Driveline 1 04-22-2003 09:12 PM
