Old 05-29-2009, 01:56 AM   #1
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Default Need help wiring my GC Morettes
So I managed to pick up a set of Morettes. Here's the problem.
When I turn my lights on, the driver's side low beam lights up in full, the passengers' side is very dim. When I hit the stalk to turn the high beams on, the driver's side low beam stays on, the driver's side high beam does not come on. The passengers' side low beam goes off, the passengers' side high beam comes on in full.
I'm using the bulbs that came with the lights, I don't know how many miles are on them, etc. The relays and wiring looks correct from the diagrams I've seen. All the connections are good and clean.
Here are the questions.
Is this most likely a problem with
1. The wiring harness
2. The bulbs
3. The relays
and how do I fix this?
Thanks everyone in advance, every little bit helps.
XanRules is offline   Reply With Quote
Old 05-29-2009, 02:41 AM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
it's the bulbs, I've decided. I switched the two low-beam bulbs out and tried again. The driver's side doesn't come on at all, while the passengers' side came on full blast. Switching to high beams, the driver's side still doesn't come on - the high beam came on on the passengers' side, and the passengers' side low-beam stayed on. This leads me to conclude that the bulbs draw power from each other through the relays.
Neat. Figured my own problem out.
Old 11-02-2009, 01:03 PM   #3
voyagerman
Member#: 42133
2002 Impreza WRX
Rally Blue Pearl
The morettes comes with three relays ,for subaru 2002,.check those relays,remove the caps, they are suceptible to damage due to poor water resistance .I get a similar problem and when i removed the caps of the relays two of the three relays were totally corroded.I begin to experiment intermittence and the lights begin to turn on and off or one side turn on while the other keeps off.
let me know what you find.
voyagerman is offline   Reply With Quote
Old 11-02-2009, 03:31 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I fixed this issue after the thread was posted in May.
I have since retrofitted the Morettes.
i need help locating my battery wire veightkiller Electrical & Lighting 4 01-19-2006 04:38 PM
need help painting my morettes kinks19 Texas Impreza Club Forum -- TXIC 0 02-04-2005 10:28 PM
need help wiring my amp, Im a car audio n00b :( newb Car Audio, Video & Security 9 01-31-2004 11:19 AM
need help with my stock/morette lights!! gooter80 General Community 5 10-23-2002 10:17 AM
Need help wiring my antenna JGard Car Audio, Video & Security 6 02-05-2002 09:14 AM
