Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 05-29-2009, 11:50 AM   #1
ScoobyDoo69er
Member#: 82965
Default Handbrake or clutch switch 04 STi?
Hi guys,
I don't often post, but I'm after a little help.
Do you know if the 2004 STi has a clutch switch? If so where does the wiring run for it? If not, where does the handbrake (or e-brake) send it's signal from to say that it's on or off?
Thanks very much
ScoobyDoo69er is offline   Reply With Quote
Old 05-29-2009, 12:40 PM   #2
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
The handbrake has a switch on it. You'll have to pull open the center console to get to it.
The clutch has two switches on it. One for the starter, and the other to disable cruise control. IIRC the top switch on the clutch pedal is for the starter interlock, and the bottom the cruise control. Just follow the clutch pedal up and you will see them.
Noah is offline   Reply With Quote
Old 05-29-2009, 02:05 PM   #3
ScoobyDoo69er
Member#: 82965
Hi there,
I managed to find the handbrake switch, I just didn't look hard enough it would seem
However, as I don't have cruise control, does that mean I won't have any clutch wiring? As I still can't seem to see anything?
Thanks very much
Old 05-31-2009, 12:23 PM   #4
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
if your clutch has to be on the floor to start the car, then there is a starter interlock switch on the clutch. you need to look harder my friend.
jdubya301 is offline   Reply With Quote
Greetings from down under! Exedy clutch for 04 STi - OEM or stage 1 sports org.?? mr_tt Transmission (AT/MT) & Driveline 3 10-25-2009 03:16 PM
07 sti clutch in 04 sti tranny? RobWRX04 Transmission (AT/MT) & Driveline 0 08-29-2008 04:42 PM
starter or clutch switch?? Dknits782 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 10-22-2007 01:18 AM
act sti clutch and 04 STI Tranny South Coast Subaru Drivetrain 4 11-05-2006 10:18 PM
WTB: Clutch for 04 STi turbo tecnica Private 'Wanted' Classifieds 0 08-14-2006 01:50 AM
