Old 05-29-2009, 04:45 AM   #1
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
Default mishap at ebisu circuit
well winter has passed and time attack season has started again. couple things changed on my car this season. switched to a TD05H/16G, 235/45/17 RE070s, cusco rear adjustable trailing arms, cusco rear adjustable lateral links, whiteline roll center adjust kit, R32 GTR Calipers an 04 sti rotors with ebc yellow pads. everything was going fine, but it wasn't hitting as high of top speeds as the last time i was on the track. anyways after a couple popped off intercooler hoses i was getting in the groove with 1:09.35, 1:09.20. 1:08.90, coming around for a last lap before cool down my brake pedal got rock hard and i had no brakes. here is the carnage.
Well after all this, since i have to paint 2 doors and a fender, going to go wide body :-)
wopdeeze is offline   Reply With Quote
Old 05-29-2009, 07:40 AM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
blessing in disguise. What happened with your brakes?
rjrutzky is offline   Reply With Quote
Old 05-29-2009, 08:12 AM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Sucks that it's damaged but in the grand scheme it looks like you got away with one. It could have been a LOT worse.
boost junkie is offline   Reply With Quote
Old 05-29-2009, 08:29 AM   #4
wopdeeze
Member#: 148597
00 GDA Jet Black
Still don't know what happened with my brakes, after i got pulled out of the tires my brakes worked fine. it felt like i lost vacuum to the master cylinder booster. it did shake me up a little bit, after that i was in the 1:10's. you are right it could have been alot worse, i was heading straight for the wall head on at 140kph, lucky for me and the time of year in japan the ground stays pretty moist so my tires were able to dig through the dirt to slow me down a bit, plus a little e-brake to rotate the car slightly to setup for a side impact, as i got closer to the end of the pavement i realized an impact was inevitable so i figured a couple body panels is cheaper than another engine. messed up part about the whole thing, i won a full set of Spec C doors the night before, that i was bidding on for the glass.. moral of the story don't bid on something the night before, because you will probably need it sooner than you expected.
Old 05-29-2009, 08:32 AM   #5
HighwayStarPP
Member#: 174548
2002 impreza
flat black
sorry to hear about your accidents, what did you have to do to the r32 caliper to make it fit? custom bracket? or just bolt on.
sell me your headlights kthxbai
HighwayStarPP is offline   Reply With Quote
Old 05-29-2009, 09:56 AM   #6
MasterKwan
Member#: 98961
2003 WRX
You're lucky, the times I've ever hit something on track always resulted in a totalled car... Maybe you should stick with Brembo's? Are the R32 brakes actually better than Brembo's?
I really want your fog covers too.
Old 05-29-2009, 10:26 AM   #7
wopdeeze
Member#: 148597
00 GDA Jet Black
quit parting my car with your eyes!
r32 calipers use a bracket, i created a post about it in the technical forum. anyways if they are better than brembos they are about the same, just a smaller pad sweep on the rotor, but the fact that i can use z32/gtr/gtst/subaru 4 pot pads makes it a little easier on the wallet for me the fact that the sti brembos are still fetching a pretty penny (i assume the gold paint on them is real gold) the nissan calipers provides me the use of 324mm x 30mm rotors for much better cooling. if i could afford some decent 18's and tires i want to try the GTR vspec brembos, with my calculations i figure that i would use a 355mm rotor with them and the same brackets im using. just trying to find the 355mm rotor might be a problem though.
Old 05-29-2009, 12:54 PM   #8
mateospeed
Member#: 116317
2002 WRX...sold:-(
Better count your blessings, dude... That's some pretty amazingly minor damage for a no-brakes off! I'm very impressed your escaped so unscathed!
Time to break out the buffer!
-Matt
mateospeed is offline   Reply With Quote
Old 05-29-2009, 01:06 PM   #9
DJSuperSoul
Member#: 120004
2xx8 STI
grey
check the hose to the master cylinder. hell, just get a new one.
DJSuperSoul is offline   Reply With Quote
Old 05-29-2009, 01:36 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
wwoooo, glad you are ok and the damage is minimal. So when are you getting back stateside?
Old 05-29-2009, 08:09 PM   #11
wopdeeze
Member#: 148597
00 GDA Jet Black
yeah im going to replace the vacuum lines just as a precaution, car is 9 years old things get old before you know it.
thanks micha, not sure, really enjoy it over here having tracks on every corner is very nice ;-)
Old 05-29-2009, 09:09 PM   #12
elirentz
Member#: 70082
2016 SS, 02 s2k
06 Cayman S, 80cc shifter
Yeah one of the few times you can say "It will buff right out" and for the most part mean it. Good quick thinking and a little luck went a long way.
elirentz is offline   Reply With Quote
Old 05-31-2009, 12:54 AM   #13
kursplat
Member#: 89528
2005 sti
crystal grey
sure you wern't left foot braking and bled off the vacume?
kursplat is offline   Reply With Quote
Old 05-31-2009, 01:21 AM   #14
wopdeeze
Member#: 148597
00 GDA Jet Black
yeah, i was only trying to brake will all my weight and nothing happened
Old 05-31-2009, 02:19 AM   #15
Wizzelt
Member#: 107512
2005 Audi S4
Moro Blue
going straight when it happened or into the turn? Pad knock back possible?
Wizzelt is offline   Reply With Quote
Old 05-31-2009, 02:52 AM   #16
wopdeeze
Member#: 148597
00 GDA Jet Black
going straight off throttle getting ready to go into the turn.
Old 06-01-2009, 05:59 PM   #17
PhantomPilot
Member#: 202275
Chapter/Region: PRSIC
2003 Impreza WRX
Sedona Red
Sorry to see a Suby wrinkled up, dosen't look that bad. That does look like you could buff it out, maybe touch-up paint.
PhantomPilot is offline   Reply With Quote
Old 07-27-2009, 08:23 PM   #18
wopdeeze
Member#: 148597
00 GDA Jet Black
after the first coat of paint, still need to wet sand and spray some more color on it but im finally making some progress.
Old 07-27-2009, 10:15 PM   #19
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Glad you're ok. It sounds like your brake booster pressure/vacuum line came loose, the one way valve stuck open, or your booster is bad. At the very lease replace the line and valve with a new oem piece and check the booster for a leaking diaphram.
Typically for the pedal to go rock hard the booster has to see boost pressure which means the pedal still should have come back after a second or two unless your throttle was still open/stuck.
Thanks
Phil Grabow
Element
Element Tuning is offline   Reply With Quote
Old 07-28-2009, 12:14 AM   #20
wopdeeze
Member#: 148597
00 GDA Jet Black
Thanks
Phil Grabow
Element
Phil,
Thanks, yeah i replaced both lines and i have another booster/mc just in case. havent had any problems since, but my nerves are still a little on edge the last time i went up to hakone for touge.
also for anybody deciding to use EBC yellow pads... dont waste your money, after this one event they are toast. ill post more when i get closer to the finish product.. and get my 255s mounted :-)
Old 07-28-2009, 07:28 PM   #21
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Are those new wheels or just spacers?
good job and luck getting back out there, Hope I can do the same.
parker/slc/gc8fan is offline   Reply With Quote
Old 07-28-2009, 09:51 PM   #22
wopdeeze
Member#: 148597
00 GDA Jet Black
Thanks! you too.
Same wheels with added spacers to fill in the 20mm front over fenders and the rear 50mm blister fenders.
Drags at Nago Circuit 9 Apr on Okinawa old_duwel Member's Car Gallery 25 05-02-2006 01:39 AM
endlink/swaybar installation mishap at dealer culturedetox Brakes, Steering & Suspension 25 10-21-2005 09:31 PM
Caught at Ebisu Circuit AVOjapan Member's Car Gallery 50 08-28-2005 02:41 PM
anybody wanna buy my spot at import circuit? suby ej25 Tri-State Area Forum 10 05-05-2004 09:14 AM
Hyper Meeting 2002 at Tsukuba Circuit - Impreza vs. Lancer [pics/link] j y Motorsports 0 05-15-2002 05:08 PM
