Old 05-29-2009, 11:54 AM   #1
ScottyDOESknow
Member#: 203037
2006 WRX
SOLD
Default Boost gauge install problem--HELP!
Hey guys, I just installed a mechanical boost gauge last night and i'm running into a problem: the gauge won't shut off after the car is shut off. I wired it up using the clock wires. I have an 06 wrx. Everything else works fine, it's white when my headlights are off, green when the headlights are on, but won't shut off after the ignition is turned off. This is how I wired it:
gauge - car
12V accessory power - batt
ground - ground
acc - accessory power on
headlight switch - ill
The car abbreviations came from under the clock panel.
Any suggestions on how to fix this?
ScottyDOESknow is offline   Reply With Quote
Old 05-29-2009, 12:44 PM   #2
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
You might have the 12V battery and accessory power wires switched. Who makes the gauge you're installing?
Noah is offline   Reply With Quote
Old 05-29-2009, 12:54 PM   #3
ScottyDOESknow
Member#: 203037
2006 WRX
SOLD
prosport
Old 05-29-2009, 12:58 PM   #4
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Is it a Premium or Regular?
Old 05-29-2009, 01:05 PM   #5
ScottyDOESknow
Member#: 203037
2006 WRX
SOLD
I'm guessing regular. Its called the Green/white mechanical boost gauge
Old 05-29-2009, 01:08 PM   #6
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Try disconnecting the wire that is going directly to the battery. If I recall the regular mechanical gauges don't need battery power. The red and white wires can be connected to accessory in different combinations to change the color of the gauge backlighting.
Old 05-29-2009, 01:14 PM   #7
ScottyDOESknow
Member#: 203037
2006 WRX
SOLD
I cut the wire going to the battery and now the gauge doesn't light up at all.
Old 05-29-2009, 01:19 PM   #8
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Which color wire did you cut? Try hooking the wire you cut onto the same wire you have going to accessory.
Old 05-29-2009, 01:28 PM   #9
ScottyDOESknow
Member#: 203037
2006 WRX
SOLD
I cut the red wire. But you are correct Noah. I just got an email back from Prosport saying the same thing. The batt wire for the clock is a constant 12v, and I want ignition power. So according to prosport, if I hook up both red and white wire to the acc wire of the clock, the gauge should work.
Boost Gauge Install Problem! Please help 1st1 Electrical & Lighting 13 06-14-2012 09:09 PM
Electronic Boost Gauge install Problem !? HELP PLEASE boogyman_ea Electrical & Lighting 17 05-06-2005 12:40 AM
Boost Gauge Install Problems ronnyek Electrical & Lighting 8 12-06-2004 03:47 PM
Help! Boost Gauge install Problem! forsaken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-23-2004 06:25 PM
Boost gauge install problem please help dolinga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-28-2001 11:24 PM
